Hi everyone!
I've got a 22 inch Toshiba TV which is really just a rebaged Vestel and like so many of these things the PSU has got a shorted diode on the 12v rail preventing it from working.
Now replacing the diode is simple enough but having read this thread https://www.badcaps.net/forum/showthread.php?t=42137 I'm leaning towards fitting a high voltage fast recovery diode instead but my concern is how hot would such a diode get with the increased voltage drop? Should I parallel multiple diodes up like Vestel did?
The back of the TV reveals a power draw of 50w max which is just over 4.1 amps @ 12v.
The PSU is a VESTEL 17IPS61-3 and can only accept DO-201 diodes but I can't find any suitable 300v+ 5 amp schottkys in that package which is why I'm considering a regular fast recovery diode instead.
The 24v rail currently has a single 200v UF5402 installed which I plan to upgrade to the 400v UF5404 in order to cater for the increased reflected voltage spike which the 12v rails underrated schottky used to clamp.
If anyone has repaired one of this PSU's before I would be interested in knowing what replacement part you fitted and how long the repair has lasted, I know these boards are infamous for being junk but I'm trying to avoid a repeat diode failure in future from selecting an under rated part.
Thanks!
Thanks!
