sanyo no back ligth
    Re: sanyo no back ligth
    OK, the last set of pictures, some are really good, some are kind of dark and yellowish/greenish pictures.
    But I am able to trace out how the PWM IC for the backlights inverter gets its power from.
    It is generated by the AUX winding of the 12v power supply. the output is fed through first voltage regulator circuits (Q602, Zener Diode ZD601), the output of the regulator then is fed to the switched transistor Q303 which is turn on by the OPTO IC 303 when the BL_ON (BL-SW) is applied.
    So we need to find out if we are getting the VCC on pin 16 of the PWM IC301.
    We still need the P/N of those IC's.
    You will need to find the way to measure the voltages.
    Make sure to use the negative leg of C821 as your GROUND REF.
    Check ZD601, Q602, Q303, R320.
      So are you still working on this? Lots of time spending on tracing out the board.
        I do hate when people disappear mid-thread as we are getting ever closer...
          Some time I felt like wasting so much time tracing out so many boards for the forum (not many people are willing to do) from bad pictures, and no follow-up.
          • ealequi
            • Dec 2012
            • 212
            • usa
            #165
            hey i am here. i am testing it. for me it take forever, want to make sure i dont mess something else. i will give you the result withing minute.
            • ealequi
              • Dec 2012
              • 212
              • usa
              #166
              This is very strange. none of the one you ask me to test has power pin 16 on ic301, zd601,q303, r320,q602. i check the meter in other resistant and it is working.
              • ealequi
                • Dec 2012
                • 212
                • usa
                #167
                One more thing, I want to apology to every one that is helping me, but been cristmas time you get unexpected visitor and has to stop doing what i really want to be respecfull. Again my apology.
                  "This is very strange. none of the one you ask me to test has power pin 16 on ic301, zd601,q303, r320,q602. i check the meter in other resistant and it is working." I do not understand this statement. I want resistance reading, especially the Zener diode and the transistors to make sure they are not shorted out first, if they are bad , then the voltage reading will be next. Step by step.
                  And the parts are on the bottom side of the board plus they are also on the hot (deadly side of the circuits, must be real careful) you will have to have the board power up with the lamps connected just in case the inverter circuits kick on, you do want high voltage arcing.
                  "it is working" what is working?
                  • MisterD
                    • Oct 2012
                    • 668
                    Okay, Did you hook the negative probe of your volt meter to the negative lead of the Capacitor C821 on the power supply board? it must be hooked here for the ground connection otherwise it will not give you any voltages, and please leave it there for checking these voltages bud has asked for? these are DC Voltages not resistance. Then you will remove the negative probe from C821 and make sure the power is off then check resistance of the other components as you normally would.
                    • ealequi
                      • Dec 2012
                      • 212
                      • usa
                      #170
                      do i need the board pug tocheck the diode?
                        Board should have no power applied when testing diodes or resistances.
                        • ealequi
                          • Dec 2012
                          • 212
                          • usa
                          #172
                          yes i did
                          • MisterD
                            • Oct 2012
                            • 668
                            Please read post 168, turn on TV to check voltages, turn off TV to check resistance.
                              Unplug the TV from the outlet to check when checking the resistance.
                              And by the way, what are the IC P/N I request so we will know what operating voltage on pin 16 should be (now I assume that the line I trace from the pictures is correct)
                              • ealequi
                                • Dec 2012
                                • 212
                                • usa
                                #175
                                ok this is what i got zd601 =.6, pin 16 on IC 301 with ground on c821 = beep but not reading, Q602=.6, Q303=.6 on e, 1.7 on b, R603 and R320 beep but not reading. Nothing, not even beep on C809,C808,R805,R806,R807
                                  OK take the DC voltage reading next. With TV plugged in and power switch activated.
                                  • ealequi
                                    • Dec 2012
                                    • 212
                                    • usa
                                    #177
                                    ok give me a minute
                                    • ealequi
                                      • Dec 2012
                                      • 212
                                      • usa
                                      #178
                                      ok, is the testing on the green part of the board or on the top part?
                                        All those solder pads for the SMD Zener, transistors, resistors are on the bottom side of the board, you cannot access them from the top side of the board.
                                        • ealequi
                                          • Dec 2012
                                          • 212
                                          • usa
                                          #180
                                          ok give me a minute
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
