Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 12-08-2022, 04:24 PM   #1
fab13
City & State: Arras
My Country: France
I'm a: Knowledge Seeker
Question ps4 power supply resistance out of order, what to choose?
Hello
After checking this resistor which gives no value on the ohmmeter on a PS4 SLIM power supply.
I would like to change it but by which power I can choose it knowing that this resistor is on the primary part that is to say on the 230/400 V side
Value 16.8 Ohm normally according to color code (See photo)
1st ring = Brown = 1
2nd ring Blue = 6
3rd ring Grey = 8
4th ring OR Multiplier = x0.1 Ohm
5th ring Red = +/- 2 %.
Tolerance of either + or - 0.336 ohms
Dimension of the resistor Length = 6.4mm, Width 4.8mm
Can I place one between 15 and 17 Ohm or a little more?
What power in Watt I can order if it is 2W or 3W
I don't want to do anything stupid about the value to choose
Thanks a lot to you
fab13 is offline   Reply With Quote
Old 12-08-2022, 05:18 PM   #2
lotas
City & State: Sochi
My Country: Russia
Default Re: ps4 power supply resistance out of order, what to choose?
This is a safety resistor, plays the role of a fuse (0.16 Om. 5%).
lotas is online now   Reply With Quote
Old 12-09-2022, 01:21 PM   #3
fab13
City & State: Arras
My Country: France
Strange because it doesn't even sound continuous in this case
Old 12-09-2022, 02:33 PM   #4
lotas
City & State: Sochi
My Country: Russia
What is strange here, 3 stripes (silver) is a multiplier of x0.01.
Old 12-12-2022, 01:06 PM   #5
fab13
City & State: Arras
My Country: France
Question Re: ps4 power supply resistance out of order, what to choose?
I was really surprised to see this silver stripe in the 3rd position, so I considered it as a grey color.
I can't find any other information about a silver band in the 3rd place for 5 rings.Maybe it should not be taken into account then =S so I will have to calculate it as 4 rings.
This would give 0.16 Ohm but tested in several modes Diode or megaohm the resistance gives nothing at all.
Only I need an example of a resistor on the same power supply of a ps4 slim
Old 12-12-2022, 01:49 PM   #6
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Is this the resistor at location F3? if it is, it is a 0.16Ω-2watt. Lotas post #2 is correct
R_J is offline   Reply With Quote
Old 01-17-2023, 03:53 PM   #7
fab13
City & State: Arras
My Country: France
So the resistor is indeed 0.16 OHM which acts as a fuse we will say.
I ordered a 2W and it is much smaller, so I took a 3W which is the same size and the power supply works now
Many thanks to you
Old 01-17-2023, 09:21 PM   #8
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
I don't think I've ever seen a multiplier band of gray (and definitely not white), it's always been silver of that set of similar colors.
Purple multiplier is rare enough as it is... I think I've only seen 1 or 2 ever.
eccerr0r is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
