Go Back   Badcaps Forums > General Topics > Custom Tweaks, Modifications, and Revisions
Old 09-04-2018, 06:12 PM   #441
diif
City & State: Midlands
My Country: England
Default Re: The ghetto mod thread
Originally Posted by stj View Post
white bits remind me of a sword or gun stand.
like you use to put one on a shelf.
Not so stabby shooty but close enough.
It's had a trim since the last photo.
diif is offline   Reply With Quote
Old 09-10-2018, 09:52 PM   #442
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
^ Soldering iron stand for the v-shaped piece was what I had in mind first as well (or perhaps a hot air wand "stand". But the other piece, I really couldn't think of anything. My first guess was some kind of special mobile phone and/or tablet test jig / holder. But a hot glue holder?? - no way. I just put my hot glue gun on the bench and hope that it doesn't leak (seems as some of my hot glue guns get older, the start to leak glue a lot more). That's one reason I don't keep them nozzle facing down anymore.
Old 09-14-2018, 02:07 AM   #443
momaka
momaka's Avatar
My Country: U.S.A.
Default Re: The ghetto mod thread - summer house P3 PC
I did a few upgrades to the summer house Pentium 3 PC, posted here:
https://www.badcaps.net/forum/showpo...&postcount=603
Basically, one of the upgrades was that I changed the video card to a Sapphire Radeon 9600. Being a passively-cooled video card, I decided to put a fan to blow some air across its heatsink, as it would get pretty hot when running games. This is the ghetto-mod:
The fan is held by a piece of steel sheet bent into an “L” shape (so that the fan wouldn’t flap around, as the steel sheet I used is rather thin). The steel sheet piece is held with a screw to the case and the fan is held with another screw. I cut it to a length that puts the fan right over the heatsink. As for the fan, it came out of a gutless broken L&C PSU I got from a repair shop (this one, actually). It’s a Foxconn 80 mm fan rated for 0.14A or thereabout. I connected it directly to a floppy drive connector to run @ 7V (‘+’ lead connected to 12V rail and ‘-‘ lead connected to 5V rail), so that way it is both quiet and still pushes enough air to keep the card cool.
Other ghetto mods in that PC…
You’ve probably noticed one of the cut IDE cables with red electrical tape.
Also not visible in that picture but there: CPU fan is also connected to run @ 7V, because otherwise it is very loud. For this, I took out the black wire from the fan connector and shoved it in the back of a spare molex connector, hooked to the 5V rail. And because of doing this, the motherboard no longer shows the fan tacho/RPM… but that’s not an issue. The fan is still audible even @ 7V, so I will hear it if it stops. The 933 MHz Pentium 3 CPU still cools absolutely fine that way.
Old 09-14-2018, 05:56 PM   #444
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
All my hot glue guns "leak" because they're cheap and all the trigger does is feed the glue, and depend on the viscosity of the glue from letting it drip.
In fact are there any hot glue guns that actually block off the nozzle? I end up putting them on their side if I *really* didn't want them to drip, else... I just let them drip.
eccerr0r is offline   Reply With Quote
Old 09-14-2018, 07:17 PM   #445
momaka
momaka's Avatar
My Country: U.S.A.
^ I hate drippy glue guns - it's a waste of glue.
The one I have is from Michael's (arts and crafts store in the US). Probably the best and cheapest glue guns I've bought ($2 or $3 I think). It doesn't drip when new. But if you leave it overheat for too long, it will start getting drippy over time. Mine's fairly old (about 13 years) so it's gotten a bit drippy. Only way to stop it is to lay it on the side... and also not plug it in until ready to use. Once it starts "self-feeding", that's when I use it. When done, I unplug it.
The other same one I have, it's still very tight and does not drip at all.
Old 09-15-2018, 12:08 AM   #446
brethin
City & State: Owensboro, KY.
I use solder the wife uses hot glue.
brethin is offline   Reply With Quote
Old 09-15-2018, 01:04 AM   #447
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I haven't seen any that fancy.
Mine would possibly drip if I used it sufficiently, but I don't do much with it.
I did have an awfully cheap ($1) one before, which fell apart. I pulled the trigger, and the glue stick pushed the heater and nozzle out the end of the gun. The plastic around the screws had softened... Then again, it was only rated for 220v and I get 237v at home.
-David VanHorn
Agent24 is offline   Reply With Quote
Old 09-15-2018, 05:09 PM   #448
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
yeah, mine drip. I'm so cheap I reuse the drops by remelting on the tip and reuse as much as possible, true ghetto style
Old 09-16-2018, 01:25 AM   #449
momaka
momaka's Avatar
My Country: U.S.A.
^ Ha, me too!
Actually, doing that is not too bad. Now try doing the same with old pealed and yellowed hot glue. It will re-melt, but don't expect it to hold too long. I do that on my cheap multimeter leads when their hot glue starts to degrade and brake off. Each time this happens, the glue holds less and less (typically around 1/2-1 year, though, so that's not bad).
Old 09-18-2018, 09:03 PM   #450
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Insanely Hot Texas
Line Voltage: 118-126VAC@60hZ/200A
I'm a: Hardcore Geek
I have so many computers and junk in my room that EMI/RFI runs rampant. Not to mention the fact that there's an A/C condenser unit with 2 VFDs next to my bathroom. I also like listening to the radio. Obviously, there's a problem: 99% of the stations on the dial are swamped.
Here's my fix. I have some shielded wire from an industrial thermocouple attached to the stereo receiver's 75 ohm input. The shield is connected to ground. This goes to a set of jumper clips which goes to some bell wire. The white wire is connected back to the stereo receiver's ground, but is also connected to a ground stake driven into the ground. The red wire (signal) is connected to a homemade all-direction antenna, which was held from falling by a pair of old wire strippers. All the wire is held in place with staples.
This takes me from getting a couple staticy stations to 19 or 20 stations in crystal-clear stereo.
Suck it, RFI.
And bite me, FCC.
https://badcaps.net/forum/attachment...1&d=1537326135
For computer parts, go to Newegg
OR
Amazon.
For electrical stuff(pushbuttons, capacitors, etc), use Digikey
OR
Mouser.
Windows 10!? Oh yeah, that sorry excuse of an operating system that spies on you 24/7/365!
Samsung = Seagate = Seatrash = Trashgate
Don't buy Seagate drives. Don't use Seagate drives. If you have any in service right now, make plans to replace them ASAP.
TVs repaired: Toshiba 32AV500U
Stereo Receivers brought back to life: 1(Fisher RS-1056)
Stereos/Stereo receivers to recap: Fisher RS-1056
TechGeek is online now   Reply With Quote
Old 09-19-2018, 12:49 AM   #451
momaka
momaka's Avatar
My Country: U.S.A.
^ Man, all of that long unshielded wire... just pray a lightning doesn't strike near your house, as that can easily fry your stereo (or at the very least, the receiver portion inside). Otherwise, everything else is proper
Old 09-29-2018, 10:34 AM   #452
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Some news on the G86 core 8400GS - it's still working! No artefacts so far, so I guess it was a successful "reflow"?
Anyways, my latest "invention"
ATX to AT adapter. Ripped a 24pin plug off a dead MSI board, used two AUX plugs off two PSUs, added a switch.
Works fine, just tested it on a 486DX-50 board I am going to work on as soon as I can source a ISA GPU.
Main rig:
ASUS H61M-A
Core i3-3220 3.30GHz
MSI Twinfrozr GTX 750Ti 2GB GDDR5
6GB DDR3-1066
Samsung SH-224AB DVD-RW
Raidmax RX-500XT (recapped)
Seagate Barracuda ES.2 ST31000340NS 1TB
JNC RJA-52 case
Dan81 is offline   Reply With Quote
Old 10-10-2018, 01:35 AM   #453
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Originally Posted by TechGeek View Post
Suck it, RFI.
And bite me, FCC.
Honestly FCC doesn't care.
However your neighbors do. If you're reducing the enjoyment of other peoples' enjoyment of RF services, this is a problem. The FCC was made to allow others who can no longer enjoy RF to take actions against people who make lots of RF trash hash.
If you have no neighbors, knock yourself out until you reach the next person nearest you who cares.
The normal rule of "out of sight out of mind" doesn't work for RF, where other infractions against others can easily be seen, you can't make the same argument for RF so a new set of rules need to be made - FCC rules.
Old 10-10-2018, 03:44 AM   #454
stj
stj's Avatar
City & State: Europe
FCC warnings in the past sounded more like they were protecting the governments ability to bug people actually.
Old 10-12-2018, 11:39 PM   #455
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
This actually is not a "ghetto" mod but I didn't want to make another thread. Maybe it's a ricer mod, but that backlight is sorely needed on this old HT 2m ham radio. In any case the 30mA incandescent backlight burned out. Of course I didn't have any 12.8V 30mA incandescent lamps that would fit that spot, so ... how about an LED!
Turns out a T1 LED fits. However I didn't have any orange or even white T1 LEDs, have a lot of red ones which would look funny. I did have a blue T1 LED. Tuned it to about 5mA and got:
Old 10-13-2018, 04:29 AM   #456
stj
stj's Avatar
not bad, it's not easy doing led swaps - you often get uneven lighting because of the more focussed output.
Old 10-13-2018, 11:45 AM   #457
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Yeah I was worried about that, but fortunately lucked out probably because of the size of the screen. Also the LED was a "flood" versus a "spot beam" LED (you can tell by the distance between the die and the top surface) so that probably helped a little.
Old 11-16-2018, 10:10 AM   #458
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Well here's my fuse.
From top to bottom:
- the colorful wires that pass data to/from the main board and the display board
- the jury rigged black fuse holder frame
- the gold plated contacts of the black fuse holder fuse
- (foreground) the 10 amp shunt loop
- the 3AG 3 ampere regular blow fuse
- the original 10mm fuse holder nickel plated contacts
- the green wire
- the red wire that feeds from the front panel
- the green main PCB
- 10A measurement black wire
- and finally the original 10mm x 38mm BBS4 fast blow 4A fuse lying there ready for the trash can.
I guess it's not as ghetto as if I wrapped the endcaps of the 3AG fuse with aluminum foil to make it thick enough to meet the 10mm needed for the contacts, but oh well, it's a workaround to get this to work.
Old 12-07-2018, 04:38 PM   #459
Drack
Yup it's me
Drack's Avatar
City & State: Carabobo
My Country: Venezuela
Line Voltage: 110v 60hz
Huh, just found this thread, I think I have quite a bit of stuff that qualify for it... Probably will post a couple tomorrow
Drack is offline   Reply With Quote
Old 12-08-2018, 02:29 PM   #460
Drack
Yup it's me
Drack's Avatar
Smile Re: The ghetto mod thread
well lets start...
this is my main pc:
Asrock g41-vs3 rev2.0
Pentium E5700 @3.69Ghz (246 FSB IIRC)
4gb of ddr3 ram (2x2) dual chanell @984Mhz CL-7
PowerColor R9 270 Turboduo
Agiler Agi-1000ps psu
random case
on this pic you can see there is a black thing on top of the bottom fan(i saw that there was a hole on the bottom of the case, i had a 80mm low rpm fan that could take some cold air from the side grill for the gfx so...) is a 10w 20ohm resistor for the nidec beta V 92mm fan on the back
here you can see some tape on the 5v and ground wires, the cables connected to those are going to a guetto mounted 120x38mm fan that moves a ton of air even at 5v
in reality you cant actually see the foam unless you get very close
here you can see the guetto mounted fan using a molex conector cutted from a cd drive and blue leds
more details later
Badcaps.net Technical Forums © 2003 - 2019
