GA-P67A-UD4-B3 No Boot
  • Russ17
    • Mar 2018
    • 125
    Hi All,
    This is the second MB I have to repair.
    Given to me for free. I have no history on it.
    It came with an i5 processor and 8Gb RAM. It doesn't boot. The CPU fan LED is inconsistent in its operation.
    All 6 Stage LED's light up.
    I examined the CPU socket and there were some bent pins, which I managed to bend CAREFULLY back. I found one had snapped already, but this appears to be a VCC pin, so shouldn't affect operation (so I am advised).
    Pictures attached.
    I haven't checked VCore, VRAM or 3.3V rails yet. All capacitors are high reliability types (not the usual electrolytic types), so fingers crossed!
    I did find DQ34 transistor had some physical damage, but it seems to check out with my tester (it gives the same readings as other identical transistors on the board)
    I haven't got a PCI Port80 tester - yet
    Any thoughts on the socket pins anyone?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: GA-P67A-UD4-B3 No Boot
    You are correct about a broken Vcore pin, it should't cause a problem. Are you 100% sure that pin is Vcore? Measures resistance from the broken pin to the VRM coils?
    I would be tempted to change that broken transistor - or at the very least unsolder it and test it out of circiut
    I've seen a lot worse LGA sockets than that, which were still working. So the board powers up when you press the ATX power switch, but does not boot? if you then hold in the power button does it shut down? Yepp?
    Which processor are you using? Is it supported by your BIOS revision?
    Do you have any RAM fitted?
    Did the CPU and RAM originally work with this motherboard before it failed?
    When you power it up, does the CPU get warm?
    Is there an onboard speaker, or can you plug a speaker in, and do you here any bleeps (with/without ram fitted)
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    • Russ17
      • Mar 2018
      • 125
      HI Rich,
      I will answer where I can.
      Please see answers below:
      Are you 100% sure that pin is Vcore? Pretty Sure from the CPU layout diagram I studied.
      Measures resistance from the broken pin to the VRM coils? Not Checked as cannot I get on to the broken pin to check continuity.
      So the board powers up when you press the ATX power switch, but does not boot? Correct - it will power up, but, it will switch off after about 15 seconds, and repeat permanently - all without further button presses.
      If you then hold in the power button does it shut down? Yes - if Power Button is held for 4 seconds.
      Which processor are you using? Intel Core i5-3450 3‎.10GHz 6‎MB 7‎20 MHz Ivy Bridge 2‎2nm
      Is it supported by your BIOS revision? Supported from BIOS F8 - but I cannot tell if the BIOS is Rev F8 (stock is F4) as I cannot boot - I don't have another compatible CPU to try - yet.
      Do you have any RAM fitted? Tried with and without RAM and different RAM brands/sizes too - same result
      Did the CPU and RAM originally work with this motherboard before it failed? I cannot find this out at this time.
      When you power it up, does the CPU get warm? With a a big cooler and it not staying on for long, it is tough to give an accurate answer.
      Is there an onboard speaker, or can you plug a speaker in, and do you here any bleeps (with/without ram fitted)? I plugged in a speaker, but no sounds under any conditions.
      The CPU fan I am using has an LED inside the fan (its the only LGA1155 Cooler I have). The fan comes on, but the LED only comes on briefly at switch on - I tried the same fan on another LGS1155 MB, and the LED stays on permanently (as expected).
      Regards
      Russ
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Originally posted by Russ17
        HI Rich,
        Regards
        Russ
        Hmm OK in my not totally vast experience - this type of problem is often a fault with the SIO or more likely the Northbridge (PCH or whatever they like to call it these days) or it could be related to that broken pin in the LGA socket.
        As you can't easily get to the pins around the NB, I would suggest have a look at the pins of the SIO that are related to the sleep states (S3, S5 that sort of signal) and see if it is turning Vcore and the ATX PSU on and off
        The board view file should help here - do you know how to use that? if not I can guide you and promise it will be a revelation! It's worth experiencing board view even if you don't fix this one. It will also tell you if that broken CPU pin really is Vcc
        I know some folks will say no, no, no, or shoot me down here.... but with that CPU type I would remove the CPU heatsink, put one finger on top of the CPU right in the middle, put another hand on the mains on/off switch to the ATX PSU ,and put a third hand (lol) on the ATX PS_ON switch, turn it on and see what happens. If the finger on the CPU gets real hot real quick, switch the mains power off fast with hand number two. If it don't the CPU ain't running
        Maybe one of the other guys here can advise or correct me, I'm still learning too, I'm just a little way ahead of you as I started earlier lol
        • piernov
          • Jan 2016
          • 4435
          • France
          As far as I know a 6-series chipset board will not boot with an Ivy Bridge CPU if it didn't receive the BIOS update for Ivy Bridge. I'd use a Sandy Bridge CPU or flash the BIOS externally at the very least. And in any case flashing the BIOS can be a good idea at this point if it's confirmed not to be a RAM or CPU issue.
          • Russ17
            • Mar 2018
            • 125
            Dear Piernov,
            You make a good point.
            I think the most sensible approach is to buy an i3-2120 CPU, and see if that works, as this is supported from the first release in the Gigabyte MB, and I can also use it in a HP IPISB-CH2 "Chicago" motherboard I have, which also won't boot, but I think this is because I only have the i5 3450 CPU, which is not supported.
            I contacted the person who gave me the Gigabyte MB, and he said that it was working to the best of his recollection.
            Will report back once I have tried the i3 2120 CPU in both MB's.
            If the Gigabyte will boot with the i3 2120, I will then update the BIOS to F8 version, which will add support for the i5 3450 CPU.
            Regards
            Russ
            • privato89
              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
              by privato89
              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
              Let's begin:
              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
              03-26-2024, 06:37 AM
            • Luke Anders
              Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
              by Luke Anders
              A few details about the laptop itself:
              Name: Lenovo Legion 5
              Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
              BIOS Version: GKCN60WW
              EC Version: GKEC65WW
              Serial Number: PF39AQ7Z
              Board Model: NM-D562 Rev 3.0
              RAM: 16GB Installed, DDR4 (brand new)
              NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
              I bought this laptop recently from eBay as a faulty device....
              10-12-2024, 05:13 AM
            • kitor
              HP 400 G6 DeskMini broken bios - never ending boot loop - fix request.
              by kitor
              I have HP 400 G6 DM which is not booting - it will spin up for like 30 seconds, then turn off for a few, boot again... and it goes on forever.
              Can anyone check this dump and maybe attempt to repair it?
              SN is 8CC1340PC8. Board is "Missandei-AUD Rev B Model F91" DAF91MB16B0...
              07-09-2024, 12:19 PM
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
