MSI PM8M3-V rev. 1 - unstable gaming only
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    #41
    Re: MSI PM8M3-V rev. 1 - unstable gaming only
    I choosen this mosfet as good replacement:
    Vishay SUD50N02-06P
    20V, 6mOhms, 26A, rise time 10nS, shutoff time 24nS
    gate treshold 0.8V, gate charge 19nC
    Even that at 4.5V the resistance is actually 9.5mOhms, then it is still far better that 50mOhms.
    Also the mosfet can operate at 175°C, witch is pretty high.
    While it is a bit slower (rise time 10 to 6, shut off time 24 do 20), the gate treshold 0.8V should compensate that a bit for the original is 1.2V... The slightly higher gate charge 19nC over 15nC should not be a problem.
    I believe I found the perfect replacement, that is better than the original!
    ...however I would prefer that things begin to work, but they do not. I managed to replace the last remaining capacitor on the MSI PM8M3-V mobo - the 10uF d4 SMD suxxka, that have kinda horrible ESR or 3.2 Ohms:
    ...with a new SMD tantal-polymer KEMET 220uF 2.5V capacitor T520B227M2R5ATE015
    ...with have ESR around 0.015 Ohms
    That should be a huge improve. Also I, out of the desperation, resoldered a bit the drain tops of there NIKOS mosfets near the AGP slot.
    And result?
    ABSOLUTELY NONE!
    So it looks like that the mainboard was not up to the blame the whole damn time. It is the videocard that have to be recapped.
    The Radeon R9100 was crashing when new SoF2 level is loading. Given that it run passively cooled on Licon caps:
    ...with 60 mOhms ESR one should not wonder. Rest of the caps looks quite similar, so recapping is in order, just waiting for the caps (as usual).
    The PNY 6800 GT failed after a short time to run in AGP mode, going down to PCI mode and crashing after some gaming is played. Now that is serious problem, because there are just THERE caps, two of them polymers on the voltage input filter and they are Chemicon polymers.
    Last one is unknown 100uF SMD cap and that it is for other that ceramic caps! I would be inclined to add some caps in the blank spots too, probably something over 100uF SMD... and I would also like to create a custom effecient heatsink for the mosfets on the card, because they do overheat a lot - GPU VRM temp 71°C: http://postimg.org/image/x9m8pl4sl/
    Should I try recap these graphic cards before I try replacing the NIKOS mosfets?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
    • tmiha71
      • Apr 2010
      • 130
      #42
      Do you have kill-a-watt ?
      If you do, it would be interesting to see consumption, in idle, and in game (before and after the re-cap)...
      If you re-caped PSU correctly, some improvements should be seen, as lower wattage (personally I've seen few Watts lower consumption on some PSU's), or steadier draw from wall-socket (more often)... Also seen increased draw from the wall :-(( something went wrong, during re-cap)...
      • trodas
        • Jan 2006
        • 770
        • Czech republic
        #43
        Nop, nothing like that. But I plan to getting something so I can measure the wattage drawn....
        And the recap is long time done, no way to measure what it WAS before, mate
        The PSU is fine, because if it was not, then we see troubles from going from Celeron 2.8GHz with 256k L2 to Pentium 4 3.4GHz with 2048k L2 But since the machine is ram/CPU/HDD rock-stable, then sure as hell the PSU is right.
        But the graphic cards need recap. The R9100 is obvious with the bad caps. The 6800GT is much less obvious, but it seems that these Chemicon polymers could be up to the blame for the high temps AND instability during gaming (not to mention that at first it worked at AGP 8x and now only in PCI mode, with is SLOW AS HELL) ...
        Of course it might even be these NIKOS voltage regulators, but I'm less and less inclined to believe this and more and more inclined to believe in bad caps in these graphic cards. Like I say, in few DAYS I will finish the Radeon R9100 and put it back. If it once crash, as it used to do when level loading many times, then I will consider these mosfets to replace. If it does not crash, then I will work on the 6800GT caps and heatsink on the mosfets to get there something serious, fill the omited caps and so on...
        It will require creating a special heatsink just for measuring of the voltages, tough... Because under this:
        http://s22.postimg.org/yjv18ii6p/PNY...eblocker_1.jpg
        ...you simply cant measure a thing. And when my machine is stable, then I should be concerned about power that it draw. Not a minute sooner...
        • trodas
          • Jan 2006
          • 770
          • Czech republic
          #44
          Quick report - after recapping the Radeon R9100, I put it into my MSI PM8M3-V mobo and at first it show ram errors (heartbreaking, after so much work and so many polymers and added caps...) on the screen, so I have to pull it off and check.
          Fortunately, I managed to find the bit of tin, that ended up on one of the bottom ram chips and after cleaning - hoooray, all works like a charm!
          Immediatelly the card go into AGP 4x mode (!) and despite being TAD slower that PNY 6800GT, the system feels notably faster. That is, because, PCI mode DO SUXX BADLY. Therefore it is getting almost sure that the mainboard was NOT for the blame. The bad caps are in the GFX card(s), witch I indent to fix, of course.
          Now is time for a clean win install and then I do more testing - mainly the play testing and longetivity under serious load. Then I might be inclined to see, if I can overclock the card a bit, despite the poor speed to start with
          The lesson from all this is too early to draw, but there are only 3 caps on the PNY 6800GT, that are not ceramic: two Chemicon polymers 330uF 16V d10 SMD and one 100uF 16V d6.3 SMD Nichicon UD with 3.4V on it + some empty spaces, but that it is.
          Since I was getting about 71°C on the VRM mosfets ( http://postimg.org/image/x9m8pl4sl/ ) with just the ATI tool cube in small window, then I suspect these Chemicon polymer caps are up to the blame.
          Of course the cooling of these mosfets is poor, but that was unchanged since day one and the card worked well for me before, so...
          • RJARRRPCGP
            • Jul 2004
            • 6304
            But it definitely don't suxx as much as an HDD in PIO!
            That's probably the worst when it comes to the downgrading bull.
            Windows will downgrade to PIO mode if there's ATA errors.
            (More likely because of a bad ATA cable connection.)
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • trodas
              • Jan 2006
              • 770
              • Czech republic
              #46
              Sure thing. Luckily, that does not happens to me. I even upgraded the HDDs on the mainboard to hi-end ones (system is on 250G Samsung 850 PRO 512MB cache (MZ-7KE256BW), data are on 1024G Western Digital Black 64MB cache (WD1003FZEX) ), but since both are on SATA 150, the speed hardly reaching 130MB/s
              PIO mode will be a killer.
              Sadly even after the recapping, after the first crash, my Radeon 9100 is back in PCI mode. Crazy... but things relatively reasonably work, so... what one can do now?!
              • Loretto
                Samsung SMPS BN44-00339A
                by Loretto
                this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                03-29-2025, 08:30 AM
              • Loretto
                by Loretto
                03-28-2025, 10:28 AM
              • mkdj
                MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                by mkdj
                About me, my goal and the equipment I (don't) have:
                I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                About my issue and my goal:
                A friend of mine has a MacBook Air M1 A2337 that does not...
                04-03-2025, 08:28 AM
                Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                by momaka
                I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                https://www.badcaps.net/filedata/fetch?id=3591771
                https://www.badcaps.net/filedata/fetch?id=3591772
                It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                https://www.badcaps.net/filedata/fetch?id=359177...
                03-12-2025, 03:42 PM
              • thuygsm
                Macbook Air 2020 A2179 820-01958 (5V to the USB-C port unstable)
                by thuygsm
                Hi everyone,
                I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port unstable).
                I noticed there is liquid at U3200 and U3100 and have replaced them.
                PP1V5_UPC_X_LDO_CORE : 1.575V
                PP3V3_UPC_X_LDO : 3.280V
                PP3V3_G3H_RTC: constantly fluctuating from 0.5V to 3.284V
                I have isolated R6979,
                Pin 1: 3.280V stable
                Pin 2: 0.447 (diode)
                PPBUS_G3H: 12.28V (with R6979 isolated)
                PPBUS_G3H: fluctuates 5V -> 4V -> 6V -> 12.28V(when R6979 is present), and repeats in a loop
                What should I do next?
                10-29-2025, 06:02 AM
