Lenovo e460 bios problem
  • bilen
    • Aug 2014
    • 637
    • istanbul
    motherboard code : NM-A551
    device turns on and works but
    Invalid RFID configuration information area;
    Invalid RFID serialization information area;
    Machine type and serial number are invalid
    Machine UUID invalid.
    gives an error message. how can i fix this?
    NOTE: I wrote other bios in the forum
    .same result
  • peste
    • Dec 2016
    • 13599
    • ROMANIA
    Re: Lenovo e460 bios problem
    .same result
    DMI information is missing from the bios
    • bilen
      • Aug 2014
      • 637
      • istanbul
      what should I do ?
      • bilen
        • Aug 2014
        • 637
        • istanbul
        Anyone know the solution for this?
          • 21922
          Do you have the original bios backup.
          • bilen
            • Aug 2014
            • 637
            • istanbul
            unfortunately. this is how it arrived
              • 21922
              You will have to add the DMI info . Try this - https://github.com/ASparkOfFire/lenovo-u1-tool .If it doesn`t work look for LVAR64 (lenovo variable tool) or the lenovo hardware maintenance diskette
              • bilen
                • Aug 2014
                • 637
                • istanbul
                0189 error persists:
                It was fixed after the procedure you said :
                ''Invalid RFID serialization information area;
                Machine type and serial number are invalid''
                • lucaszmn
                  Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                  by lucaszmn
                  Problem:
                  I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                  Initial Findings:
                  • My current BIOS version is N1KET58W (1.45).
                  • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                  • I have the ability to use command-line tools on a Linux machine.
                  Troubleshooting Steps & Conclusions:
                  • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • grimacelord
                  Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                  by grimacelord
                  Hello there.
                  I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                  History:
                  1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                  I searched for this error online and discovered...
                  03-15-2023, 03:29 PM
                • to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                  by to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                  I have opened the laptop and identified the main BIOS chip...
                  10-24-2025, 01:35 AM
                • mkdj
                  Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                  by mkdj
                  Dear all,
                  I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                  Here the steps I have taken to fix the laptop:
                  - downloaded latest BIOS from Lenovo Website...
                  10-18-2025, 03:43 AM
