Hey everyone,
I have been trying to figure out this error. I have not been able to calibrate the unit, not getting anything from the test resistors. Running the self diagnostics give me the F6 error code. I have at this time de-soldered the components checked the resistors, and verified that everything has been put into place. Re-soldered the components listed under the F6 code. Maybe everyone here might be able to stop a misplaced component or point me to test some thing.
I have followed the leads on the board and tested with an ohm meter to see if there are any breaks, but non found. I have pictures located on my web site, you can view them here http://www.comshyft.com/ESRMeter/ . The I have the photos split up into two folders for the front and back side of the board.
I am just stuck at this point and I am trying to avoid the expense of sending it into Anatek. I was working with their tech support, who was stuck on solder whiskers or a bridged lead. After I posted the pictures and sent them a link they jumped to it can be troubleshooted. I figured I would check here with you guys and see what options I may have.
Thank you in advance.
