Hi all looking for some help on repairing this old TV for a friend in work. Its a Sony KDL-40W2000 (Old LCD TV).
Any Help Guidance would be much appreciated.
TV has the LED error code 3 -
UNREG10.5V, PANEL5V Voltage Trouble (DCALERT1).
When power is applied and the power switch on tv is pressed you can hear the relay switching the LED goes from RED to Green for a brief couple of seconds then it goes into the flashing Red LED state. (3 blinks pause 3 blinks pause and so on.) On doing some reading up I've found:
"" Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault.
This is also a problem in the power supply circuit, check T603 and R672. (I cannot find these parts on the schematics at all most parts have the letter of the component and then 4 numbers.) ""
I have attached a pic of connector CN6200 as I took some measurements from it but no voltages were present with the connector seated or unseated.
Some pics are attached and I hope to get back to this tonight to get more pics and measurements
I also found this thread: https://www.badcaps.net/forum/showth...hlight=40w2000
Thanks in advance.
S.
Thanks in advance.
S.
