DV15 MLK MB Schematics needed
  • salawayon
    • Nov 2012
    • 578
    • philippines
    The problem with this unit it's totally dead. No lights at all.
    3.34vdc and 5vdc is present at PL4102 and PL4101 respectively...
    Switch voltage: 3.1vdc
    When power switch is being pressed both CPU and GPU doesn't heat up and no supply voltage at both chipset....
    Thanks....
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: DV15 MLK MB Schematics needed
    first flash bios, then check EC.
    • sorinac
      • Jul 2013
      • 123
      • Romania
      try this
      https://www.badcaps.net/forum/showthread.php?t=34711
      • mano115
        • Jul 2014
        • 6
        • EEUU
        I have the same motherboard with shortcircuit in the coil PL4102 (3.3v) and I think that is the NUVOTON NPCE885 BUT I don't have any schematics. Do you have something to help me through. Sorry for my english and keep this good job
        thanks
        • JOHNCOOPER
          • 11
          • INDIA
          dv15 mlk mb schema needed
          • JOHNCOOPER
            • 11
            • INDIA
            dv15 mlk
            no schematic
            all coil have good volt but on pl4401 have no volt
            its a gfx vcccore
            anyone know pu4404 ic name if yes plz tellme
            • sadakhuno
              • May 2015
              • Me
              Originally posted by JOHNCOOPER
              dv15 mlk
              no schematic
              its a gfx vcccore
              Part for Pu4404 is ISL6208BCRZ! I hope to help
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Same board, same issue (no video, no boot). PL4401 no voltage and PU4404 no PWM signal on the PWM Input (checked with oscilloscope).
                Flashed BIOS and all is OK. BIOS can be downloaded from Dell's site, then open a command prompt and type in 3520A10.exe /writeromfile and it will spit out the 8MB ROM which you can flash using programmer.
                Hope this helps.
                A working TV? How boring!
                • AKR
                  RAK
                  • Jun 2015
                  • 3
                  • india
                  Thanks....
                  dell inspiron n5110 is same
                  • AKR
                    RAK
                    • Jun 2015
                    • 3
                    • india
                    Thanks....
                    check this
                    http://kythuatphancung.vn/download/d...matics.html?dl
                    • rhison
                      • Jun 2014
                      • Philippines
                      Hi can i ask about my dell 3520 my battery is good and also the charger but it desktop you can see a no battery is detected?? what probably the problem of that?? i already test on the pin of the battery if there's a 3v yes the laptop haave 3v...
                      hope you can help me thankyou
                      • Quietstorm24
                        • Mar 2016
                        • canada
                        I had the similar problem with my DV15 MLK MB (Dell inspiron 15 3520). only the battery led was flashing giving an error code.
                        I have manually reset the BIOS and this helped to fix the issue.
                        https://www.youtube.com/watch?v=qEx9mq66blA
                        • sureshbobby
                          • Mar 2015
                          • 137
                          • India
                          Hi Friends i have the same laptop which is powering on but no display. please help me
                          • teknoelectronica
                            • May 2015
                            • 8
                            • Mexico
                            Enjoy Schematic inspiron 3520
