zerox 22" lcd psu help
  • swampy
    • May 2011
    • 21
    Hi there everyone im new to the forum and could really do with some advise.
    Im not getting any power what so ever to the monitor,
    So far ive changed these caps :
    Green - 470uf 25v
    Red - 680uf 25v
    purple - 220uf 25v
    brown - 10uf 50v
    and still nothing im wondering if the 100uf 400v cap might need changing.
    Heres a pic of the unit.
    Cheers swampy
  • retiredcaps
    • Apr 2010
    • 9271
    Re: zerox 22" lcd psu help
    If you have a multimeter, then check the DC voltages of each of the pins on the connector on the left hand side of the power board. Your photo is too blurry, but there is a legend just above the pins. List the legend and each DC voltage.
    --- begin sig file ---
    --- end sig file ---
    • swampy
      • May 2011
      • 21
      cheers for that i'll get a clearer picture uploaded tomorrow.
      • jetadm123
        • 2169
        Did you check the main fuse, F201? Also, check fuse F202, as that is for the 5V output.
        If F201 checks good, try measuring the voltage across the main cap, C201. If you're in the USA, it should read 165VDC.
        You should have also changed cap C206, since that is a startup cap.
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          Looking at the burn marks on your board i would suspect the 2 mosfets
          on the rear of the board are gone
          • swampy
            • May 2011
            • 21
            Cheers guys the c206 start up cap is next as its dud.
            • swampy
              • May 2011
              • 21
              I have'nt changed the start up cap yet but i set it up on my desk and plug'd it into the mains and you can here a tick,tick,tick sound coming from the board.
              Also when i checked the dv voltage from the pins on the connector on the right hand side of the power board the voltage fluctuated.
              • PlainBill
                • Feb 2009
                • 7034
                The tick, tick, tick sound is typical of either a bad start up cap or excessive load. The fluctuating output would point to the startup cap.
                PlainBill
                • swampy
                  • May 2011
                  • 21
                  I've changed the start up cap and its still ticking? and the dc voltage from the pins on the connector on the right hand side of the power board is still fluctuating.
                  2 of the pins are 14+v and 2 are 5+v.
                  • swampy
                    • May 2011
                    • 21
                    I forgot to say the board is a Mirage PI-190DTLB board.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Short on one of the outputs. Check the diodes mounted on heatsinks.
                      A working TV? How boring!
                      • swampy
                        • May 2011
                        • 21
                        Thanks for the help so far peeps
                        I've just tested the voltage on the pins and this is what i get,
                        on the +14v pins im getting a bouncing reading from 0 to 1.5v
                        on the +5v pins im getting a bouncing reading from 2 to 3.5v.
                        I think i've just fubar i got a spark while i was testing the c201 cap (400v 100uf) and now it smells of sulphur and im not getting any reading at all
                        I've just blown the F201 fuse T3.15A/250VAC.
                        • jetadm123
                          • 2169
                          Hopefully, once you change the fuse, you'll be back to where you started.
                          • Rtech
                            • Jul 2010
                            • 1095
                            Confirm that of the 4 x 680uf caps,the left hand pair,have their negative side facing the other pairs negative side ?? ( cannot see if they are from the photo).
                            • swampy
                              • May 2011
                              • 21
                              Yes they do Rtech they were one of the first things i changed .
                              Im not too bad with caps its just everything else
                              I've got another monitor that ive changed every cap in but its still having trouble to kick in, (but thats another thread )
                              • Rtech
                                • Jul 2010
                                • 1095
                                Following on,F203 feeds the +14v to both the connector,and to the inverter side of the cct,so when you get it running again,one test I would do would be unsolder one side of the fuse,and then measure both the outputs,and see if the fault may be in the inverter side.
                                • swampy
                                  • May 2011
                                  • 21
                                  Does anyone know of a good supplyer in the uk of these fuses T3.15A/250VAC.
                                  On my board it is a little red box.
                                  Im also im going to change the c201 cap (400v 100uf) as that was what i was testing when i got the blow out.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    You don't need to change the cap. And you can substitute a regular glass fuse with the same specs, there should be enough room for a fuse and a fuse holder.
                                    • sabre504
                                      • May 2010
                                      • 449
                                      • United Kingdom
                                      Forgot i had this may be of some help
                                      • swampy
                                        • May 2011
                                        • 21
                                        Cheers sabre504 thats great help
                                        Would it be ok to swap the 100uf 400v cap for a 120uf 400v cap?
                                        • Laelster
                                          ASRock 9070XT Steel Legend Schematic Request
                                          by Laelster
                                          Currently working on my ASRock 9070xt Steel Legend, and would greatly appreciate a schematic for it!
                                          09-24-2025, 03:31 PM
                                        • nolaryie
                                          BIOS .bin file for ASRock B450M Steel Legend
                                          by nolaryie
                                          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                                          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                                          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                                          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                                          Thank you!
                                          08-06-2025, 12:01 PM
                                        • Rass
                                          asrock x670e steel legend boardview
                                          by Rass
                                          Hello, could you help me with the boardview of an ASrock X670E Steel Legend? I have a project to assemble a PC from scrap parts. My last purchase was this motherboard and I want to try to repair it as much as possible. Any help is acceptable and welcome. Always grateful for the help Greetings
                                          03-23-2025, 11:47 AM
                                        • Miguelitows
                                          Asrock b550m steel legend
                                          by Miguelitows
                                          Hi Guys,
                                          I am new in electronics repairing. Do anyone have Asrock b550m steel legend schematic and boardview if can with front and back layer file?. Thank you in advance guys!...
                                          03-21-2025, 05:44 PM
                                        • karlp028
                                          ASRock B450 Steel Legend - no reaction to power button
                                          by karlp028
                                          I've got an ASRock B450 Steel Legend that I'm trying to diagnose for no reaction to the power button.
                                          The SIO receives the PWRBTN# signal and sends PSOUT#, but the CPU doesn't return SLP_S3# so nothing further happens. I have been looking around the board trying to figure out why and I happened to touch the STEP-DOWN CONVERTER NB685GQ-Z (UP10 in photo) which was VERY hot (like burn your finger). This seems to provide VDDP_S5, and indirectly, VDDCR_SOC_S5, which the CPU needs in order to handle the startup signals.
                                          The VCC voltage powering the converter does not look right....
                                          02-09-2025, 03:52 PM
