Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 12-06-2009, 08:06 PM   #1
garrettair
Question Blown (FZ78 1500 6.3v) on XFX 8600 GT. What to buy?
This is a two part question.
1. Can I buy any capacitor just based on the 1500 and 6.3v, or are there other things that I need to learn?
2. What capacitors should I buy? Two (FZ78 1500 6.3v), and one (FZ78 1000 6.3v) broke. I hadn't even been over using my computer that day.
The two big ones are the 1500's. I take it that means how much it holds?
garrettair is offline   Reply With Quote
Old 12-06-2009, 10:29 PM   #2
ss627
Super Member
City & State: New York
Default Re: Blown (FZ78 1500 6.3v) on XFX 8600 GT. What to buy?
2 of http://www.badcaps.net/store/product...products_id=40 and 1 of http://www.badcaps.net/store/product...products_id=48
If there are other capacitors of this type on the card, I would replace them even if they still look fine.
ss627 is offline   Reply With Quote
Old 12-06-2009, 10:33 PM   #3
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
you have sacon fz. those things are so BAD! as you have seen they explode with force. make all of them go away. NOW!
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 12-06-2009, 10:33 PM   #4
garrettair
It's that simple? Wikipedia was talking about resistance in perecent. Thanks!
Old 12-06-2009, 11:46 PM   #5
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
There are at least 10 of these on that card. ALL need to be replaced. Not just these blown ones.
FZ are KNOWN bad brand and 'always' fail. If you don't fix them now, you'll be back doing it again, or they'll end up killing your card.
Toast
Toasty is offline   Reply With Quote
Old 12-06-2009, 11:52 PM   #6
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Yes it's that simple.
If you don't replace all the FZ series caps you have a good chance of eventually causing permanent damage to other components.
I have no idea what you saw on wikipedia but it doesn't make much sense in talking about caps.
GSC changed their name because their products were such crap.
http://www.google.com/#hl=en&source=...5ffa94030d2d34
Their new names are Sacon and Evercon.
Guest who makes -> SACON <- FZ series caps.
http://www.google.com/#hl=en&q=FZ+ba...5ffa94030d2d34
Now, Sacon and Evercon's site just went 'poof' again, like the old GSC site did.
We are waiting to see what their next new name will be.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 12-06-2009, 11:56 PM   #7
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Thought this might help.
http://www.badcaps.net/forum/showpos...79&postcount=8
Old 12-07-2009, 07:04 AM   #8
Keith41501
City & State: Kentucky
Exact same capacitors I just replaced on my motherboard and 1 on my video card. All Sacon FZ on the mobo and Sacon Evercon on the video card. I replaced em with Rubycons. Easy to do.
Keith41501 is offline   Reply With Quote
Old 12-07-2009, 02:19 PM   #9
garrettair
Toast
All right, here is a picture of the video card model I have. I shooped it so that the colors match.
Only 2 Large A's are blown
(\n for next line)
A: 3x(FZ78 \n 1500 \n 6.3v) 1x(FZ78 \n 1000 \n 6.3v)
B + E: 3x(FZ79 \n 470 \n 16v)
C: 1x(642 \n SVP \n 330 \n 16)
D: 1x(628 \n SVP \n 330 \n 16)
F: 1x(square \n A 779 \n 1200 \n 4V)
G: 3x(square 7YZ \n 100 \n 16v)
H: 1x(68 \n 470 \n 16 A)
If this is going to be really hard, I might as well just buy this: http://www.newegg.com/Product/Produc...82E16814121340
It's cheaper and faster. But I at least want to try.
Old 12-07-2009, 08:09 PM   #10
garrettair
So I looked though the store and found these:
Code:
1500uF 6.3v 10mm MCZ Series  $1.83 x3
1000uF 6.3v 8mm MBZ Series    $0.49 x1
470uF 16v 8mm GD Series	   $1.28 x3
I couldn't find any caps like C, D, F, G or H. Is it possible that these type aren't made?
Old 12-07-2009, 11:45 PM   #11
ratdude747
Black Sheep
ratdude747's Avatar
no, re-cap it. that way you have one that is reliable... newegg would get you another ticking time-bomb...
how could it be cheaper to buy new? caps are far cheaper than 50 bux... i have recapped p3 coppermine boards... and those were worth far less than 50.
do you have a decent iron (no 22w pos for radio s***)? solder sucker/dentist pick? get those and some solder, and order caps. once you get the hang of it, its easy.
if you have crappy skills, practice on a dead board... any circuit board will do. thats the best way to be a better solder monkey.
Old 12-08-2009, 12:41 AM   #12
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
No, you don't need to replace all of those.
Just the FZ
C&D are: Sanyo OSCON, SVP, 330uF, 16v -- Good Cap
F is Chemicon PSA series: 1200uF, 4v -- Good Cap
G&H: Not sure but not FZ so -probably- not a problem. Those are up to you.
Old 12-08-2009, 12:59 AM   #13
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
If you want to do the others try digikey.com.
Old 12-08-2009, 02:24 PM   #14
garrettair
Thanks! For reference, I attached what I bought.
Old 12-15-2009, 06:02 PM   #15
garrettair
They worked! %100 back to normal. Thanks!
Old 12-15-2009, 08:31 PM   #16
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Congrats!
Old 12-17-2009, 02:28 PM   #17
garrettair
A strange thing has started to happen. I put my computer in sleep mode a lot. It has always woken up fine, but recently, it will fail to wake up, then try to reboot like a failed car engine. It sometimes works after 5 tries. I removed the video card and everything is fine, so it must be the card. When I had finished putting the caps on, the last one was a little loose, could that have affected it? Also, the fan on the card is sounding funky.
Old 12-17-2009, 02:46 PM   #18
Toasty
Toasty's Avatar
Question Re: Blown (FZ78 1500 6.3v) on XFX 8600 GT. What to buy?
I have no idea what all that is. Nothing opens. Just a text file would be fine.
What do you mean by "sounds funky"?
Old 12-17-2009, 03:31 PM   #19
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
I think you may have a problem on +5v or +5vsb.
+5vsb enables the wake.
RAM has power in standby from +5vsb then switches to +5v on wake.
GPU fan is -probably- a 5v fan. [Please check.]
Was that loose cap on 5v?
Old 12-19-2009, 12:27 PM   #20
garrettair
The loose cap was a 16v.
