I have a neighbor that has this TV and he brought it to me because I have had luck fixed TV's in the past. The TV works like normal accept everything has a blue tint to it. Everything I have read online makes me think there is an LED issue but I have also seen some that say it's a TCON issue. I am just looking for some guidance of where to start, I have replaced a bunch of LED in LG TV's and am familiar with the process to do so just want to get opinions on where I should start to pinpoint the cause of this. I would prefer not to just start buying parts to try to find the problem. Thanks in advance!
Hisense 55H6B Blue tint
Re: Hisense 55H6B Blue tint
if your backlights look blue looking at them from the back thru the little holes, i doubt it's the tcon at fault, most likely the backlights are worn out from being overdriven. Whenever your tv is set to vivid and the like they run the backlights at full blast and they wear out all the faster, article there says something about adjustments but that's probably just if your tv got out of adjustment somehow, best to turn your backlights down to as low as you can tolerate, to expand their lifespan, if they have turned blue from that they will need replaced: https://voltfixer.com/how-to-remove-...ve_a_blue_tint
Yes, please post photos of YOUR ACTUAL TV.
Failing LEDs can have degraded phosphors that emit a blueish light, but also a problem in LVDS signal cable can cause a blue "push" which causes more gain to blue signal than red or green signals and yield similar issue. Hard to know which it is without some nice clear photos of images that should have easy to discern white areas. Try a news channel feed - it will have people's faces and usually white text that might help people see the issue
Picture looks ok in spots, so would say your leds are the problem.
https://www.youtube.com/watch?v=Fv15_yyo9dMLast edited by dskall; 03-22-2022, 06:58 PM.I assume no responsibility for any stupid suggestions I might post.
