2 Phase to 3 Phase VRM
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: 2 Phase to 3 Phase VRM
    Alright update time... I downloaded the Distributed.net client and ran it for 10 minutes...
    My tempsensor now displays "HHH" this means the temp is over 100°C, even more amazing is that it shows temps 10°C too low (10°C in a room with over 20°C temp...) so it is infact over 110°C hot there now...
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      You need to get yourself one of these bad boys... http://www2.towerhobbies.com/cgi-bin...&I=LXEMG5&P=ML
      I used to use one for checking the temps of my RC car engines. They'd be great for what you're trying to do... and much more accurate.
      Ludicrous gibs!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        dood; the tempsensor I've got now is really accurate. It's this one.
        After calming down a little I brought the system back down to 1.6v and 2.3ghz... Now the MOSFETS are running about 73°C...
        I was thinking that perhaps the reason they get so hot is because the caps have started to fail, they are not visibly bulging but I still think something is wrong for them to get this hot... If they indeed have failed or degraded that would cause the MOSFETS to have to do more work and thus become hotter...
        • Rainbow
          • Aug 2005
          • 1375
          Yes, bad caps can result in hot mosfets. Even so hot that they burn and desolder from the board or even worse (I saw a picture of GigaByte board somewhere with mosfet fried through! the PCB)
          • gonzo0815
            • Feb 2006
            • 1600
            you should consider the substantiall higher ripple current in dual phase vrm too. So, if you drain mutch more power as it is desingt for, the specified ripple current for the inputcapacitor can easily exceeded. Even good caps won`t witstand them for long time. 3 phase vrm desing need s mutch fewer caps with lower ripple current rating and they will therefore last longer.
            But with newest improvements in capazitors, like KCZ and comparable series, the dual phase circuit will be sufficient for all socket A CPU, if properly designt.
            If i ncompare my losy K7s8xe+ vrm with only 4 x 3300 caps, for output, and 4x 1500uF input the you could feel comfortable with 8x3300uf. Especially the inputcapacitors are realy close to the ripple current specs. Therefore i will replace them, even if they are good ucc ones.
            • 999999999
              • Sep 2006
              • 774
              In many overclocking experiments, I had added a jumper wire on the back of the board when it was a 5V rail supplying the VRM subcircuit, between the 5V socket pins and the VRM input inductor leg. Typically that jumper was 12-14 gauge, standard solid core household wire I'd epoxied to the board for durabilty / permanence. It tends to result in at least 0.2V higher supply to the VRM at full load, unless the ATX connector was moved very close to it by the board designer.
              Even then, if you have one of the last generations of CPu running from a VRM off 5v rail, you will see large current and pseudo-accurate software/bios measurements of voltage. All you can do then (reasonably) is measure the PSu voltage at the connector to determine if it's the PSU or motherboard falling short of the goal.
              • Super Nade
                • Jun 2006
                • 294
                #27
                Hannson, put the temp probe on the VRM inductors. You may be in for a surprise
                Q6700 @ 3.6 GHz
                Zippy GSM-6600P
                Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                Abit IP35Pro
                ATi HD4870
                  HP Compaq Elite 8200 Compaq Elite 8200 i5-2500 Specification for Upgrade or Repair
                  This specification for the HP Compaq Elite 8200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8200 boardview and Compaq Elite 8200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-12-2024, 03:36 PM
                • SavaBogdan
                  Help disabling a vcore phase on a MSI X570 Carbon - I have schematics + boardview
                  by SavaBogdan
                  Hello.
                  Does anyone have any experience with disabling a power phase on the CPU vrm?
                  The controller is IR35201 6+2 phases. It only uses 5 phases and the pins for pwm and feedback on the 6'th phase are not populated (no traces).
                  I got the board with a burned mosfet which I removed along with a part of the pcb. I dremelled away the short as best I could and the board started up fine without the vrm heatsink.
                  I then put some sealant and left it for two days to completely dry. I suspect the pressure from the thermal pads on the heatsink compressed the layers so when I started...
                  10-21-2022, 10:05 AM
                • Axis937
                  BQ 727 Chip 2.4V at Phase
                  by Axis937
                  HI folks 1 question on ablout BQ 727 IC. I believe that it is also meant to charge the battery based on the proximity to the battery pins. I have a strong feeling that the battery is dead but i will look at it later. My question is VCC on BQ is receiving the ADP voltage of 19V. However PHASE and HiDRV on BQ is only pushing out about 2.4V with or without battery attached. That 2.4 V is heading to the gate of the charging mosfet. Source is also pushing out the same 2.4V. Finally the battery voltage pin is receiving 2.2V. Do you see this as a issue or no issue. Battery is likely faulty as well as...
                  09-24-2024, 08:49 AM
                • aysat
                  MSI GTX 970 Golden Edition phase restore problem
                  by aysat
                  Hi everyone,
                  I have the weirdest problem of a core phase restoring. I have replaced the doubler, driver and the drmos and checked all the resistors around the main inductor but still there is no switching on that phase. I even swapped these phase with another but still no go. I checked around the voltage regulator ncp81174 but could not find a culprit. i have board scheme but that did not help either. got oscillator and everything but it drives me crazy.
                  Has anyone observed such a behavior before ? I am out of ideas. any help would be appreciated. i will post some...
                  03-03-2023, 01:09 AM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
