Dynex DX-LCD32-09 Sound but no Picture
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dynex DX-LCD32-09 Sound but no Picture
    Originally posted by gorr35
    I was affraid you'd say that!
    The results still don't make any sense, but you did clear up one thing. Your DMM shows a '1' at the left side of the display to indicate the signal is over range. Also, the meter is set on the correct range for the test.
    To clarify things, I've marked up a picture of the inverter. The transformers are numbered 1 - 14. I've labeled the terminals at the top with the letters a and b. With the meter set to the 2000 ohm range, measure the resistance from 'a' to 'b' on each transformer. Don't mess around with marking up a picture, just make a list with two columns - transformer number, resistance. And show all digits of the resistance reading.
    It is very unlikely the resistance of more than one transformer would be over range. If that happens, switch to the 20K range and recheck.
    PlainBill
    • gorr35
      • Nov 2010
      • 127
      #42
      PlainBill
      If I'm doing something wrong please let me know but as pictured i'm still getting the same results on all except the ones I pointed out earlier that just read 1 .
      • PlainBill
        • Feb 2009
        • 7034
        Make sure you are making contact through any coating that may be on the pins. Try at the 20K, 200K, and even the 2Meg ranges. If they are really open, it would explain the 'two seconds to black'.
        PlainBill
        • gorr35
          • Nov 2010
          • 127
          #44
          PlainBill
          2 seconds to black never applied here as the picture never comes up, not even for a split second, but I know what you're saying.
          Retested at the 20k setting and #5,11,12,13,14 are reading 1....all the rest are reading 0.00
          • PlainBill
            • Feb 2009
            • 7034
            Thanks for the correction. I've reviewed the thread and I'm not sure where I got that idea.
            It's time to take a different approach.
            First of all, I note that this was a 'freebie'. What was the history of it?
            Next, there aren't any really good pictures of the inverter. Could you take several, including one really good one of the area where the power and control cable connects.
            Have you checked the fuses?
            Are there any numbers on the transformers?
            PlainBill
            • gorr35
              • Nov 2010
              • 127
              #46
              PlainBill
              The person who game me the TV didn't tell me anything about it other than that she got up one morning and that's how it was. As you can see from post #7 - there is nothing on the underside of the inverter. Both fuses on the inverter test at .09. As far as the transformers....there are no numbers on them, just the numbers next to them on the board - T304 etc.
              • PlainBill
                • Feb 2009
                • 7034
                That makes things difficult. I do have one suggestion. Set your DMM to the 2K ohm range. Choose one of the inverter transformers. Put one probe on pin 1. Measure the resistance to each pin 2 through 6.
                2 Put the probe on pin 2, measure the resistance to each pin 3 to 7
                3. Repeat, starting at pin 3, etc,
                Post the readings.
                PlainBill
                • gorr35
                  • Nov 2010
                  • 127
                  #48
                  [QUOTE=PlainBill;185686] Set your DMM to the 2K ohm range.
                  My meter doesn't have a 2k ohm range....did you mean 20k?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    [QUOTE=gorr35;185688]
                    2K=2000. I was doing my part for the environment by saving electrons.
                    PlainBill
                    • gorr35
                      • Nov 2010
                      • 127
                      #50
                      Post the readings.
                      PlainBill
                      Not sure if this makes any sense the way I posted it.
                      From pin 1 - p2=1, p3=002, p4=1, p5=1, p6=1
                      From pin 2 - p3=1 p4=1, p5=1, p6=1
                      From pin 3 - p4=1, p5=1, p6=1
                      From pin 4 - p5=975, p6=972
                      From pin 5 - p6=002
                      • PlainBill
                        • Feb 2009
                        • 7034
                        From pin 5 - p6=002
                        All right!!! Nothing like giving you the wrong pins to measure.
                        Set the DMM on the 2000 ohms range and measure from P4 to P5 on each transformer and report the numbers. All readings should match to within 3% (about 29 ohms). You are hoping to find one outlier.
                        PlainBill
                        • gorr35
                          • Nov 2010
                          • 127
                          #52
                          PlainBill
                          Is there suppose to be a decimal somewhere? If looking at the previous inverter picture....from left to right. Tested p4 to p5 on each transformer.
                          @2000ohm setting - 970,987,989,989,982,982,988,997,980,985,986,994,999,973.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Interesting - you get a range of 970 to 999 ohms, almost exactly 3%. What's more, that's a pretty consistent range of values. I would have to say those transformers are good.
                            Now we are left with the mystery of why the backlights don't come on.
                            From earlier posts, I remember there was some problem accessing certain boards. Can you make voltage readings on the inverter when the TV is (more or less) together?
                            Also, I keep remembering one TV that gave me fits. I spent hours trying to figure out why the backlights wouldn't come on. Then I turned on the TV while looking at the back of the LCD panel, and saw a very brief flash - only a fraction of a second. The inverter had a very short delay time. If I had tried turning the TV on in a darkened room, it would have been obvious.
                            PlainBill
                            • gorr35
                              • Nov 2010
                              • 127
                              #54
                              PlainBill
                              The problem I was having with the inverter was when the inside of the TV was put together, the Mainboard sits OVER the inverter....covering the half with the power connector. So when tom66 was trying to help me, I had to keep removing this board and that board in order to test.....then put it all together again to test something on the power board. Most tests came back ok. As far as checking for a quick flash when powering on....I think I tried that already and saw nothing, but i'll try again tonight when it gets dark, and I turn off all the lights.
                              EDIT: Something else....I can't remove the metal cover for the T-Con Board without tearing down the whole panel as it looks like the cover has a lip that goes from over the board to under the panel...after taking out the screws it will lift up a little but won't come out.
                              • gorr35
                                • Nov 2010
                                • 127
                                #55
                                I powered on the TV last night in the dark and nothing....not even a little flicker.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  At this point I feel you have four options, none of which I'm real happy about.
                                  1. Buy a working inverter.
                                  2. Run leads from various test points so you can test the inverter while the TV is assembled.
                                  3. If this is possible, position the inverter in a location that you can access it, but obviously the CCFLs will not be connected.
                                  4. Use an external supply (or extend the power leads) and test it on the bench.
                                  PlainBill
                                    I can't remember, did you check the INV_ON pin when trying to turn the TV on?
                                    • finished1
                                      • Oct 2011
                                      • 1
                                      #58
                                      I seem to have the same problem with the same type of TV. DX-LCD32-09 is the model #. Same problem as you described. Same picture with the flashlight and everything. I was able to get a hold of an inverter for $30. I just ordered it. Can you give me instructions on how to change out the inverter. Is it as simple as it looks by just unplugging the wires and placing the new inverter?
                                      • gorr35
                                        • Nov 2010
                                        • 127
                                        #59
                                        Yes that's pretty much it....there's just the one cable going from the power supply to the inverter. Let us know if it works!
                                        • Joust
                                          • Sep 2011
                                          • 4
                                          #60
                                          I have this same problem with a TV from a charitable organization i'm looking at.
                                          some of the transformers output side seem to be open.
                                          my concern is that if I spend the money on a new board, what are the chances the lights are bad? I think its not worth it to replace them as well. new 32 inch tv is cheap.
                                          if I can get a board for 50 all in then it is worth it to repair.
                                          can the lamps be tested?
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
