Can you dignose from the photo ? . Toshiba 65S2650EV
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4539
    • Italy - Milan
    #181
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    Yes, a tv from hell, sadly.. i thought we there were... now, i was expecting more on pin 12 ic3, i don't know what there is between pin2 q10 and pin12 ic3, it seems pretty straight, only a 10 ohm smd resistor if i can see.. also another thing, if on opto UF1 cold side there is 1,2v then hot side must conduct and then q10 pin3 (i guess base) tied to gnd, test the hot side pins of UF1 it must be less than 1v, maybe q10 has an internal pullup resistor to the collector.. test the pin16 of ic3, must be a little lower than pin12.. have you tested outputs with PSU alone?
    • Ancient1
      • Dec 2019
      • 275
      • Israel
      #182
      Yes. I did not see any V on 12V . I recall seeing no V on Opto Cold side ? I must measure again.
      q10 pin3 had 12.6V
      I will investigate everything and provide as much data as I can.
      I need time to decipher what you wrote, because , having little knowledge I need to think how it works etc. tomorrow
      What puzzles me is that the problem that "started" with blown fuse , bridge and wire resistor has now moved to the Cold Side ? what could it be ? Is it possible it came from Mainboard ?
      Thank you very much for staying with me on this TV.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        #183
        The profile of this tv is of a tv that is been hit once by an heavy spike from the mains, but the faults are been revealed one at the moment, others delayed, sometimes it happens..
        forget the previous post, to make it simple, test only the pin16 of ic3, must be a little lower than pin12..
        PS: the faulty AZ431 is due to the fact that the spike trespassed the optocoupler and hit that.. maybe you can try to put on the 5vsb output a dummy load like 3ohm 2w.. if the tension collapses under 5v then standby psu has something not good in feedback still..
        • Ancient1
          • Dec 2019
          • 275
          • Israel
          #184
          Pin 12 : 9.62V
          Pin 16 : 9.47V
          5VSB is 7.42V ! under [10 Ohm 5W] load it remained stable for ~ 7 seconds.
          Where is the Standby PSU on the board ?
          Should I check Mosfets under HS on Cold Side ?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4539
            • Italy - Milan
            #185
            neghter the mosfet nor diode are the problem, maybe the 6pin controller, but after 7 seconds?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4539
              • Italy - Milan
              #186
              is it possible that you grabbed a bad 431 chip from other psu? Are those psu ok?
              • Ancient1
                • Dec 2019
                • 275
                • Israel
                #187
                I figured 7 seconds are enough. 6pin, IC2 controller unrelated, I didn't check it.
                Not from good PSU.
                I replaced from a good one and still get 7.4V on 5VSB
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  #188
                  ic2 doesn't matter, ic1 is the one... i think your tester battery is low, have you got a new one?
                  • lotas
                    • Jan 2016
                    • 4904
                    • Russia
                    #189
                    It looks like the R37 resistor has burned out.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4539
                      • Italy - Milan
                      #190
                      • Ancient1
                        • Dec 2019
                        • 275
                        • Israel
                        #191
                        OK
                        I replaced the Opto and the "transistor" IC : 817 and 431 , with new ones. AZ431 , EL 817
                        I took out R37 .. asking for trouble.. I knew it..
                        puff .. gone !
                        and found after vacuuming the whole area
                        I put it on masking tape : measures 123K . Its marking is 562 = 5.6K !
                        * I tested my DMM : with 4 AA batteries and SMD Resistors ( which are easy to know the value of ) : my DMM is fine
                        Now I am looking for new 5.6K SMD
                        • lotas
                          • Jan 2016
                          • 4904
                          • Russia
                          #192
                          If the resistor burns out, then most likely the NCP1653A also burned out.
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            #193
                            OK. Got the datasheet.
                            I'll look for shorts. and new R37
                            But FYI , we got 5.2 on 5VSB Pin at first ( no PSU High V output ) , and after changing the Opto and IC : 817 and 431 : we got 7.2 . Thats for standby V
                            • lotas
                              • Jan 2016
                              • 4904
                              • Russia
                              #194
                              So put the native 817 and 431 back in place.
                              "431" comes with a different pinout
                              • Ancient1
                                • Dec 2019
                                • 275
                                • Israel
                                #195
                                Found R37 Resistor 562 . But smaller - see image.
                                Would it burn
                                haven't checked yet for shorts on NCP1653 = IC2.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4539
                                  • Italy - Milan
                                  #196
                                  No, don't put original ones! We are not shrimps the original 431 is faulty, and sorry i thought AZ431 was same as TL431 to simplify things but them are not same, the change ratio vref/vka is different, this why you have wrong Vout, i apologize, i'm very sorry.. get a true Az431.. if you don't have connected mb with this bad Vstby no damage..
                                  • Ancient1
                                    • Dec 2019
                                    • 275
                                    • Israel
                                    #197
                                    I put AZ and 817 Opto from another source.
                                    I am searching for "same size" R37 5.6k Ohm SMD , and another IC2 NCP1653
                                    I don't remember, but I might have connected Main... hehe looks like this TV doesn't want to be repaired isn't it ?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4539
                                      • Italy - Milan
                                      #198
                                      is the face of 431 facing the hot side? if yes so you have probably a bad ic1, to mention that i usually don't have seen any transistor near the 431 area and i ignore its function, maybe check it for shorts..
                                      • Ancient1
                                        • Dec 2019
                                        • 275
                                        • Israel
                                        #199
                                        I don't quite understand : U3 AZ431 is (flat) facing out from the separation line
                                        IC1 ? where is it ?
                                        check what for shorts ?
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4539
                                          • Italy - Milan
                                          #200
                                          i was asking if you have put attention to the right rotation of the AZ431, forget the rest, i think we are going quite to a dead rail.. i don't understand why these strangenesses.. there are not much components to test in a feedback..
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                            Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
