hello can somone point me in direction this file please done search with no luck .
K9GAG08U0E SAMSUNG nand flash file
Re: K9GAG08U0E SAMSUNG nand flash file
google maybe something like "ue40d5520 dump" that set has an EEPROM and a NAND. Your nand is faulty. Maybe there is some vendor that sells the Nand pre programmed. You may have to match with the main board number. It starts with BNxx-something. Maybe post a dump request into the EEPROM dump threat here: https://www.badcaps.net/forum/showthread.php?t=59877Last edited by CapLeaker; 03-13-2019, 07:46 PM.
Does the auction state that the NAND is specifically programmed for your TV? Or are you buying empty ICs for which you need to program yourself?
Please provide more information.
Please provide the eBay auction links to the 4 you have purchased for us to review.
Originally posted by chrislyons View Posthello there are programed nand on ebay much rather solve problem my self i do have propper programing gear . gq-5x
this is message i got Copyright (C) 2014-2018
GQBlaster 1.10
Target: K9GAG08U0E
CE Pin = 1
-load
-read
Time 00:08:40 (.692)
Source bad block No. 203
Source bad block No. 485
Source bad block No. 1014
Source bad block No. 1025
Source bad block No. 1745
Source bad block No. 1893
Source bad block No. 2074
that is what I would do. I'd order a new blank nand IC and in the meanwhile I'd look and ask for a nand dump for that TV. If by the time the new IC comes, no dump was found, I'd try copying the saved file from the old nand into the new nand, put that back onto the main board and see what's happening after you turn on the TV.
BTW. what happens if you read the nand after you freeze it with a can of air upside down?
Try this @chrislyons https://se******************************IJzD2ym-gfQ
Originally posted by chrislyons View Posthello can somone point me in direction this file please done search with no luck .
