Panasonic Blu-ray Disc Player -SA-BTT490 - Dead
    Hi, have this Blu-ray disc player that is completely dead due to being powered by 220-240V while the duel voltage switch was set for 110-127V.
    The internal 250V 3AH fuse did not blow and the IC5799 has been destroyed.
    When the player is connected to 220-240V, I have 110V across the mentioned fuse.
    Having not repaired any disk players (only tvs) I'm stuck on what to check next?
    Thanks.
    Re: Panasonic Blu-ray Disc Player -SA-BTT490 - Dead
    that piece of shit looks familiar - alot like the SA-PT860
    the chip is probably:MIP4110MSSCF
    check any diodes near it, and dont forget to check for surface-mount parts on the underside.
      possible example schem.
        Service manual:
        http://elektrotanya.com/?q=showresul...at2=schematics
          Hi, sorry to interject but If you manage to fix yours, maybe you could give some pointers to mine, though a different issue.
          https://www.badcaps.net/forum/showth...d=1#post528531
            Originally posted by albertross View Post
            hi, have this blu-ray disc player that is completely dead due to being powered by 220-240v while the duel voltage switch was set for 110-127v.
            The internal 250v 3ah fuse did not blow and the ic5799 has been destroyed.
            When the player is connected to 220-240v, i have 110v across the mentioned fuse.
            Having not repaired any disk players (only tvs) i'm stuck on what to check next?
            Thanks.
            ic5799=mip2f2
              Ic5799=mip2f2
