APC BR550GI Pro UPS not charging battery
  • theone111
    • Mar 2022
    • 13
    • Israel
    I have an APC BR550GI Pro UPS
    https://www.se.com/il/en/product/BR5...ckups-pro-550/
    The motherboard model I have in the UPS is the 640-1172A-Z_REV05
    The problem I have is that my UPS does not seem to charge the battery when ON.
    After charging the battery with an external battery charger and installing into the UPS (updating change date) the battery drains slowly ~7% every 12 hours with no load connected (the PowerChute SW show decrease in jumps of ~7% not 1% decrements).
    I think it does charge the battery when OFF because I measure ~0.3-0.4A on the wires to the battery. and when connecting external battery charger it does say battery is at 100%.
    The UPS does switch from Mains to battery and back when it should.
    I see no physical damage to the board.
    The 2 fuses F4 and F5 are OK.
    Does anyone have the schematics of this board or can help point me in the right direction for troubleshooting and finding the bad component/connection.
    Thank you
    • Jul 2011
    • 6039
    Re: APC BR550GI Pro UPS not charging battery
    What is going on with the device that is on the heat sink it is looking odd it near T1 and I think is also near IC2 can you please post the part number for IC2
    • theone111
      • Mar 2022
      • 13
      • Israel
      IC2 is TNY278PN (I am waiting for order for replacement - maybe it will help)
      What device looks odd? The silver one I marked PINK In attached picture? I don't know what it is? Why do you think it odd?
        • Jul 2011
        • 6039
        Is there an ic chip that is mounted to it or something else that is mounted to it
        • theone111
          • Mar 2022
          • 13
          • Israel
          I have no idea what it is. There are no markings.
          • benq32
            • Mar 2022
            • 3
            This is simply heatsink for TNY278PN.
            I have the same symptoms. I've changed TNY278PN chip, but there is no changes. Problem exists.
            battery will not charge!
            If I switch UPS on, it makes it internal tests, shows that battery is empty, but no error message.
            If I disconnect the battery and measure voltage on battery pins, it's about 9V -- this is the reason why the battery does not charge.
            Has anyone Idea why it could happen? Why it does not charge the battery?
            Best regards,
            Q
            • benq32
              • Mar 2022
              • 3
              There are two capacitors on th board -- C18 and C32
              Please take a look at the capacitor C18. It is 330mkf
              I've measured it with multimeter and it was about 250mkf...
              I've changed it to something I've found (470mkf 50v) and UPS is working again. Charge voltage about 13v!
              Hope this helps you.
              Solution - change capacitor C18.
              Best regards,
              Q
              • theone111
                • Mar 2022
                • 13
                • Israel
                Best regards,
                Q
                Did you measure them (C18, C32) out of the board (removed from board)?
                I meausred them on the board (they seem to be connected in parallel and got ~600uF (they are each marked as 330uF 35v). I will try and remove them and measure outside the board.
                When I power up the UPS with no battery connected I get ~5.4v and a buzzing sound (see attached zipped video)
                • benq32
                  • Mar 2022
                  • 3
                  Yes, I've measured them by removing from board. If I measured them on the board, it was more or less normal, but it was not so.
                  I've orderen another elkos 330mkf 63v from Panasonic.
                  now all is working fine!
                  Change your capacitors and have a look what happens.
                  • stigger
                    • May 2022
                    I had exactly the same problem. My capacitors looked fine, but tried to replace them with 330uf 35V Panasonic and that helped. Thanks a lot for the tip!
                    • theone111
                      • Mar 2022
                      • 13
                      • Israel
                      So I replaced c18 and c32 (i measured them after removal and they were about 300uf instead of 330uf).
                      Now I get 14.1v when no battery connected and get charging current (measured on the battery wires) of about 0.5A and battery voltage increasing slowly.
                      Is this charging current OK?
                      • theone111
                        • Mar 2022
                        • 13
                        • Israel
                        So I have tested the UPS after the capacitors replacement and it seems to work.
                        Thank you @benq32
                        • lego1234567
                          • May 2022
                          • 7
                          • Slovakia
                          Best regards,
                          Q
                          I had the same problem as you, battery was not charging at all. After removing and measuring the C18 and C32, I found they had much lower capacity (not any visual damage). After soldering new ones, UPS works fine. Thanks for your efforts !
                            • Jul 2011
                            • 6039
                            More items not ending up in a landfill good work to both of you
                            • LimeGreenSky
                              • Jul 2023
                              • Armenia
                              Thank you all for help my BR550GI is up and running again now! An interesting fact is that one of the capacitors was of absolutely normal capacity (C18 - 331mkf), and the second was only 10% less than the nominal (C32 - 298mkf). Wierd though...
                              • pavgoust
                                • Mar 2021
                                • greece
                                Dear All,
                                My UPC is a APC Back-UPS Pro 550 BR550GI to 640-1172A-Z_REV05. Same problem, no charging. I replaced the following: IC2 - TNY278PN, 22 uF/400V on the raised board 2 x 330μF /35V and it still doesn't work. Is there anything else related to the charging circuit breaking down?
                                Thank you
                                • SimpleUsuario
                                  • Sep 2024
                                  • Spain
                                  Thank you very much for this post!!!!!!, I saved quite some money by replacing both caps instead the whole unit. In my case, one of them was faulty, the other one had a capacity of 310 μF which I believe was already too low. (I just created the account to be able to say thank you).
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • Julian Bailey
                                    HP ProBook 445 G8 Battery not charging
                                    by Julian Bailey
                                    Hi all
                                    We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                    The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                    I have gone around the board with a MM and cant find anything
                                    Windows shows the battery fine,...
                                    10-11-2024, 10:34 AM
                                  • piernov
                                    Laptop battery charging circuit
                                    by piernov
                                    1. Some theory
                                    1.1. Introduction
                                    Almost every laptop has a charging circuit of some sort, that does a few things:
                                    • Manages switching between AC adapter and battery power
                                    • Manages battery charging and generates power rail to charge battery
                                    There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                    • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                    • Narrow VDC (NVDC)
                                    Texas instrument has a nice overview of these technologies with some more details at https:...
                                    11-15-2020, 01:31 PM
                                  • kodox
                                    ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                                    by kodox
                                    since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                                    the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                                    what i've done:
                                    - flashing...
                                    12-29-2024, 02:49 AM
                                  • Shinju
                                    Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                    by Shinju
                                    Hey All!
                                    Long time forum member here with a problematic laptop issue!
                                    I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                    The laptop would not power on with the new battery installed without the power supply being plugged in.
                                    When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                    TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                    10-20-2021, 04:58 PM
