HP 840 G5 EndPoint Security Controller Problem
  • trunguntilyou
    • Aug 2022
    • 327
    • Vietnam
    #61
    Re: HP 840 G5 EndPoint Security Controller Problem
    I'm having the same problem, please help me
    • 2wtn
      • Dec 2017
      • 5
      • israel
      #62
      Originally posted by hoaca388
      You used the bios of another machine, so in the 32MB bios file, there is MPM information of that device and it has enabled the "security endpoint". I rebuilt the new 32MB bios file, cleaned the ME region.
      With the 16MB file, I deleted the first NvramActiveRegn region.
      But now you may have trouble with MPM again.
      Thanks for explaining the procedure of fixing the EC firmware. Worked for me to fix the "endpoint security controller" problem.
      To elaborate, this machine (HP Probook 440 G7) had its EC firmware corrupted which in turn caused persistent BIOS corruption. So besides re-building the BIOS image, I had to replace the EC firmware with a "foreign" one (from vinafix), but then I ran into the Security Endpoint issue. Eventually I removed the first NvramActiveRegn from the foreign firmware, and replaced the 2nd NvramActiveRegn instance with a copy from the original EC firmware, and then it was fixed. I also had to reset Secure Boot keys to factory defaults, otherwise the machine refused to boot with Secure Boot turned on.
      I wonder how you knew to remove the 1st NvramActiveRegn to fix that?
      • kulokutoys
        • Jun 2010
        • 132
        • Phillippines
        #63
        having same problem also tried deleted first nvram but it didn't work
        Model: Elitebook 840 G5
        Board number: Computro-6050a2945601-mb-a01
        S/N: 5CG92046B4
        • hoaca388
          Badcaps
          • Jan 2022
          • 11738
          #64
          Originally posted by trunguntilyou
          i'm having the same problem, please help me
          dd
          • hoaca388
            Badcaps
            • Jan 2022
            • 11738
            #65
            model: Elitebook 840 g5
            board number: Computro-6050a2945601-mb-a01
            s/n: 5cg92046b4
            gggggggg
            • kulokutoys
              • Jun 2010
              • 132
              • Phillippines
              #66
              gggggggg
              thank you working great. can I know the DMI location of this bin?
              • hoaca388
                Badcaps
                • Jan 2022
                • 11738
                #67
                thank you working great. Can i know the dmi location of this bin?
                aaaaaaa
                • alsai1
                  • May 2020
                  • 5
                  #68
                  Hi there Can you remove EndPoint Security Controller Problem on HP ZBOOK STUDIO G7 please
                  SN: CND03349B2
                    • 20906
                    SN: CND03349B2
                    Off topic. The thread as per the title is only for the 840 G5 .https://www.badcaps.net/forum/troubl...before-posting
                    • babydoll8867
                      • Nov 2014
                      • 91
                      • romania
                      #70
                      Hi, i am having a problem with a 840 g5 motherboard (6050A2945601-MB-A01, sn:5CG91751R4) The bios and ec have been already tampered with, so there are no original files. actually the notebook doesn't even show post with the files written in them. so, i tried a few pairs of bioses. with the majority of them it gives the "endpoint security error" issue that appear resolved with only one 32mb file but the ethernet has an error in device manager, device cannot start. even tried modifying Pcie slot in Fitc. didn't work. don't know why. the ethernet work with the ones with endpoint security. please help me resolve my issue. i attached the files that work but give endpoint error. thank you!
                      • ragoub44
                        • Feb 2022
                        • 6
                        • morocco
                        #71
                        Hello.i have hp 840 g5 with endpoint security error
                        my files
                      • LEO037_2029_
                        BIOS_LEGEND
                        • Nov 2023
                        • 83
                        • Argentina
                        #72
                        @ragoub44 TRY this bios and tell me.
                        read the pic ....
                      • ragoub44
                        • Feb 2022
                        • 6
                        • morocco
                        #73
                        read the pic ....
                        not working thks
                      • cvtech
                        • Mar 2014
                        • 63
                        • ph
                        #74
                        can someone help me to clear my bin
                        after bootng it says SECURITY DEVICE PROBLEM
                        pls help thanks guys
                        hp 840 g5
                        s/n 5CG8180LLR
                          SMDFlea commented
                          Editing a comment
                          Thread merged.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11738
                        #75
                        hp 840 g5
                        s/n 5CG8180LLR
                        HP EliteBook 840 G5 Base Model Notebook PC
                        • AlekS-GT
                          • Mar 2025
                          Hello PC gurus. I am Alex and I am a new member of this forum. My problem brought me here to find help or solution. My HP 840 G5 has an error EndPoint Security Controller Problem. This thing happened after I was able to sucsesfully remove a password from EC BIOS. Installing Win10 and apdating BIOS to the latest version did not help. For several days I have been seching and reading posts, but still could not understand what should I do. Realy need your help.
                          HP 840 G5
                          s/n 5CG84020QB
                          Prod/n 3RF06UT#ABA
                          Bios Q78 Ver.01.30.00​
                          • Bios Cracker
                            • Oct 2024
                            • 313
                            • India
                            #77
                            HP 840 G5
                            s/n 5CG84020QB
                            Prod/n 3RF06UT#ABA
                            Try and Update.
                            • AlekS-GT
                              • Mar 2025
                              Thank you very much, no more errors. Only spent a bit time with DMI tool on updating pc information in bios.
                              • Bios Cracker
                                • Oct 2024
                                • 313
                                • India
                                #79
                                Good to know mate.
                                • kolebbk
                                  HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                  by kolebbk
                                  Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                  HP Endpoint Security Controller problem
                                  there is a problem with the hp endpoint security controller on the unit
                                  I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                  09-04-2024, 12:44 AM
                                • fede77
                                  Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                  by fede77
                                  Notebook HP ProBook 450 G8
                                  ProdID 2K8L1LT#AC8
                                  Mother: DAX8QAMB8D0 REV D
                                  The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                  03-10-2025, 07:12 AM
                                • lamonde
                                  850 G6 Endpoint Security Controller Problem
                                  by lamonde
                                  Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
                                  and there is no soud after flashing new bios, may be have some solutions?
                                  ProdID: 4YD62AV
                                  SN: 2TK9500V8X...
                                  01-15-2025, 09:31 AM
                                • biednybelfer
                                  HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
                                  by biednybelfer
                                  After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
                                  Mainbard model:6050A3044201-MB-A01 (A1)​
                                  Serial Number: 5CG0275ZLV
                                  (I'm not allowed to upload files with the extension bin, so I upload zip)...
                                  10-05-2024, 05:04 AM
                                • Voyager65
                                  HP 800 G6 Deskop Mini - Endpoint Security Controller Problem
                                  by Voyager65
                                  I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
                                  I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
                                  SN: 8CC1120Z0V
                                  PN: 8WY18AV
                                  Bios Dump:
                                  Thanks a lot...
                                  01-13-2024, 04:58 PM
