Dell Precision 7510 charge battery and left side board problem.
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Re: Dell Precision 7510 charge battery and left side board problem.
    I just ordered another daughterboard just to be sure (bargain it at 30€ including p&p).
    I can't understand why the PBAT_PRES# goes through that board, on fully working 7510 the battery charges the same with or without the daugterboard.
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      I don't know either, but looks like Dell's engineers like it that way :
      Become a Badcaps supporter
      Thanks to all supporters.​
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        Originally posted by SMDFlea
        ok. have you checked PD702,PU1001 and all around the dock connector for liquid damage/corrosion
        Dock connector is clean without corrosion around.
        PD702 and PU1001 are clean BUT next to PD702 is a resistor with one pin corroded (check attachment)
        Now, this resistor (soldered) in my MB shows 1.57kΩ while on customer's MB shows 10.4Ω.
        (Both MB disconnected from everything, without GPU, without RTC).
          • 21986
          Test PD701 and PD702 in diode mode ,replace that resistor PR717 10_1206_5% , 10ohms 1206 5% tolerance.In your picture it looks like theres some crud stuck to the chip above PJP14
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            Cross tested PD701 and PD702 with the fully working (at charge at least) 7510 MB and give identical measurements so all good there.
            I replaced the PR717 and charge issue resolve, now charging battery smoothly.
            I only have one last (?) problem with this MB, when only battery attached i must press the power on switch for at least 8 seconds to power on.
            With charger and battery attached OR charger only powers on instantly.
            Any ideas?
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              #26
              Someone? Anyone?? : )
                • 21986
                Can you find the pads at PWRSW1 @SHORT PADS~D ,and see if the delay is the same after shorting them.
                Did you manage to get all the daughter boards working ok ?
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  #28
                  Tested to short the 2 pins directly from MB to power it on but delay it's the same, not a button problem for sure.
                  I managed to make the customer's daughterboard to half work in my 7510 (only USB is working, HDMI detects 2nd screen but no output)
                  No waiting the fully working (at least this is how advertised) daughterboard from Germany to test further.
                  • Andreasbest
                    • Aug 2014
                    • 1196
                    • Hellas ( Greece )
                    #29
                    I'm at bench now so if you have any idea, let me know, thank you!
                    • Andreasbest
                      • Aug 2014
                      • 1196
                      • Hellas ( Greece )
                      #30
                      Just made a huge mistake.
                      I removed the right side daughterboard (3x USB 1x MicroSD) while laptop was charging, something shortcircuit and smell, now laptop is dead and charger goes off immediately when i connect it.
                      PQ101, PQ103 and all around caps are shorted to GND.
                      Bought boardview too in case community or us need it. Thank you in advance.
                      Boardview - https://www.badcaps.net/forum/showthread.php?t=99399
                      • Andreasbest
                        • Aug 2014
                        • 1196
                        • Hellas ( Greece )
                        #31
                        Dell Precision 7510 shortcircuit. Charger goes off.
                        Hello!
                        Yesterday i made a terrible mistake with my 7510, i removed the right side daughterboard JIO1 while the system charging (was not on, just charging) that resulted to a shortcircuit and since then it's dead, charger goes immediately off when i connect it.
                        I noticed some tiny solder balls next to PQ101, probably created by instant heat right before shortcircuit.
                        All area there (PQ101, PQ103 and nearby caps) is grounded!
                        Any ideas?
                        Photo, schematics and boardview attached.
                        Thank you in advance!
                          • 21986
                          Oh dear,you were so close to fixing it. Looks like some blackened pins on JI01 ,look at the boardview see where they all go
                          • Andreasbest
                            • Aug 2014
                            • 1196
                            • Hellas ( Greece )
                            #33
                            I'll try to trace them Monday morning as i'm away from the bench for some days.
                            My problem is that i don't remember the settings on Allegro to configure it to show copper lines and component names.
                            We discuss it before a couple of months but i don't remember when and where.
                            • Andreasbest
                              • Aug 2014
                              • 1196
                              • Hellas ( Greece )
                              #34
                              Goodmorning.
                              Can't figure it out from the boardview, it's a mess of traces.
                              But from the schematics i see clearly they are pins 44 46 48 50
                              What do you think?
                              Perhaps 1v & 1a from bench PSU will show where the short is?
                              • Andreasbest
                                • Aug 2014
                                • 1196
                                • Hellas ( Greece )
                                #35
                                Found them on Allegro too
                                (to view traces and component names in Allegro ->https://www.badcaps.net/forum/showpo...0&postcount=38 ,thank you @Spider1211 !!)
                                • Andreasbest
                                  • Aug 2014
                                  • 1196
                                  • Hellas ( Greece )
                                  #36
                                  Someone??
                                  • Andreasbest
                                    • Aug 2014
                                    • 1196
                                    • Hellas ( Greece )
                                    #37
                                    With the feeling of talking to my self i report:
                                    PQ101 has all pins shorted, dead
                                    PQ103 has D pins shorted with G, dead
                                    Now i'm measuring PC114 both pins are shorted to GND so i assume +5VALWP line is shorted too.
                                    Am i correct so far?
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      #38
                                      So PC114 was indeed grounded
                                      Replaced PQ101
                                      Now i have a problem with PQ103 traces on MB, they are all kinda shorted between them (~20Ω)
                                      PQ103 is not soldered, i just measure the traces on it's position, is this normal?
                                      • Andreasbest
                                        • Aug 2014
                                        • 1196
                                        • Hellas ( Greece )
                                        #39
                                        Also please confirm the MDV1524 is correct replacement for AON7752
                                        Datasheets attached↓
                                        • Andreasbest
                                          • Aug 2014
                                          • 1196
                                          • Hellas ( Greece )
                                          #40
                                          bump
                                          • Stephen
                                            A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                            by Stephen
                                            Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                            05-29-2025, 10:35 AM
                                          • ravi_1617
                                            HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                                            by ravi_1617
                                            Hello to all ,
                                            I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                                            Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                                            on external VGA port image is perfect /normal , Attached image...
                                            07-25-2025, 12:07 AM
                                            DELL Precision 3630 Precision i7-9700 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL Precision 5820 Precision 5000 W-2235 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 5820 boardview and Precision 5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
