Bought this about 15months ago and used it as an external drive for my desktop and laptop. Just stopped working the other day. No noise coming from it so I removed the printed circuit board and gave it a clean. Is there a fuse on this board? Can't think of anything else to try except buying and exact model replacement and swopping the boards over to prove wether its the board or the motor thats at fault.
Seagate Barracuda 500gb 3 1/2" hardrive faulty
Re: Seagate Barracuda 500gb 3 1/2" hardrive faulty
Probably a failed drive. Is there any non-replaceable data on the drive (data that doesn't exist anywhere else)?
If not, junk it and replace with a Western Digital drive. Seagate drives are hot garbage. Also, if there are any other Seagate drives in service that you know about, make plans to replace those ASAP.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpic
^ Oh come now, they aren't all bad. The early dual platter 7200.11 1Tbs are good. Well, mechanically anyway... FirmwareLast edited by goontron; 09-22-2018, 12:58 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.
Originally posted by Cornboats View PostBought this about 15months ago and used it as an external drive for my desktop and laptop. Just stopped working the other day. No noise coming from it so I removed the printed circuit board and gave it a clean. Is there a fuse on this board? Can't think of anything else to try except buying and exact model replacement and swopping the boards over to prove wether its the board or the motor thats at fault.
Try another (sacrifical) drive in the enclosure. If it WORKS, then original drive is bad. If it doesn't work, enclosure is bad.
check power supply ..Last edited by petehall347; 09-22-2018, 06:55 PM.
I didn't realise Seagate had such a bad reputation. I bought a new caddie but the results are the same. I was trying to eliminate the small circuit board on top of the drive. Is it possible to hardwire the motor bypassing the circuit board just to prove where the fault lies?
Originally posted by Cornboats View PostI didn't realise Seagate had such a bad reputation. I bought a new caddie but the results are the same. I was trying to eliminate the small circuit board on top of the drive. Is it possible to hardwire the motor bypassing the circuit board just to prove where the fault lies?
I just had a seagate 160G drive fail, it was the motor drive ic that failed.
three phase? o_ODon't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
Originally posted by TechGeek View Postthree phase? o_O
The one on my drive was a Smooth 100501286, similar to the Smooth L6284Last edited by R_J; 09-23-2018, 12:09 PM.
Originally posted by TechGeek View Postthree phase? o_OThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
You will need to pay for postage to them, but they will inspect the drive and if they cannot retrieve data, they will not charge you. They will only ask for return postage costs to be paid I believe.
They have rescued many failed drives for us in the past - https://www.eadr.co.uk/
I get no benefit from this 'plug', just recommending a good company that I have used many times.
