This is one of the electronic course project which I'm currently doing so first I'll tell you what I think I have learned but not really helpful and then I'll ask a few questions.
--A TRIAC is an AC device when voltage is applied to the gate, it allows AC to pass through it.
Own Understanding Of How TRIAC Works In AC Voltage Circuit
"Don't be afraid to insult me--if I have this wrong. Please just spell it out to me as I'm still learning a bit more"
QUESTIONS
- Situation-A: When the switch on the Primary Side of the step-down rectifier transformer is pushed, current flows through the 1A fuse via the 10K OHM voltage divider. This allows current to apply to the gate. It will conduct both the (+) and (-) half-cycles of AC. And result can be pulses of energy at a rate of 100 times per sec if the line frequency is 50Hz (230V). Forward current start to bias toward the bulb (40W) when junction 3 and 1 is connected on this high speed cycle phase. Then current will flow through the TRIAC and the bulb illuminates.
- Situation-B: If the wire between junction 3 and 1 removed, voltage will not be converted through the 10K OHM resistor. The pulses of AC can't be given to the gate. So current will not flow through TRIAC and the bulb will remain dim..
- Situation-C: Refer to QUESTION 3...but before that do i get those 2 answers to the situations above correctly...please correct me if I'm wrong
QUESTIONS
- Does simply removing the gate current (3,1) latching of the junction connector sufficiently turn OFF the TRIAC? Why?
- Does varying the gate voltage limit in some way how much AC is passed through the TRIAC? And once a device is triggered, the gate voltage doesn't affect the current that flow through the device. Why?
- How do I switch the 40W bulb to be triggered by the TRIAC so it will always illuminate?
