About a week ago I picked up a Samsung 59 inch plasma that someone was throwing away. The model number is pn59d530a3fxza. When I attempt to power it on the red indicator blinks and it makes clicking noises. I know that Samsung had an issue several years ago with bad capacitors causing this problem. Please bear with me, I have very little experience troubleshooting at the component level. I did not find any bulging or leaking capacitors but it appears that one of the transformers is damaged. My problem is that I can't find any information with what I believe to be the correct part number. The power supply board is BN44-00445c PB6F-WVL. The board is stamped TX801S next to the damaged transformer and the transformer itself is labeled PB6F - VM. There are two other numbers (SC-03B and SC-110914CK) as well but those are also on other components. Can someone help me identify the part and possibly tell me where I can get a replacement? I have found a replacement board online but I'd rather spend a few bucks and hope it works instead of dropping $150 on a TV I know nothing about.
The Dreaded Clicking Sound And No Power On Samsung pn59d530a3fxza
Re: The Dreaded Clicking Sound And No Power On Samsung pn59d530a3fxza
That is the transformer for the stndby power supply, so what DCV do you have on each pin of the CN801 connector? Make sure to give the pin number and pin names after each reading.Never stop learning
Good afternoon, sorry for jumping into this thread but I think I have the same issue or a similar one. I have a PN59D530A3FXZA. Y302. And it no longer gets the power light, I think it's the PCB on it, and I've heard that it's usually just the capacitors, so I wasn't sure if someone here knew the fix as I can't seem to find the board for sale anywhere. Model for the board is BN44-00445C I believe.
Rodeo9ine can you post pics? The capacitors should be bulging or leaking if they're bad. On ebay the BN44-0045C boards don't last long. I did find them on another site but if ljintexas has one I'm going to grab it from him.
Before replacing the SMPS.
Unplug all boards except the main board.
Verify 5V standby
Turn TV "on" so that relays click
As soon as it is turned on verify Vs and Va (~200V and ~55V)
Then verify the 15V or 13V, whichever is present
If any of these are missing the SMPS is at fault
If all are present, even if they disappear after a few seconds, some other board is at fault
It is very rare for the power supply to fail on a Samsung plasma TV set. It is not a common issue.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can you still read any printing on the caps? They are the same value, the resistors RP820 and RP825.
They are R/C snubber network for the PFC MOSFET and the PFC Diode.
http://www.shopjimmy.com/samsung-bn4...upply-unit.htmNever stop learning
