Re: Panasonic P50G20E
Panasonic P50G20E
Have a look at the manual for the G20
http://www.tgohome.com/ServiceManual...&Search=Submit
Do any of the options match, or are they completely different?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Tom, with your help I think it will solve the problem of fan
outputs are 4 fans with 3 wires each. a power which is connected in parallel and 4 fans and yellow wire that is separate for each
This is a picture of my board has no connector and it is clearly visible
Very good, though this confuses me: Why would it be configured for fans if the connectors were not placed? Either you need to make a bridge between GND and fan signal line, or between fan line and +3.3V. I'd try the GND bridge first, try identifying which pins on that connector are ground. The thin trace is the fan signal line, probably.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
My English is bad sorry
I wanted to say that the new board has connector,and the old is gone connector ,of it is clearly visible which are GND and which are "+
"as +'m not sure but 4 are connected in parallel so it must be +Last edited by Stanislav; 02-02-2013, 03:58 PM.Comment
Your English is far better than my Bulgarian!Of which I know about zero words...
It makes more sense for V20 board to have connector on it. My tests above apply. Check voltages on each of the pins to locate the fan voltages. You could hook up a fan here if you want; it may end up being temperature controlled. Some other pins will be ground, plus there will be one extra for each fan, a signal line, which either must be grounded or connected to a positive supply. Try grounding those pins first with a blob of solder.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Do any pins have connection to ground. I just had a thought that if it uses speed control it might not show up, because it uses low-side switching. Can you mark on the image what pins show 6.96V?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
In which case, please make a jumper between each signal pin (neither GND nor 6.96V) and each GND pin, a bit of solder will be enough. If it still gives 11 blinks, it probably wants a positive signal.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
So if the grounding trick doesn't do it, we can probably wire them to the 7V (6.96V) safely, with no extra resistors, as assuming they go into ground or into a diode drop, they'll see maybe 7V, and dissipate at most 10mW (they are probably 0603 size, 63mW max.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Damn good TV, I hope you enjoy it
Adding a fan anyway?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This may be because the board is V20B... probably designed for different cable standard (maybe even Freesat, if in UK) than in rest of Europe... you may have to use an external box.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by dajokerMy old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
I chased my way through the PSU, and a board, with no results.
Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
I only have the right half of the picture.
Left half is completely blank.
now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
all the other voltage rails...09-24-2024, 04:39 AM - Loading...
- No more items.
