Pink sparklies and voltage - Panasonic P42UT30B
  • jonnyapps
    • Jul 2017
    • 35
    • United Kingdom
    Re: Pink sparklies and voltage - Panasonic P42UT30B
    Originally posted by tom66
    Use the highest voltage range for your meter (usually 500, 600 or 1000V DC). Make sure to use DC, not AC mode.
    Vsus can be measured at TPVSUS on the power board.
    The SN board (large green board on the left hand side when looking from the back) has the Vad and Vscn voltages.
    You test them on the points TPVAD, TPVSCAN with red probe on those points and black on the chassis.
    The Vda voltage should be available on a small connector on the power supply, or thereabouts, maybe on a point marked TPVAD. Generally in the 55 to 65V range (often 58V on modern Panasonic PDP).
    Be very careful not to slip the probes or touch high voltage parts. It may help to have the ground lead put in a screw hole (I find the stand bracket part works quite well).
    After much scouring, this is the only TPVSUS point I've found. Upon finding it though I noticed those brown scorch(?) marks on those solders...
    And on further inspection they're all over the left board and look more like rust
      Those marks are just dried flux and aren't a fault.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        As tom says , just flux.
        Please follow my steps and post the results or take pictures!
        • jonnyapps
          • Jul 2017
          • 35
          • United Kingdom
          TPVSUS (Measured on right hand board): 217V
          TPVSUS (measured on left hand board): 219V
          TPVAD 33.9.
          TPVSCAN I can't find nor see in the manual.
          Can't find TPVAD (or vda?) on the power board.
            It's TPVDA on the power board...maybe TPVDATA or VDATA.
            Your Vsus looks too high, can you try adjusting the potentiometer so it is around the 209V range?
            • jonnyapps
              • Jul 2017
              • 35
              • United Kingdom
              #26
              Both of the potentiometers? I'm assuming one is for left and one for right as I have 2 test points?
                This TV has only one Vsus voltage, only the larger panels (60"+) have separate Vsus. You are measuring the same voltage on two separate places (SN and SS board).
                Adjust only the highest potentiometer on the power board.
                Note ideally you would have a static image up while testing, as Vsus may vary by a couple of volts with the image.
                Do not adjust the lower potentiometer, it is the Vda adjustment and it is possible (though unlikely) to cause damage to the plasma panel by increasing Vda too high.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  #28
                  219V is way to high and thats why you got sparkles.
                  Start with 209V and see what happens.
                  • jonnyapps
                    • Jul 2017
                    • 35
                    • United Kingdom
                    #29
                    VSUS at 209v tested on a static screen doesn't eliminate the sparklies, though it does improve them.
                    • jonnyapps
                      • Jul 2017
                      • 35
                      • United Kingdom
                      #30
                      The closest I've found is VDATA
                        That's the ticket, test that pin (1) there.
                        **Under no circumstances disconnect that connector or adjust it while power is live as it is possible to kill the plasma panel doing that.**
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #32
                          Dont forget that you now might see plasma dithering and not sparkles.
                          Voltage on 209V and look at the screen from a 2 meter distance. You still see sparkles?
                          Please take a picture of the screen displaying a normal tv picture.
                          • jonnyapps
                            • Jul 2017
                            • 35
                            • United Kingdom
                            #33
                            True , but luckily the voltage on this set won't go lower then 199 and higher then +/-213V. ( If vsus is 209v )
                            Vsus is normally written on the panel sticker.......
                            I have seen plasma tv's that had sparkles because of the arching problem....got worse and worse and then shut down with the 7 blink error. I also saw some threads where people said the image on the tv got worse and shut down with a big bang.
                            Its good to check the screws anyway!
                            Think I forgot to say I took each screw off (except for the ones on the LED circuitry) and checked for any scoring. I only found one screw that looked a bit off and replaced it (had an identical one lying around). It didn't make any difference to anything.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #34
                              Ok but please take a picture of the tv from 2 meter distance. Maybe your now seeing plasma dithering which is normal.
                              Also the arching is UNDER the sc board , im sure the pads are black.
                              https://3.bp.blogspot.com/-XeSHIPRVb...70401_0001.jpg
                              This is what is happening under your sc board.
                              • jonnyapps
                                • Jul 2017
                                • 35
                                • United Kingdom
                                #35
                                Will do when I'm home from work.
                                  When removing the SN board, keep the orange ribbons that go to the panel attached, and very carefully flip it off the side of the TV. Best to have the TV lying face down when doing this.
                                  Reason is they're a pain to get back in once removed, took me quite a while on my ST50B and if you don't need to remove them, don't!
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    #37
                                    So did you reset the tv to its factory defaults also? Picture settings can cause sparkles , definately when set on 219V
                                    It's best to get all values back to its default , hardware and software!
                                    • jonnyapps
                                      • Jul 2017
                                      • 35
                                      • United Kingdom
                                      #38
                                      Yeah I did that before starting anything else.
                                      • jonnyapps
                                        • Jul 2017
                                        • 35
                                        • United Kingdom
                                        #39
                                        57.6v on that.
                                        Pink static definitely still present. Have viewed from normal viewing distance which is 2m give or take. Doesn't resolve in a photo but then that's to be expected.
                                        Current pink static:
                                        A bit more info, that may or may not help anything:
                                        • This static is constantly moving like snow on a TV.
                                        • If I look at the TV through the corner of my eye I can see the panel flickering with the refresh rate (60hz).
                                        • There's a buzzing that comes and goes depending on what's on screen. Silent as I type this, buzzes when I tab to imgur.com (black background).
                                        • Moreno83
                                          • Jun 2014
                                          • 2008
                                          • The Netherlands
                                          #40
                                          Oke , first things first because i got the idea your accidentally skipping some possible solutions. Did you tighten ALL the screws on every board including C boards?
                                          Could you please do the following?
                                          Turn tv off and lay the tv on a soft cloth/table etc with the screen facing down.
                                          Remove the power and sc20 cable from the scboard and remove all the screws from the board.
                                          Flip the board gently to the left and see if you notice any black marks on the sc board and chassis holes. If so , then take a solder iron and resolder the pads. Only need little solder.
                                          If you don't have a solder iron then scrape the black resideu off the board and chassis.
                                          Reinstall the board and screws and tighten them. Does it change anything?
                                          If not , try to alter the Vsus voltage a little. Place the tv on its stand and use a small screw driver to alter the vsus voltage with 2 / 3 v and see if it gets better. Maybe use a mirror so you can see what you are doing. If there is almost no difference then there are a few options left. ( Don't forget the meter so you can read the voltage , 2v can do ALOT so be careful ).
                                          Possible solutions:
                                          1) Try to set V-sus to HIGH in service menu
                                          2) Replace the mainboard , maybe the GPU is bad causing maldischarge.
                                          3) Worst case scenario is that the panel is failing.
                                          The buzzing sound that you are hearing is the plasma panel , usually on bright pictures.
                                          Let us know what you find!
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • Lintesir
                                            Panasonic P42S30 Plasma - Pink sparkles
                                            by Lintesir
                                            My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                            There is about a 5cm high region at the top without any sparkles,...
                                            07-26-2024, 03:16 AM
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                            Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                                            09-06-2024, 09:30 PM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
