Who is the producer of the red/brown 3300 uF caps on the photo? Are they suitable for motherboard applications? It's a Shuttle AV11 that has been unsuccessfully recapped. Will try to get it working again.
Please help me to identify these caps
Who is the producer of the red/brown 3300 uF caps on the photo? Are they suitable for motherboard applications? It's a Shuttle AV11 that has been unsuccessfully recapped. Will try to get it working again.Last edited by willawake; 05-27-2005, 01:00 PM.Tags: None
they appear to be United Chemi-con KMG series.
They are used by several board manufacturers. Whether they are suitable for motherboard applications, the chemi-con series chart indicates that they are not the best choice as it indicates they are standard series. KY, KZE, KLH, KZG, KZH are better choices as they are low esr.
i don't think it is suitable for your purpose. the kmg series has lower ripple current than the other low impedance series or from the competitor...
again, i'm sorry for including my chart. at 2200uf 16v it has only about 900 ma ripple current... 2 times lower than the others that has about 1500ma or higher...
in my opinion it is not even the choice for the purpose
Asus A8N-SLI Deluxe
DFI nF4 SLI-DR
So it is still worth of trying to replace the caps with known good ones as the first step?
1. other components of the board sustained a failure when the original caps failed.
2. the person recapped the board badly and has damaged a trace or lead port etc........
this is assuming that all the caps on the board have been replaced with new.
first step would be to visually check the board for damaged traces, burnt components. if it looks ok then i would remove the caps and check the lead ports for signs of damage or too much heat. (i think its difficult to tell though). then you could try recapping the board with some other caps. If none of that works then you will have to test the circuits of the board.
pls advise guys, i am not very familiar with circuit testing.
why are you sorry Yanz? you are doing a great job. we need someone to collect this data.
BTW, is that a Kaspersky bug you are holding? Dude, crush it!
Under availability in your chart: does this mean that you can obtain them in your local area? Given the cheap prices you have quoted in the past, I was even considering placing an order with you!
sulbert: i wast trying to recapping 2 caps near the agp slot of my abit kt7 with chemicon sxe (better than kmg) and it won't post. also i try the sanyo (S.E.08 ?) which didn't fix the situation. i try the mbz and kzg and both are success..
for else, i agree with what willawake said...days are so short when you actually do something..
