i have an intel g31pr montherbaord. when it in cold boot its working perfectly after almost 10 mintues it freezes then when i restart it giving memory beep.i am sure its not because of bad memory i changed lot of memories same problem coming .. to get the board work again need to cool down about 15 mintues. is it beacuse of bad caps? i could not find any bad caps. please answer me
intel G31PR freezing after heatup
Re: intel G31PR freezing after heatup
Are all of the cooling fans working?
Does it have a fan to pull air over the CPU heat sink?
Do you have software installed that will monitor the CPU temperature and if so, what is the CPU temperature?
If you have a can of component cooler or compressed air you can use that to cool down the CPU heat sink and see if that will help it restart in less than 15 minutes.
If you have a can of component cooler or compressed air you can use that to cool down the CPU heat sink and see if that will help it restart in less than 15 minutes.Last edited by srt1; 03-18-2014, 09:22 AM.
After 10 minutes of operation does the CPU temperature still read 50 degrees?
I would use a fan or component cooler to cool different parts of the board to isolate the problem. Try cooling the memory modules, CPU, south bridge, and anything else that seems hot to see if you can get it to run more than 10 minutes.
If there are no bad caps, i would suspect that there is a problem with the Northbridge. You could try reflowing it.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
Originally posted by T30M31 View PostAfter 10 minutes of operation does the CPU temperature still read 50 degrees?
Is the mother board an Intel Dg31pr ?
Can you tell me who makes the memory and the part number of the memory modules?
Please try this when the computer has cooled down.
Start computer and let it run 10 minutes.
Turn off the computer and remove AC power cord for 2 minutes.
Connect AC power cord and start computer.
Does it give memory beep now?
Does it give memory beep now?Last edited by srt1; 03-19-2014, 10:33 AM.
That Kingston ram is on the Intel list of memory modules that have been tested to work with the DG31pr mother board.
This is a link to the Intel memory list.
http://www.intel.com/support/motherb.../CS-027918.htm
I am glad you solved the problem.
Try running the memory at a slower clock and more lax timings. See if that changes anything. Unless you have genuine Hynix RAM (i.e. not just Hynix chips on the RAM module, but also proper info in CPU-Z), the module could be made from binned RAM chips, so there's no 100% guarantee it will work at the advertised speeds.
It could also be the BGA joints on the NB as Th3_uN1Qu3 suggested.
Originally posted by momaka View PostTry running the memory at a slower clock and more lax timings. See if that changes anything. Unless you have genuine Hynix RAM (i.e. not just Hynix chips on the RAM module, but also proper info in CPU-Z), the module could be made from binned RAM chips, so there's no 100% guarantee it will work at the advertised speeds.
