Old 01-26-2022, 08:43 AM   #1
Ukdigger
City & State: Lincolnshire
My Country: England
Default TOSHIBA 37CV505D TV turns on and then off
TOSHIBA 37CV505D TV
POWER SUPPLY PE0531 V28A000711B1
TV turns on with no backlight and then off after about 10 seconds
All caps test good with ESR meter, no signs of any burning, board has been repaired before but not by me. Should I be getting 12v on pin 1 and 2 12vlcd
Any help would be welcome.
Ukdigger is offline   Reply With Quote
Old 01-26-2022, 10:09 AM   #2
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
Default Re: TOSHIBA 37CV505D TV turns on and then off
Do backlights flash? Are you getting an image on screen?
dskall is online now   Reply With Quote
Old 01-26-2022, 11:07 AM   #3
nomoresonys
City & State: midwest
My Country: U.S.
The first thing I do when a tv goes on and off is check for bulged or leaking capacitors, they don't have to look bad to be bad tho. Second is in signature below, which is pretty simple and low cost, just to make sure it isn't the problem.
(Signature) One of the first and least expensive things you can do when you have an issue is take the powerboard out of the tv, flip it over and look the solder joints over with a magnifying glass if needed, add a little flux to make the solder flow well and add solder to any joints that look even a little suspect. You can practice on a scrap pcb board if needed, careful not to bridge any joints, and always let the board sit for quite a while or discharge the big caps with an appropriate resister before working on it (safety first) to try to keep from getting shocked, it doesn't take 1000 volts to KILL, a lot less can kill, so be careful, it's only a tv.
nomoresonys is offline   Reply With Quote
Old 01-26-2022, 12:53 PM   #4
Ukdigger
My Country: England
I don't see the screen flash from the front, in a dark room, but I can see a flash looking from the back near the underside of the inverter board.
Old 01-26-2022, 01:14 PM   #5
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
This is a older ccfl lit tv i wonder if this has the two second to black fault which is sometimes caused by the invertor or a failed ccfl tube or connection.
Not sure if you should have the 12volts on psu your missing, i would hope a more experienced member who understands schematics will advise on that.
vinceroger69 is offline   Reply With Quote
Old 01-26-2022, 03:06 PM   #6
dskall
dskall's Avatar
My Country: usa
A flash as in an arc?
Old 01-27-2022, 02:03 AM   #7
Ukdigger
My Country: England
No, a very brief flash of the ccfl's
Old 01-27-2022, 08:07 AM   #8
nomoresonys
My Country: U.S.
How bout a picture of the whole back of tv, if there's a cover on the inverter board take it off before the picture, check the fuse on inverter F1.
Old 01-27-2022, 09:29 AM   #9
Ukdigger
My Country: England
The fuse F1 is good and the caps esr is 0.0002 and 0.0007 (inverter board)
Old 01-27-2022, 09:42 AM   #10
nomoresonys
My Country: U.S.
The ribbon cable with the blue end looks really crooked.
Old 01-27-2022, 09:50 AM   #11
vinceroger69
My Country: uk
do both of the invertor transormers measure the same resistace as they do fail.
Service manual link https://elektrotanya.com/toshiba_37c.../download.html
Old 01-27-2022, 10:07 AM   #12
lotas
City & State: Sochi
My Country: russia
Check the PFC in the power supply, what voltage you have on a large capacitor, in operating mode it should rise
up to DC 380v - 390v.
lotas is offline   Reply With Quote
Old 01-27-2022, 10:54 AM   #13
dskall
dskall's Avatar
My Country: usa
And you don't smell any ozone? ccfl's are high voltage and prone to bad connections and arcing.
Old 01-28-2022, 07:29 AM   #14
Ukdigger
My Country: England
Reseating the crooked cable made no difference.
Before I go any further, I'm not getting any reading on this cap 4kv 22j 70
Old 01-28-2022, 07:38 AM   #15
nomoresonys
My Country: U.S.
Read it in ohms if you didn't, it is labeled starting with a Cxx?
Old 01-28-2022, 07:40 AM   #16
Ukdigger
My Country: England
I got 10.3 in the 20k scale
Old 01-28-2022, 07:44 AM   #17
nomoresonys
My Country: U.S.
Don't seem bad, what do you get on 200 ohm setting?
Old 01-28-2022, 07:48 AM   #18
Ukdigger
My Country: England
nothing on 200 or 2k
Old 01-28-2022, 07:56 AM   #19
nomoresonys
My Country: U.S.
You know, I forgot what they should be, let me see if I have one to measure.
Old 01-28-2022, 08:04 AM   #20
diif
City & State: Midlands
My Country: England
Check the four mosfets on the inverter for shorts.
diif is offline   Reply With Quote
