Another one of these XFX GeForce 8600 GT video cards saved from the electronics scrap yard!
This one is a version 6.5. Technically, it is the same exact thing as version 5.0 from the other thread I created a while back. But I decided to make a new thread for this, as the other one got a bit off-topic with me erroneously concluding that the card was failed. So here goes another one.
As usual, I got this 8600 GT from eBay too. But unlike the previous one, look at what we have here:
https://www.badcaps.net/forum/attach...1&d=1499527964
This 8600 GT came with pretty much all of the original box contents (including the game, “Company of Heroes”). I am the type of person that likes to keep original boxes, cables, and CDs with my hardware, so I find this awesome!
Now let’s see the card from up close:
Uh-oh - busted Sacon FZ all over again. Let’s have a closer look, shall we?
Ugh! It's like a dejavu of the other 8600 GT. The RAM has both of its caps busted. That’s always risky, as I have two EVGA GeForce 7600 GT video cards that smoked their RAM due to this. But again, the seller of this auction reassured me that the card was working when it was taken out of service. So I took his word and began my recap.
Step 1: Give the video card a Sacon-be-Gone treatment. My spray can of that stuff ran out, so I had to do it manually with a soldering iron
- Ah! Much better!
Step 2: Solder replacement caps.
I probably went a bit more minimalist here than I normally do, as I did nothing to replace the bulged FZ caps on the 12V rail (only left the blue Chemicon PSA polymers). But this was just for testing, after all. I also used more Chemicon PSA caps as the replacement for some of the FZ, just for the sake of consistency and color-matching .
By the way, note the corrosion on the SMD cap pads – not sure why, but it was pretty terrible on this video card. I cleaned them all before soldering my “new” caps.
Step 3: test.
Well, it works alright. But for how long? –Probably not much if under load / gaming. Look at these core temperatures:
At a 21°C / 70°F room temperature and open PC case, the GPU core temperature easily reached 62°C (and still rising) after about 20-30 seconds under medium-high load. Clearly, the heatsink is not adequate here, just like on the previous 8600 GT. It will surely need a modded heatsink of some sort.
So now that the card was working, I made a cap diagram for it, so you can see which caps are connected to which rail. Technically, I didn’t really need to make one, as this video card has the same exact layout and design as the v5.0 8600 GT – so if you’ve read through that thread, you may find the information here a bit redundant. On the other hand, the cap diagram in this thread may be easier to follow than the text description in my other thread.
Cap diagram:
If I remember correctly, these were the voltages for the rails above:
GPU V_core: 1.4 Volts
RAM Vdda/Vddq: 1.8 to 2 Volts, depending on RAM type (Infineon typically takes 2V)
GPU Vtt: 1.25 Volts
And finally, I save the best for last. The icing of the cake, as they say.
Let’s see how bad those Sacon FZ caps are once they poped. Ladies and gentlemen, I present you Sacon FZ at their finest:
Lol, look at these c[r]aps! They are a hair away from open-circuit. . Not even two (2) nanoFarads of capacitance in any of them! I think it is an absolute miracle this video card worked at all!
Now that the video card is recapped, the only thing that can kill it is heat. So for this, we need us a modified heatsink that will keep the core lower than 60°C. But that would be material for another post. I am already experimenting with my first 8600 GT. Once I come up with a good heatsink mod that is both quiet and cool, I will then make the same one for this video card.
- Ah! Much better!
Step 3: test.
Cap diagram:
GPU Vtt: 1.25 Volts
