Zyxel Prestige 660H Triple play ADSL Modem
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    I've been a dialup user for like 10 years but a few months ago finally got ADSL...
    Well, the "modem" I got for free from my ISP is a Zyxel Triple Play, and I just today opened it up to see what was inside... While the layout looks very good and the total number of capacitors and their values seem well in excess their names where not as impressive: Jackcon and Hermei
    I'm gonna keep it "cabbed" from now on, it's in my basement and it's only like 18°C down there so hopefully it will live a long and happy life... I do have a Cisco 827 ADSL modem just lying on my workbench but it's limited to 8mbps (which is what I have now but when I get around to it and swap out my copper lines in the house I hope to be able to jump up to 24mbps...)
    There is another problem and that is that I do not have a working config for the Cisco modem, I only need regular RFC1483 bridging but I've followed Cisco's guide on it right here without success. I do not even get Sync with the ISP...
    Anyway, on with the picture, I do have more if anyone is interested.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Zyxel Prestige 660H Triple play ADSL Modem
    ZyXEL Prestige 652HW-31 (Jackcon and Hermei)
    but it's limited to 8mbps (which is what I have now..)
    i would just like to say #$%@!!!!$$$@*!*!##!!!1
    i have a 827 config for my isp somewhere, i can pass it tomorrow. does it have all nichicon caps like the 2950 switch
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      no it was an 837 but i quote it anyway in case found useful. If you need help, ask on http://www.dslreports.com/forum/equip,cis
      Code:
      (Router 837)
      Router 837 Configuration (Show Run)
      Building configuration...
      Current configuration : 2465 bytes
      version 12.3
      no service pad
      service timestamps debug uptime
      service timestamps log uptime
      service password-encryption
      hostname [hostname]
      boot-start-marker
      boot-end-marker
      no logging buffered
      enable secret 5 [B][encrypted password][/B]
      no aaa new-model
      ip subnet-zero
      ip name-server [B][ip of name server 1][/B]
      ip name-server [B][ip of name server 2][/B]
      ip audit notify log
      ip audit po max-events 100
      ip ssh break-string
      no ftp-server write-enable
      no scripting tcl init
      no scripting tcl encdir
      no crypto isakmp enable
      interface Ethernet0
       ip address [B][LAN ip address] [subnetmask][/B]
       ip tcp adjust-mss 1452
       no ip mroute-cache
       hold-queue 100 out
      interface ATM0
       no ip address
       no ip mroute-cache
       atm vc-per-vp 64
       no atm ilmi-keepalive
       pvc 8/35
       oam-pvc 0
       encapsulation aal5mux ppp dialer
       dialer pool-member 1
       dsl operating-mode auto
      interface FastEthernet1
       no ip address
       duplex auto
       speed auto
      interface FastEthernet2
       no ip address
       duplex auto
       speed auto
      interface FastEthernet3
       no ip address
       duplex auto
       speed auto
      interface FastEthernet4
       no ip address
       duplex auto
       speed auto
      interface Dialer1
       ip address negotiated
       ip mtu 1492
       encapsulation ppp
       dialer pool 1
       dialer remote-name redback
       dialer-group 1
       no cdp enable
       ppp authentication chap pap callin
       ppp pap sent-username [B][username][/B] password [B][password][/B]
       hold-queue 224 in
      ip classless
      ip route 0.0.0.0 0.0.0.0 Dialer1
      ip http server
      no ip http secure-server
      dialer-list 1 protocol ip permit
      control-plane
      line con 0
       exec-timeout 120 0
       no modem enable
       transport preferred all
       transport output all
       stopbits 1
      line aux 0
      line vty 0 4
       exec-timeout 120 0
       login local
       length 0
       transport input all
      scheduler max-task-time 5000
      end
      Last edited by Per Hansson; 05-30-2014, 01:27 PM. Reason: Added "code" tags for code
      • Newbie2
        • Sep 2005
        • 885
        If one of those caps blow then it could be recapped. ADSL modems sould have the same solder job quality that is done on motherboards.
        Am I seeing things or those two big Jackcon caps in Per Hansson's post have those honey-comb vents?
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Newbie2; https://www.badcaps.net/forum/attach...1&d=1399819684
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            This ADSL modem started acting up in January this year, it caused packet loss...
            At first I thought it was the phone line that was bad, but after doing a thorough test I realized it was the modem.
            Code:
            ---[COLOR="Red"]Before recap:[/COLOR]---
            Ping ISP's gateway, Zyxel connected directly to firewall:
            Ping statistics:
              Packets: Sent = 58, Received = 48, [COLOR="red"]Lost = 10 (17% loss)[/COLOR],
            Approximate round trip times in milli-seconds:
              Minimum = 18ms, Maximum = 246ms, Average = 26ms
            Code:
            ---[COLOR="red"]After recap:[/COLOR]---
            Ping statistics for:
              Packets: Sent = 58, Received = 58, [COLOR="Red"]Lost = 0 (0% loss)[/COLOR],
              Minimum = 19ms, Maximum = 176ms, Average = 23ms
            In January I replaced all caps except the 2x large Hermei 2200uF caps, I did not have them in stock but ordered them so I could do it "a little later".
            That time finally came today, because there was a lightning strike that took out several lightning protection devices, but thankfully not the recapped ADSL modem
            So due to the downtime I replaced the remaining two Jackcon caps, it looks like it was not necessary though because they measured 2150uF & 0.1 ESR after I had taken them out...
            The problem with the packet loss was actually not on the DSL side, but the Ethernet side. (Only the 1000uF cap in the Ethernet side still measured good)
            The two Hermei SH 22uF 16v caps had an ESR of 50 & 37 respectively
            And the two 220uF 10v Hermei HT caps had 3.2 & 3.6 ESR respectively
            Before the recap reducing the link speed from 100Mbps to 10Mbps "solved" the packet loss issue.
            The issue can even be seen on the ethernet LED's on the modem, instead of blinking rapidly with traffic they would go dark, for seconds in a row.
            At the same time a packet loss would be registered, and any download in progress would slow to zero...
            The Jackcon caps around the DSL area had ESR ranging between 0.2 > 0.8 (They have no model marking, only the text "LOW E.S.R"
            And as mentioned the Jackcon LHK 2200uF 25v caps measured good, I still replaced all caps though...
            This is how the link looked before the recap:
            And this is after the recap, the link is slightly better, due to the improved capacitors:
            What was interesting with last weekends lightning strike is that it improved the link, the phone line was cut in two places which the telco had to repair, after this it became much more stable:
            I will also need to buy a new "whole house" protector for the incoming phone line because it got destroyed, as did an APC surge protector with built in phone line protection...
            (This was a part of the reduced quality on the ADSL signal but the biggest reason was the line itself...)
            Note the very cool "lightning strike pattern" on the underside of the PCB between the lines & ground! (It arcs over even before it reaches the Epcos surge arrester)
            The name of this surge protector is OBO Blitzbarriere FLD 60T
              • 31201
              what's that "DMT" software?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                It's a software for certain DSL modems that allow you to check the signal quality:
                http://dmt.mhilfe.de/
                For my specific ZyXel v6.12 is the best supported.
                That is to say with this software "latest is not greatest"
                You have to check which major X.YY version number is for your modem...
                  MSI Prestige PRESTIGE 14EVO A11M-431BE Notebook 14 Evo Specification for Upgrade or Repair
                  This specification for the MSI Prestige PRESTIGE 14EVO A11M-431BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PRESTIGE 14EVO A11M-431BE boardview and PRESTIGE 14EVO A11M-431BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  09-06-2024, 10:50 PM
                  MSI Prestige PRESTIGE 14EVO A11M-429BE Notebook 14 Evo Specification for Upgrade or Repair
                  This specification for the MSI Prestige PRESTIGE 14EVO A11M-429BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PRESTIGE 14EVO A11M-429BE boardview and PRESTIGE 14EVO A11M-429BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  MSI Prestige Prestige 15 A11SCX-017 Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Prestige Prestige 15 A11SCX-017 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prestige 15 A11SCX-017 boardview and Prestige 15 A11SCX-017 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 10:00 PM
                  MSI Prestige PRESTIGE 16EVO A13M-259US 16 I7 IRISXE Notebook Specification for Upgrade or Repair
                  This specification for the MSI Prestige PRESTIGE 16EVO A13M-259US 16 I7 IRISXE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PRESTIGE 16EVO A13M-259US 16 I7 IRISXE boardview and PRESTIGE 16EVO A13M-259US 16 I7 IRISXE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-07-2024, 06:21 AM
                  MSI Prestige Prestige 15 Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Prestige Prestige 15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prestige 15 boardview and Prestige 15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-07-2024, 04:10 AM
