Re: Toshiba 43L3753DB Screen Issue
Hi
Update: When a source is connected to HDMI2, the screen just has lines.
When I enter Service Menu (MENU 4725) the screen just has lines.
Pressing Menu, gives a the menu options, but when you select an item, you get lines.
The Mainboard from the 32" screen TV is not Full HD, so the ribbon connection is different as the panel is different (has in integrated T-Con), so trying that Mainboard is not an option.
43" panel has a separate T-Con.
The only option, without replacing the Main board, is to flash the firmware, assuming this can be achieved by just plugging in a pre-loaded Firmware file into the USB socket at switch on - is this a possibility?
I would also need the firmware, which I don't have at the moment.
Regards
Russell
					Hi
Regards
Russell
