Old 07-03-2010, 05:01 PM   #1
retiredcaps
City & State: Canada
Default Daytek DCM-17WT no display
I received a non working Daytek DCM-17WT (circa around 2002/2003). I'm not the original owner so I don't know the history. It is a hybrid LCD TV/computer monitor. The TV side has S-video and composite inputs. The "PC" side has a single VGA input.
SETUP
- known working VGA cable, 15 pin male to male
- known working laptop with VGA output
- known working AC power surger protector
- laptop plugged into Daytek PC side with known working VGA connections
- remote control has fresh known working batteries
- known working DVD player and composite cable plugged into TV side
SYMPTOMS
- press power button and Daytek LED will turn green, but there is no picture at all. No flash of the screen, nothing. LED stays green.
- pressing the OSD menu on the TV or remote shows nothing
- pressing the source button on the TV or remote control does not display any picture
- I cannot be sure what the "source" is because there is no OSD display or menu
- if I remove the LVDS cable, the screen goes entirely white and stays that way which infers the inverter board and CCFLs are working okay
- there is a slightly high pitched whine or squeal with the LVDS cable is plugged in. If I disconnect the LVDS cable, that sound is gone.
MEASUREMENTS
- external power supply DC12V 4.17A shows steady 12.22V DC with DMM
- inverter board gets 12V DC with DMM
- all fuses show 0.03 ohms with DMM
- LVDS (from left to right) DC voltages are
pin 1-4: 4.88V DC
pin 5-8: 0.00V DC
pin 9: 1.34V DC
pin 10: 1.19V DC
pin 11: 1.34V DC
pin 12: 1.19V DC
pin 13: 1.25V DC
pin 14: 1.28V DC
pin 15: 1.24V DC
pin 16: 1.28V DC
pin 17: 1.36V DC
pin 18: 1.17V DC
- I have no ESR meter, but all the caps look visibly okay except one that *might* have been slightly bloated which I changed. All the original caps are real "K" vent Rubycon YK 85C.
- all front panel buttons test okay (no shorts)
NOTES
- the cap I changed out took a lot of heat, scraping, struggles to get out and I think I damaged or removed the solder pads which explains why it looks so ugly. Solder doesn't stick to PCB very well. The front side logic picture shows the "old" cap in. It looks slightly bloated and I replaced it with a United Chemicon.
- I did test the monitor BEFORE I changed the one cap and I got almost the same voltage measurements on the LVDS.
- I have reseated and cleaned all the connections and verified cable integrity with a DMM using the continuity test.
- I think the problem lies somewhere on the logic board, possibly the pixelworks PW166B-10T chip. I suspect that for two reasons.
First,it looks like it is the chip that processes both PC and TV side inputs. Since neither composite or PC work this might be the choke point.
Second, it looks like this is a BGA implementation and there are numerous reported problems with this type of implementation.
- Datasheet for PW166B is at
http://www.eserviceinfo.com/download.php?fileid=24584
NEXT?
Since the PW166B is a BGA, I cannot easily verify it is working properly. I guess I can infer it is working or not by measuring the outputs and comparing it to the datasheet.
So I'm looking for suggestions on how to proceed or test points.
If the suggestion is to recap the logic board, I can, but I need to order some caps that fit. As you can see, some caps lie on their side to fit underneath the aluminum shield. And these are already Rubycon caps, albeit 2002/2003 circa.
Old 07-03-2010, 06:21 PM   #2
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Default Re: Daytek DCM-17WT no display
SETUP
SYMPTOMS
MEASUREMENTS
pin 1-4: 4.88V DC
pin 5-8: 0.00V DC
pin 9: 1.34V DC
pin 10: 1.19V DC
pin 11: 1.34V DC
pin 12: 1.19V DC
pin 13: 1.25V DC
pin 14: 1.28V DC
pin 15: 1.24V DC
pin 16: 1.28V DC
pin 17: 1.36V DC
pin 18: 1.17V DC
NOTES
NEXT?
An obvious next step would be to check the onboard voltage regulators. I count 7 of them.
PlainBill
Old 07-03-2010, 07:04 PM   #3
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
Another trick I use is to hook up an old video game or other signal source with composite out to the composite inputs. Then I step through the inputs until I hear the sound out of the speakers.
PlainBill
Old 07-03-2010, 10:45 PM   #4
el3ctroded
City & State: NC
The reason you had so much trouble is your soldering iron is likely not powerful enough to heat the part and power/gnd copper planes on the PCB, or there was no flux left in the solder, or both. The reason solder didn't want to stick to the board is the same reason: You were likely not getting the solder point hot enough, most likely due to a too-small wattage iron.
I use this 100W iron and on occasion have to turn up the temperature to 900degF (it says max 850, but it goes higher): http://www.xytronic-usa.com/LF-1000_index.htm
Edit: When using the temp so high, you have to be very careful not to damage the PCB or part(s)!
el3ctroded is offline   Reply With Quote
Old 07-04-2010, 11:58 AM   #5
retiredcaps
Happy 4th of July to all the American readers!
IC 501 - LM25765
pin 1 - VIN - 12.23V
pin 2 - OUT - 4.98V
pin 3 - GND
pin 4 - feedback - 4.92V
pin 5 - on/off - 0.01V
IC504 - AME1085
pin 1 - GND
pin 2 - OUT - 3.31V
pin 3 - VIN - 4.92V
IC302 - AMS1117 2.5
pin 1 - GND
pin 2 - OUT - 2.52V
pin 3 - VIN - 4.92V
IC9 - 78M05
pin 1 - VIN - 12.21V
pin 2 - GND
pin 3 - OUT - 5.01V
IC1 - AMS1117 3.3
pin 1 - GND
pin 2 - OUT - 3.31V
pin 3 - VIN - 4.93V
IC702 - AMS1117 3.3
pin 1 - GND
pin 2 - OUT - 3.31V
pin 3 - VIN - 4.93V
IC801 - MC7809C
pin 2 - GND
pin 3 - OUT - 9.09V
All the voltages look good to me and match the datasheets for input and output.
At first I thought IC302 VOUT was low, but the chip says AMS1117 2.5 which to me indicates 2.5V.
If I intrepret the datasheet correctly for IC 501, LM25765, pin 5 with 0V indicates ON while 5V indicates OFF.
On IC504, when I was probing, I had the black lead on pin 1 and it slipped and briefly touched pin 2 and I noticed the backlight came on while it was shorted. However, I don't know if there was a display or not because the panel was face front on the carpet.
PlainBill
Old 07-04-2010, 12:26 PM   #6
el3ctroded
City & State: NC
Do you have anything to use to test the CCFLs? 1 may be bad, though it usually will flash at turn-on when 1 is bad... I usually connect 1 at a time to find the bad one.
LCD Monitors also usually will display on the screen, you just can't see it cause of the backlight not being on. Use a bright flashlight and an input with a bright background being displayed to see if you are getting any display on the panel.
Old 07-04-2010, 12:44 PM   #7
retiredcaps
When I disconnect the LVDS cable, I get a full white screen on solid (not a brief flash). To me, this would infer, both CCFLs are working.
Old 07-04-2010, 01:03 PM   #8
el3ctroded
City & State: NC
Don't assume. Test 1 at a time. Looks like you have 4 CCFLs, so it would be hard to tell if just 1 failed.
Old 07-04-2010, 02:12 PM   #9
retiredcaps
Good point. So I took another LCD panel and tested it in the following manner.
All tests below without the LVDS cable plugged in.
1) Inverter board CN5 connected to Daytek CCFL tube "1" while the other 3 (CN4, CN3, and Cn2) are connected to an external LCD panel.
Result: Daytek LCD panel is white -> CCFL tube 1 works.
2) Same as above, but CN4 connected to Daytek CCFL tube "2" while the other 3 (CN5, CN3, CN2) are connected to an external LCD panel.
Result: Daytek LCD panel is white -> CCFL tube 2 works.
I did the same for CN3 and CN2 and CCFL tube 3 and 4 works.
In all cases, the external LCD panel was white.
However, WITH the LVDS cable plugged in and doing the exact same tests above, I get nothing on the Daytek LCD or external LCD screen.
I'm ready to test more suggestions.
Old 07-04-2010, 02:24 PM   #10
el3ctroded
City & State: NC
Well, at least we verified the CCFLs. How about seeing if there's any display on the screen using a flashlight?
Old 07-04-2010, 03:09 PM   #11
retiredcaps
Good suggestion. I tried this with a working DVD player and known good cables and composite/audio outputs.
I hooked it up and cycled through the source button on the remote and front panel and I hear no audio. I tried turning up the volume up/down on the front panel via knob and remote control. I also tried pressing the mute button several times and still no sound.
I found something new that I initially didn't find. With the LVDS cable plugged in, I can turn ON the TV via front panel by pressing in the button, but I cannot turn it OFF by pressing the front panel. I also cannot turn it ON or OFF via the remote.
With the LVDS cable unplugged, I can the TV ON and OFF using the front panel button.
PlainBill
Old 07-04-2010, 03:38 PM   #12
el3ctroded
City & State: NC
No display on the panel points to main board being faulty as you originally suspected.
Old 07-04-2010, 05:41 PM   #13
retiredcaps
Hmm, I missed one variation of this test.
With the LVDS cable unplugged, I can use the remote to turn the TV ON and OFF. Also, with the remote, I was able to switch the TV to composite and hear sound.
Once I found sound and composite source, I powered off the TV, plugged the LVDS cable back in and I saw the TV say something like "Composite Input no signal, monitor going to sleep" and the green power LED turns to red after about 5 seconds.
So I try again. I unplug the LVDS cable and I get audio, a white screen, but no picture. I power off and replug in the LVDS cable and I get no audio, no picture, and no message about a missing input signal.
Old 07-08-2010, 12:46 AM   #14
retiredcaps
Any suggestions on replacing the solder pads? I was doing really well today removing (from another monitor) one FU9024 and two C5707s until one side of the C5707 solder pads all came loose. All that effort installing new components only to have the last C5707 screw up. :-(
I heard something about solder glue as an alternative to solder?
This missing pad looks like another post at (2nd hole)
http://www.badcaps.net/forum/attachm...chmentid=16725
After 10 or 11 repairs, I have only had problems lately with the solder pads coming off. In both cases, the monitors were 2003/2004 heritage.
