Pink sparklies and voltage - Panasonic P42UT30B
    Re: Pink sparklies and voltage - Panasonic P42UT30B
    That pink diffusion just looks like dithering if it's moving around. When maldischarge due to low Vsus occurs then it tends to stick on the panel. Example:
    https://www.youtube.com/watch?v=ROYHWY79784
    You can see some of it in my video, in my case Vsus is far lower than it should be due to the bulb. But generally you get static pink patches and discharge issues as the picture brightens. Pink tends to be the first colour noticed because the green subpixels require a slightly higher activation energy to successfully discharge.
    It might be that the TV is compensating for phosphor degradation and upping the gain on the green. To resolve this detail it will use a dither pattern across the panel. The plasma screen does not have a great deal of graduation steps (only ~1000 or so) without dithering, so it is a necessary feature. On most panels it is completely unnoticeable - I own several Panasonic PDP TVs and it is notable that Panasonic invested a lot of money into getting the dither patterns and algorithms right and that if you view the TV from its design distance of about 1.6m to 2m it is invisible. Note that beyond 1.6m the 1080p resolution of the panel is unresolvable to anyone with 20/20 vision.
    If it's not visible from ordinary viewing distance I'd say it's not a fault and by design. The UT30B was Panasonic's entry-level 3D panel, so they had to make a few compromises which probably means it will dither more than a premium-line model like a GT or VT series. It was a first for the budget 3D plasmas (2011) and only a year after their high-end VT20 model which also supported 3D (& 1st proper commercially sold 3D TV, IIRC). Samsung had its entry out a couple of months later (D490) but by any account, having seen both panels, I would say that the Panasonic has it beat...and if you want to see dithering, you need only see a budget Samsung plasma panel. The black levels/graduations are almost entirely made up of dithered patterns!
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      #42
      I repaired this model a few times , it has the same board as in the video. This y-sus is a bit smaller then in the 42ST30/GT30/VT30 and as tom says is the entry level tv.
      You are now probably seeing plasma dithering. You still could try to follow the steps that i said in last post and see if it changes anything because i did not have this fault on the repaired models. ( Did not see pink picture ).
      This still could be a mainboard issue , i had a few of these models that had failed bga solder under the GPU chip displaying weird pictures and/or half screen etc. In this case it is a gamble.
      Does it happen on all inputs?
      • jonnyapps
        • Jul 2017
        • 35
        • United Kingdom
        #43
        I had been a firm subscriber to this but recently had cause to buy a new TV and side-by-side the picture quality (and perceived resolution) is significantly worse on my P42UT30 at 1080p than my new 50CX802 Panny at 4k. Might be the size difference I suppose. Probably getting off track by worrying about this.
        It is visible from my seated position approximately 2 metres away.
        Originally posted by jonnyapps
        In light blue is the position these two potentiometers were in when I opened the TV up. Pink is the position I've had to move both to in order to eradicate the sparklies. They were moved counter-clockwise, towards a number 1 on the PCB and away from a number 3. This has been done in combination with setting VSUS to 'high' in the service menu.
        If this change worked to eradicate the pink noise would it suggest it isn't dithering?
        Yes and from multiple devices and visible in the service menu test screens.
        I intend to take your advice on checking the back of the board. I've just been trying to avoid that process in the hope that something simpler fixes the issue as I reaaaaally suck at soldering.
        I will try to film the effect but it is proving difficult to get anything but weird colours and refresh rate flickers. Perhaps if I change the input to 24hz I might get a better result from my phone camera.
        Thanks again for all the help you're both providing.
          Well, of course a 50" 4K screen would have higher perceived resolution than a 42" 1080p panel . That is from the same distance. However you will find that if you put up a standard test pattern of a checkerboard that the 4K and 1080p checkerboards will be roughly the same - they should appear grey at two metres. If you actually can see the difference then you are perhaps amongst a few percent of people that have better than 20/20 vision.
          There is disagreement on exactly where the point is where higher resolution matters, and it is different for everyone, but many say around sit back around 3-4x the screen diagonal size.
          In terms of colour accuracy and black level (an important factor for night viewing), a UT30B should beat most LED-backlit LCD TVs, except some of the ones using regional dimming, but they are really rare nowadays. This depends on the set being configured correctly.
          Yes indeed it would. Please do note if there is any difference.
          If you have a camera that lets you control shutter during shooting, set it to 1/50 or longer. The way a plasma screen refreshes causes odd effects on recorded video.
          • jonnyapps
            • Jul 2017
            • 35
            • United Kingdom
            #45
            It's definitely better with the initial adjustments from my original post.
              Well that is good. This is with the lower Vsus?
              • jonnyapps
                • Jul 2017
                • 35
                • United Kingdom
                #47
                "They were moved counter-clockwise, towards a number 1 on the PCB and away from a number 3. This has been done in combination with setting VSUS to 'high' in the service menu"
                I'll go back and check this though as reducing VSUS but then setting it to high doesn't seem to make sense and I was also reducing the VDA (assuming that second pot being moved counter-clockwise is also a reduction in voltage).
                  Can you indicate what Vsus and Vda are on now?
                  And yes, decreasing Vsus and then setting it to high is a bit odd.
                  • jonnyapps
                    • Jul 2017
                    • 35
                    • United Kingdom
                    #49
                    can you indicate what vsus and vda are on now?
                    And yes, decreasing vsus and then setting it to high is a bit odd.
                    211
                    52.1
                    Set like that the pink sparklies on white are gone but I notice them in grey now.
                    Time to check the back of the board I guess!
                    • jonnyapps
                      • Jul 2017
                      • 35
                      • United Kingdom
                      #50
                      Oke , first things first because i got the idea your accidentally skipping some possible solutions. Did you tighten ALL the screws on every board including C boards?
                      Could you please do the following?
                      Turn tv off and lay the tv on a soft cloth/table etc with the screen facing down.
                      Remove the power and sc20 cable from the scboard and remove all the screws from the board.
                      Flip the board gently to the left and see if you notice any black marks on the sc board and chassis holes. If so , then take a solder iron and resolder the pads. Only need little solder.
                      If you don't have a solder iron then scrape the black resideu off the board and chassis.
                      Reinstall the board and screws and tighten them. Does it change anything?
                      If not , try to alter the Vsus voltage a little. Place the tv on its stand and use a small screw driver to alter the vsus voltage with 2 / 3 v and see if it gets better. Maybe use a mirror so you can see what you are doing. If there is almost no difference then there are a few options left. ( Don't forget the meter so you can read the voltage , 2v can do ALOT so be careful ).
                      Possible solutions:
                      1) Try to set V-sus to HIGH in service menu
                      2) Replace the mainboard , maybe the GPU is bad causing maldischarge.
                      3) Worst case scenario is that the panel is failing.
                      The buzzing sound that you are hearing is the plasma panel , usually on bright pictures.
                      Let us know what you find!
                      I don't see an SC-board listed in the manual. I do see an SN-board with an SN20 cable. Is that the one?
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        #51
                        Yes that is the same board! But your board is not defective , unless a chip is failing but i doubt that....
                        Its the left board!
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #52
                          Ps , can you adjust the voltage to 215V?
                          Most 30 series have the voltage on 215V and a few on 209 but you said it got better with 211V. Please try 215v.
                          • jonnyapps
                            • Jul 2017
                            • 35
                            • United Kingdom
                            #53
                            Its the left board!
                            Just had a look. A few black marks on the screw hole undersides. Cleaned them up but no major effect.
                            Also tried at 215v and no major effect there either.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #54
                              Then it is either panel of mainboard....
                              Did you tighten ALL screws on all boards?
                              • jonnyapps
                                • Jul 2017
                                • 35
                                • United Kingdom
                                #55
                                Yes I did.
                                Thanks for all over the help everyone's provided in this thread.
                                I've reached the end of the experimentation I'm willing to do and as I now have a new TV will sell this one with the explanation of the problem and what I've tried.
                                Thanks again for a wonderful resource and fantastic help!
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #56
                                  Your welcome! Ps , your better of selling the parts. Especially the working sc board.
                                    @jonny, I am down in London in a month's time and I'm happy to buy the TV off you then.
                                      LCD LED TV Service Menu Codes
                                      ALL LCD LED TV SERVICE MENU CODES
                                      Service Menu Code with Board Name
                                      China Universal Board / Jumper Board Service Menu Code
                                      Changhong Ruba Service Menu Code
                                      Ecostar LED TV Service Menu Code
                                      Orient LED TV Service Menu Code
                                      Haier LED TV Service Menu Code
                                      TCL LED TV Service Menu Code
                                      Samsung LED TV Service Menu Code
                                      LG LED TV Service Menu Code
                                      Videocon LED TV Service Menu Code
                                      Supra LED TV Service Menu Code
                                      Toshiba LED TV Service Menu Code
                                      Symphony LED TV Service Menu Code
                                      Veste/ LED TV Service Menu Code...
                                      10-31-2024, 03:58 AM
                                    • Lintesir
                                      Panasonic P42S30 Plasma - Pink sparkles
                                      by Lintesir
                                      My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                      There is about a 5cm high region at the top without any sparkles,...
                                      07-26-2024, 03:16 AM
                                    • cloo
                                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                      by cloo
                                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                      After doing a factory reset this problem was gone and the picture was back to...
                                      01-06-2025, 06:02 AM
                                    • jimjoe123
                                      LCD TV Green/Pink screen problem
                                      by jimjoe123
                                      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                      Then each time...
                                      02-23-2020, 01:29 AM
                                      Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                                      This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                                      09-06-2024, 09:30 PM
