correct caps?
  • sticky
    • Nov 2005
    • 8
    correct caps?
    I have a EP-8RDA3+ with drooping vdd. and i found a few bad caps.
    Ok the ones i found that are bad say 1500uf 6.3v and 1000uf 6.3v
    So are these the correct ones?
    1500's: http://www.digikey.com/scripts/DkSea...458897&Site=US
    1000's http://www.digikey.com/scripts/DkSea...458521&Site=US
    Thanks.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: correct caps?
    your links are no good. just give part numbers instead
    • sticky
      • Nov 2005
      • 8
      Re: correct caps?
      1500's: PCE3983CT-ND
      1000's: PCE3982CT-ND
      Thanks.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: correct caps?
        PCE3983CT-ND CAP 1500UF 6.3V ELECT FC SMD
        PCE3982CT-ND CAP 1000UF 6.3V ELECT FC SMD
        those are both SMD (surface mount) you dont want that. you want radial lead.
        • sticky
          • Nov 2005
          • 8
          Re: correct caps?
          For the 1500's i searched 1500uf - Low Impedance - Radial And came up with this P10356-ND But its 63v ! also their was a 50V way to high no?
          For the 1000's i searched 1000uf - Low Impedance - Radial And came up with this
          Lowest one to highest. P5645A-ND - P10355-ND 35V - 63V .
          Also i'm searching under "Electrolytic" Is that correct?
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: correct caps?
            page 963 of catalogue
            Panasonic FC
            1000 6.3 = p10199-nd
            1500 6.3 = p10203-nd
            page 966
            Panasonic FM
            1000 6.3 = p12340-nd
            1500 6.3 = p12343-nd
            • sticky
              • Nov 2005
              • 8
              Re: correct caps?
              Panasonic FC
              page 966
              Panasonic FM
              Whats the difference between Fm & FC? Also i dont understand why they didnt come up in the search?
              Are they "Low Impedance" I didnt see that in the description. Dont they have to be. I mean, which ever ones are the correct just tell me and i could really care less as long as its right and will work. Thanks for the help!
              EDIT: I just looked them up in the catalog and it says they are rated at 3000 hours? Thats less then a year?
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: correct caps?
                http://www.electropages.com/viewarti...aref=3420&act=
                FC Series
                • Low impedance • Long life: 1000 ~ 5000 hours at +105°C
                FM series
                • Low Impedance: 40 ~ 70% lower than FC Series • High Ripple Current: 50%
                higher than FC Series • Long Life: 2000 ~ 7000 hours at 105°C
                i dont have availability of FM series in my area so i use FC only. I think you should buy FM, they are superior.
                the hours rating is when they are tested at 105oC. You most certainly will not be running them at that temperature. the lifetime increases for each degree less operating temperature.
                meaning your board will be so obsolete by the time these caps reach end of life. many years of good service
                • sticky
                  • Nov 2005
                  • 8
                  Re: correct caps?
                  VERY cool. Thanks for all the help and info!!! I'll pick up the FM'S!!
                  • sticky
                    • Nov 2005
                    • 8
                    Re: correct caps?
                    I just received my caps. The 1500UF's are shorter and fatter then the ones currently on my board. The problem i will have is i will not be able to mount 2 of them flush as the are right next to eachother. Is this ok?
                    Thanks.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      Re: correct caps?
                      you can bend the leads and then solder the caps in angled.
                      you can also bend the leads and solder the cap in lying down if you have to clear for a pci/agp card etc.
                      bushytails of this forum likes to put a dab of hot glue to hold the cap which is lying down, properly. i dont bother
                      there is no probs with those techniques, many here use them and totally stable boards.
                      if you search for posts started by me you would see some pics
                        Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                        by momaka
                        I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                        For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                        https://www.badcaps.net/filedata/fetch?id=3591771
                        https://www.badcaps.net/filedata/fetch?id=3591772
                        It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                        https://www.badcaps.net/filedata/fetch?id=359177...
                        03-12-2025, 03:42 PM
                      • Paxman_Swede
                        Identifying caps on an old Zoom 9000
                        by Paxman_Swede
                        Hello!
                        I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                        The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                        I have studied the board and...
                        01-14-2025, 09:51 AM
                      • captain150
                        Help with switching power supply caps
                        by captain150
                        I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                        I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
                      • madscientist750
                        Replacing electrolytic caps by solid caps on old motherboards
                        by madscientist750
                        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                        10-19-2025, 06:10 AM
