Hot Tub Power Supply - In Need of Comparable Relay
    I have a power supply board to a hot tub that a customer brought in to me. He says that one of the relays on it is bad. He can hear it click and it does appear to be damaged visibly. I am having trouble sourcing the part because everywhere I have looked is out of stock due to the part being obsolete now.
    I was wondering if anyone here could recommend a substitute that would work. I'll give you all of the info I have on it.
    Part Number: ALF1TF12
    Datasheet: https://cdn.badcaps-static.com/pdfs/...35596d7749.pdf
    Contact Arrangement: Form 1 A
    ) Compressor load: 20A 250V AC
    2) Inverter load: 20A 100V AC,
    10A 200V AC
    2. High insulation resistance
    • Creepage distance and clearances
    between contact and coil;
    Creepage Min. 9.5mm
    .374inch
    Clearance Min. 8mm
    .315inch
    • Surge withstand voltage: 10,000V
    I appreciate any help I can get. Thanks.
    Re: Hot Tub Power Supply - In Need of Comparable Relay
    https://www.digikey.com/product-deta...2633-ND/645563
    Digikey # 255-2633-ND Mfgr# ALF1T12
    Or drop the (f) and mouser also has it, none of the datasheets say anything about the (F), so what the F
      lol
        'F' is the UL Class F insulation.
        I.E.:
          I.E.:
          Thanks for posting this information
          9 PC LCD Monitor
          6 LCD Flat Screen TV
          1 Dell Mother Board
          15 Computer Power Supply
          All of these had CAPs POOF
            I.E.:
            Thanks guys. So even without the UL Class F, should the relay you linked me to work R_J? Budm?
              Maybe
              It might not last as long as would ( F ) type one
              9 PC LCD Monitor
              1 Dell Mother Board
                I see no reason why it would'nt, It does appear to be Coil insulation class F. UL Class F
                I don't see what choice you have if the original part is obsolete. Does the board have a layout where an alternative type of relay could be installed?
                  Just wanted to report back -
                  I ordered the relay suggested and it worked. Successful repair. Thanks again, guys! This forum is the best.
