Hotpoint FFA47X Fridge Freezer
    Re: Hotpoint FFA47X Fridge Freezer
    Polarized is for DC as it has + and -. For alternating current it has no reason, the polarity is changing very fast. You may want to refer to wikipedia or some similar source http://en.wikipedia.org/wiki/Electrical_polarity
      Cool! So although the feed to the board is live (AC) it is being converted somehow into DC and the caps with the white strips are DC caps. Perhaps there is a mix on the board?
      I will re-upload single photos or at least try to.
        Here are some revised photos
          Well. I've spent the last 40 minutes going through the RS online catalogue and it appears that they do not appear to stock capacitors (certainly not) 100V DC or AC in 2.2 uF.
          Desperate to get this fridge fixed so will look to grab some desolder braid and a flux pen from them and try to find an identical rated capacitor on some junked PCB I have sitting around.
          At least I can test my desoldering skills!
            Yep, by a device called bridge rectifier. Or jsut four independent diodes may be used. http://en.wikipedia.org/wiki/Diode_bridge
            Anyway, it does not seem to me there is actually any in here so it must be somewhere else in the fridge and here it only controls the freezer.
            What is the capacity of that biggest capacitor by the three blue ones?
            There are 9 quality 2.2/100 caps http://uk.rs-online.com/web/c/passiv...1&m=1&aaaExp=Y
              make a list of all the electrolytic caps.
              include the voltage, the uf, the diameter, and the make+series.
                The power supply circuits uses capacitive power supply (the blue rectangular cap is used for dropping the Voltage to lower value). The power supply is half-wave rectifying, and C20 looks to be the main filter cap, what is the Voltage rating of that cap. RV1 is the MOV.
                Check R30, R100. Also check the capacitance of those large blue rectangular caps.
                What is the rating of that relay with white paper on top? the coil Voltage will give you some idea of what the power supply Voltage should be.
                There is display circuit board that is attached to this board, right?
                  Isn't it too small for that? Usually such caps I have seen have been big (1+ uF) and it still took only a couple watts for logic circuitry. Here with that big transformer it looks like 10, 20 watts.
                    Just enough to drive the relay.
                    There are two power supplies, one the SMPS, and one for the relay.
                    I did not finish tracing the board yet.
                      i wonder why it has a reed-switch?
                        Thank you. I'm getting into this. There's a huge amount to learn though.
                        I'll check and report back when I get time over the weekend.
                        They do have them but the problem was they do not stock them at the local branch. Online only so no weekend fix or attempt at fixing.
                        I blew my first capacitor up yesterday! Will start another thread on another project I have going when I get a minute.
                          Which blue rectangular cap - C7?
                          I will check all and report back sometime over the weekend.
                          RV1 is the MOV.
                          What is a MOV please?
                          Will do and report back.
                          Hopefully, it will state this on it when I remove the paper. Otherwise I'd have no clue how to do that but can hopefully research that online.
                          You are correct. That is the problem with the fridge. The display used to blink over so often but now it doesn't bother!
                          If only I could buy a spare board for it but they are obsolete.
                            No idea but it is open. Don't know if it should be.
                            And thanks to everyone so far for helping me out with this. It is very much appreciated. I hope I can crack it and get it working again. If it doesn't stop buzzing SWMBO wants a new fridge.
                              yes, it should be open.
                              it closes when you put a magnet near it.
                                All measurements are taken in circuit (with components on board) at this point in time as the fridge needs to be kept live and I need to develop my desoldering skills. Any good videos out there? Watched a few on YouTube last night but they were fairly varied in quality.
                                I am currently using a Peak Atlas ESR70 to provide measurements in circuit.
                                C7 markings:
                                Top
                                N101083561 C
                                S4-X1M275V~ (Unsure about X though could be letter W)
                                Side
                                B81130 X2 MKP/SH
                                40/100/21/B
                                ENEC logo with a number 10 by side of it then RL in capitals written backwards with 250V~ under it and then cRL written backwards with 250V~ under it next to that
                                C13 markings:
                                Top
                                100n K 400V
                                373 MKT
                                Side
                                BC
                                R 0422
                                C29 markings:
                                Top
                                MK250
                                Cannot see any other markings on this cap.
                                C7 - Open Circuit or low resistance
                                C13 - 9.84uF ESR 2.3 Ohms
                                C20 - 400V 10uF (measures 9.53uF and ESR 4.4 Ohms)
                                RV1 - In-Circuit/Leaky ESR = 0.00
                                R30 - 10 Ohms
                                R100 - 27 Ohms
                                Other caps:-
                                Rating
                                C6 - 100V 2.2uF RMU (M)105degC (4R)
                                Measures
                                522.6uF ESR 0.61 Ohms
                                Ratings
                                C30, C31 and C33 - Teapo 50V 22uF SH105degC A3 04/04
                                C32 - Teapo 25V 100uF SH105degC A3 11/03
                                Measure
                                C30 - 0.92uF ESR >40 Ohms
                                C31 - 1.12uF ESR >40 Ohms
                                C32 - 88.48uF ESR 0.93 Ohms
                                C33 - 7.9uF ESR >40 Ohms
                                Rating
                                C28 - ELNA 10V 470uF CE105degC 0422 and a letter S in a circle RJH (M)
                                Measures
                                524.8uF ESR 0.19 Ohms
                                Rating
                                C26 - Teapo 25V 100uF SH105degC A3 11/03
                                Measures
                                88.22uF ESR 0.78 Ohms
                                Rating
                                C5 - Unknown RMU 100V 2.2uF SH105degC A3 11/03
                                Measures
                                Rating
                                C25 - Unknown KME 50V 22uF (M)105degC
                                Measures 24.6uF ESR 1.76 Ohms
                                  As an aside, I have put my DMM on the copper windings of L2 and there is no beep? Surely there should be continuity?
                                  Anyway, better plug it back in before food defrosts completely.
                                    Oh yeah seems like just one way rectification than.
                                    These are most likely bad, such high ESR is too high even for GP caps of that capacity (they yrae not so bad as JingHai caps so they should not have over 40 ohms; yet here you would nicely use ESR Micro which has range up to 200 ohms):
                                    These seem to be in parallel, if you have multimetr you can set it to diode/continuity tester (beeper) and check both appropriate sides, they should beep:
                                      Thanks Behemot.
                                      How can I tell if a circuit in general is AC or converted to DC? This question is for this board but also in general so two questions really.
                                      I am trying to find out how I can tell whether a capacitor is AC or DC? I suppose you could technically have a mix on a board depending on where it is located in the circuit.
                                        Considering that you need the fridge in service, capacitors are cheap, and the caps are 11 years old, why are you even bothering to troubleshoot? Just replace them all, and if there are any relays on the board, Id replace those too.
                                        As far as ac caps go, I havent ever seen a pcb mounted AC cap in an appliance. AC caps tend to be large and screw terminal or use quick disconnects.
                                          some are mounted near hot resistors.
                                          replace all.
                                          any lytic over 40 ohms esr is gone anyway.
