Seagate Barracuda 500gb 3 1/2" hardrive faulty
  • Cornboats
    Dave
    • Oct 2010
    • 232
    Bought this about 15months ago and used it as an external drive for my desktop and laptop. Just stopped working the other day. No noise coming from it so I removed the printed circuit board and gave it a clean. Is there a fuse on this board? Can't think of anything else to try except buying and exact model replacement and swopping the boards over to prove wether its the board or the motor thats at fault.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Seagate Barracuda 500gb 3 1/2" hardrive faulty
    Probably a failed drive. Is there any non-replaceable data on the drive (data that doesn't exist anywhere else)?
    If not, junk it and replace with a Western Digital drive. Seagate drives are hot garbage. Also, if there are any other Seagate drives in service that you know about, make plans to replace those ASAP.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      ^ Oh come now, they aren't all bad. The early dual platter 7200.11 1Tbs are good. Well, mechanically anyway... Firmware
      Follow the white rabbit.
      • diif
        • Feb 2014
        • 6978
        • England
        Is/was the drive in a hard drive caddy ?
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Did you remove the PCB from the DRIVE? Or, from the ENCLOSURE (into which the drive plugs)?
          Try another (sacrifical) drive in the enclosure. If it WORKS, then original drive is bad. If it doesn't work, enclosure is bad.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            maybe there is something wrong with the enclosure? Try another HDD in it.
            • petehall347
              • Jan 2015
              • 4451
              check power supply ..
              • Cornboats
                Dave
                • Oct 2010
                • 232
                I didn't realise Seagate had such a bad reputation. I bought a new caddie but the results are the same. I was trying to eliminate the small circuit board on top of the drive. Is it possible to hardwire the motor bypassing the circuit board just to prove where the fault lies?
                • petehall347
                  • Jan 2015
                  • 4451
                  yes you could plug it in on the inside of your pc .
                  • R_J
                    • Jun 2012
                    • 9629
                    If you have a board from a same but different drive, that would work. The motor itself is a three phase motor, do not just hook up voltage to it it will not work.
                    I just had a seagate 160G drive fail, it was the motor drive ic that failed.
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      three phase? o_O
                      sigpic
                      • R_J
                        • Jun 2012
                        • 9629
                        Originally posted by TechGeek
                        three phase? o_O
                        If the motor has three lines going to it , it is likely a 3-phase brushless dc motor.
                        The one on my drive was a Smooth 100501286, similar to the Smooth L6284
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          three phase? o_O
                          Yes..... And?
                          • seanc
                            • Nov 2008
                            • 1319
                            It's not often I find someone in the UK on these forums...if you don't mind paying for recovery, the guys linked below will likely be able to retrieve your data, assuming there is no damage to the platters.
                            You will need to pay for postage to them, but they will inspect the drive and if they cannot retrieve data, they will not charge you. They will only ask for return postage costs to be paid I believe.
                            They have rescued many failed drives for us in the past - https://www.eadr.co.uk/
                            I get no benefit from this 'plug', just recommending a good company that I have used many times.
