I have a Dell 2408WFPb which has worked for years, but after moving it to a new location, it will no longer power up. (A couple of weeks ago it also didn't power up but eventually worked after a few tries.)
None of the capacitors or other components appear damaged.
I have posted photos of the power input board and power supply board:
https://www.dropbox.com/sh/bff8p2cqb...vEc1JZjya?dl=0
Some measurements with a multimeter:
power input board:
fuse F601 - good continuity
power supply board
input cable CN603 - 122V AC
main cap C605 - 167V DC (I read in another thread that this should read higher, might be a problem)
fuse F701 (upper right below multi cable) - good continuity.
Please let me know if you have any ideas or other test points I should check.
Thanks!
power input board:
power supply board
Thanks!
