42PFL7422D/37 Service Manual Needed
Re: 42PFL7422D/37 Service Manual Needed
Thank goodness for the internet!
I have the exact same issue. Same exact location of burned pin.
Is this an inverter board? I tried typing in the S/N on the back of the inverter board at B&D and it came back with nothing.
Where can I buy one of these? Thanks so much!
Edit: I typed in the wrong number.
The *right* number I believe is LC420WU5.
Did a visual inspection of all the caps and other boards, no buldging or leaks, and this part above appears to be the culprit.
Any input appreciated!Last edited by Ripsnort; 11-05-2010, 03:01 PM.Comment
Well, If you do a search on ebay for the chip(bd9897fs), you will find multiple vendord selling it as low as $5 per chip. I just bought about 5 of them last week from a seller on ebay. I have seen this chip in a Philips set and a Vizio set. When I did the Vizio, it was nice to have an extra chip just sitting there. I removed it and replaced it within an hour. However, If you want to replace the board (LC420WU5), ebay sellers are selling this one for $120.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Thanks for the reply.
I ended up canceling the order for the mistake in the board I ordered. (Thought I was getting everything attached! haha!)
So, I did order the 2 inverter board kit. Plan on replacing both even though the 2nd shows no sign of duress.
I'm crossing my fingers that this will fix the issue permanently. I've never seen an IC chip blow on it own. Something else has shorted out causing that part of the chip to overload. Maybe I'll have to sell it fast like you did.
 (I was planning on replace my bedroom 37" LCD with this back up TV....)
The kits you refer to have four of the smaller chips and one of the larger (32 pin) chips. If you read my post here, (#29)
https://www.badcaps.net/forum/showth...974#post129974
this will minimize what you need to replace.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
For anybody attempting to repair this board, this attatchment is a procedure that was created by Philips for also modding this board. The mod is not needed to make the unit work, but should stop future repeat failures.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Foreveraltared - Did you buy a new board and replace it? I appear to have the exact same problem with that huge transformer. It makes this lovely shorting "crackle/zap" when the power is turned on. I'm wondering if I should just replace the board instead of troubleshooting further with the transformer.Comment
Just a follow-up post for anyone who needs the information. I purchased a DPS-168EP board for $60 and replaced it. It immediately fixed the problem.Comment
What is inside a 42PFL7422D/37 depends on who made it & where....OK - I am obviously going to be a newbie to this... I have a 42PFL7422D/37 and I do not see an inverter board. I did find a T-con board, but where everyone else's pics show a panel next to the SSB, I have a flat surface. Could it be that my TV doesnt have an inverter? Basically I have the typical (or so it seems) Philips sound but NO picture. Any advice would be very much appreciated. Thanks so much!
B
LG or AUO ... Did you solve your no picture problem ?
I need some help with same model as yours.....Comment
Interestingly enough, about 3/4 of the new people posting here need help. The other 1/4 are rejoicing because they found the information they needed, and wanted to help us.
Of the 3/4 who need help, about 50% actually give enough information in their first post to help us diagnose the problem. Some even attach useful pictures.
Some don't do so well. Depending on my mood, I will respond with sarcasm, humor, or abuse. A very few will be treated politely. Others will be ignored. This is not your lucky day.
Let's start at the basics. Is the TV plugged into a working outlet?
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
PlainBill[/QUOTE]
Yes ! Plugged in ! After carefully hand-soldering the power / inverter board, I now have back light ! No video, audio OK on all inputs. Conclusion = bad T-con
PCB ..A parts supplier had it for thirty bucks ! Ordered today..# 55.42T02008 for
YA4 Chassis with panel T420HW01 v.4....( AUO = Chinese ).
I will post the final results....
TerryComment
Terry[/QUOTE]
You may be jumping to conclusions. It could also be a bad main board. We HAVE seen a number of TVs with bad voltage regulators on the main board. Still, it IS cheaper to replace the T-con than the main board.
Second main sub = no help , third main had 5 blink code = shorted 7B06 regulator !
Sent back for credit.....Proof in the pudding on this one ! TTYLComment
T-con not an issue.....re-soldered main board ( again ) and re-seat all connectors = FIXED ! Performed re-configure main board procedure and all
option codes checked ! Test ran many hours for several days = solid !
Conclusion = Solder power and main PCB's and clean / re-seat all connectors,
including both ends of LVDS Cable....
Be thorough to avoid re-call !
again thanks to all of you and your great information...I pulled the Slave inverter board out and it was burned in the middle of the B989 chip just as many above had noted. I ordered the two board set from shopjimmy.com for 120.00 with no return fee (several places wanted 150.00 exchange fee) and replaced them both. The set fired right up. Thanks again!!!! PS, I am a RN not an electronics guy...your explanations and photos etc were extremely helpful and made the repair possible.Comment
So when Jaime Sommers (The Bionic Woman) needs repair, she can come to you? Cool!!!again thanks to all of you and your great information...I pulled the Slave inverter board out and it was burned in the middle of the B989 chip just as many above had noted. I ordered the two board set from shopjimmy.com for 120.00 with no return fee (several places wanted 150.00 exchange fee) and replaced them both. The set fired right up. Thanks again!!!! PS, I am a RN not an electronics guy...your explanations and photos etc were extremely helpful and made the repair possible.
			ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
							Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
			by iR0ckHello everyone. Could anyone please share the service manual for the LG 38GL950G monitor? I have been using it for four years and just noticed that the PCB fan has never worked. The self-test also shows an error. It would be great if I could repair it somehow.
							Channel: Troubleshooting Computer Displays
12-01-2024, 07:20 PM -
			by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
			by SMDFleaClevo P670SA Schematic ,Service Manual...
							Channel: Schematic Requests ONLY!
10-18-2025, 04:06 AM -
			by paparazzo79Hi guys.I am looking for GT73VR 7RF Titan Pro service/repair manual.
Like how to dissasembly laptop replace components ,install nvme, SSD etc, no need for schematics.
Help is appreciated....10-12-2025, 05:38 AM - Loading...
 - No more items.
