42PFL7422D/37 Service Manual Needed
  • coreyand
    • Nov 2014
    • 88
    Re: 42PFL7422D/37 Service Manual Needed
    polarbehr, Ive seen this happen when there is a bad TCON board, with the tv on unplug the tcon main connector and plug it back in, see if the picture looks "clear" for a second and then it should return to the way it looks in the picture. If thats the case its the TCON
    • coreyand
      • Nov 2014
      • 88
      So has there been no solution to this DPS-168EP board? I have looked on ebay, amazon, shopjimmy and a few other places to find a replacement board but it doesnt seem there any available. Nor can I find schematics on it. Ive only followed what on Ive read on here, I didnt believe the applying heat to it would work but it did. What is the solution to this? Perhaps a lower uf capacitor at the same voltage rating? Perhaps since were heating up the areas right next to those diodes its the diodes that is the problem.
      I got my tv on using a hair dryer, the picture and color looks off, almost like a issue with the TCON, the picture on part of the left look great but from there over its not so good.
      Ill be checking into the capacitor/diode theory but first I want to see if I can clean up this picture by messing with the TCON. Unfortunately so much has to come off to get to it because its located underneath everything.
      But any info is helpful thanks on the picture and the startup issue. I have replaced the 450v 150qf capacitor also by the way, did that from the get go.
      I also took the tv apart all the way to the panel do you believe this picture problem could be something with the boards and ribbon cables at the top of tv? The image is ghosting from mid point to the right. Attached a picture.
      • dubach tv
        • Sep 2012
        I have a philips I forgot how to configure, will someone help me Model # is 52pfl5704d/f7
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • iR0ck
          LG 38gl950g Service Manual needed
          by iR0ck
          Hello everyone. Could anyone please share the service manual for the LG 38GL950G monitor? I have been using it for four years and just noticed that the PCB fan has never worked. The self-test also shows an error. It would be great if I could repair it somehow.
          12-01-2024, 07:20 PM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
          Clevo P670SA Schematic ,Service Manual
          by SMDFlea
          Clevo P670SA Schematic ,Service Manual...
          10-18-2025, 04:06 AM
        • paparazzo79
          MSI GT73VR 7RF service manual?
          by paparazzo79
          Hi guys.I am looking for GT73VR 7RF Titan Pro service/repair manual.
          Like how to dissasembly laptop replace components ,install nvme, SSD etc, no need for schematics.
          Help is appreciated....
          10-12-2025, 05:38 AM
