Repair an inverter welder
  • edugimeno
    • May 2017
    • 581
    • Spain
    Re: Repair an inverter welder
    Ok after a long time I put this welder back onto the workshop table
    I still have the protecting diodes and the IGBT's removed (although I already have the new ones ready)
    I measured the signal at the G leads of each IGBT's getting an oscillating signal of 0,5V at 66KHz. Then I tried at the E lead and there I gor about the same signal but with more noise and reduced amplitude to 0,5V. Im not sure as I wouild expect only the G gate to get the oscillating signal, and I have the actual transistors removed. Also the amplitude of the voltage getting to both IGBT's is different.
    I see some small plug-in boards close to the IGBT's bethween the PWM boards and the IGBT's, soldered in vertical and with 3 or 4 SMD components, probably a Q and some R. Not sure if they need to be tested
    I can't really invest much more time in this device, should I just go ahead and install the new IGBT's and Diodes and see what I get?
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      I can't see the vertical boards you mention...
      Personally, I would suggest confirming that the IGBT's are receiving balanced signals from the SG3525 in order to avoid risking frying them, but as you seem determined to change the IGBT's, then just do it.
      At the very least it will help clarify the situation.
      • edugimeno
        • May 2017
        • 581
        • Spain
        Ok....I will probably give up on this one:
        (Note: I don't mind testing with the new Diodes/IGBT's before fully checking all the other componens as I bought a bag of 10 of each so if they burn in the first test, i can go deeper and still use another pair for the next attempt...)
        So I went ahead today and tried it. Soldered the new IGBT's and diodes, checked all circuit for shorts/opens around all newly swapped parts, etc and powered it on. No voltage on output.
        Checked the main large capacitor and they were 0v...So I started from the beginning..
        Rectifier briseg with large heatsink: I got ~230V in input
        Also I got 330v DC in its output, one lead from rectifier goes to capacitors. Other lead goes thu some components.... ut somehow they didn't get to the capacitors
        I saw 3 or 4 smaller diodes around and checked them (with no voltage) in diode mode and they meausred OL on both directions....that's crazy! What happened now?
        Is this still worth???
        Thanks!
        • petehall347
          • Jan 2015
          • 4449
          • United Kingdom
          Originally posted by edugimeno
          Ok....
          Thanks!
          maybe they are tvs diodes and still good
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            There are bi-directional TVS diodes that would measure open either way. Post the part numbers.
            • edugimeno
              • May 2017
              • 581
              • Spain
              #26
              I marked the above mentioned diodes in the attached picure, and now that I see it zoomed, I realize that 2 of them are not diodes ae they don't even have the white stripe. Are they chokes?
              But the other 2 at the bottom should read some 0.XXX voltage right?
              • petehall347
                • Jan 2015
                • 4449
                • United Kingdom
                #27
                big ones tvs . other 2 look like regular diodes .
                • edugimeno
                  • May 2017
                  • 581
                  • Spain
                  #28
                  Yes, they are probably...
                  One has a marking 1.5KE200CA which pdf states mentins the bidirectional option when no white stripe, for a dual 185V reverse diode
                  The other one seems to state CHN847 which doesn't seem to resolve into any diode I can find, but it's probably another dual D
                  They are around TNY255 which is an offline power switching driver.
                  Still lost....
                  • edugimeno
                    • May 2017
                    • 581
                    • Spain
                    #29
                    This schematic seems to share a lot with what I see in my welder...
                    https://danyk.cz/svar.png
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      I wood look that all the ICs like TNYxxx and UCxxxx getting power. The problem with both these PWMs is that they can fail and play dead or the lid blows off.
                      Take the IGBTs and the mosfet out and test them. Also test these diodes on the output of the welder. If power is there on these TNY and UC chips, I’d replace them and try again.
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        #31
                        Ok, update, LAST ONE, Short: It's going into the dumpster tomorrow
                        Long Story: I checked it again today. I wasn't getting the right voltages, there's a lot of rust or varnish or something on the solder joints so it takes a lot of force in the DMM pins to really sense the voltage. The large caps DO have 330V, so the IGBT's are "ready" tu pulse
                        I checked the TNY255 PS IC and it does put out 14V and the relay for soft start is working fine with this voltage
                        I also checked the transformer that gets the pulses from the PWM controller and has 2 output, one for each IGBT, and it gets 7v 44KHz pulses, and also power out the right voltage and Hz to the intermediate pulse adaptor circuits (the ones that drive the gates of the IGTB with a Q, some D's and some R's).
                        Then in the middle of this I was going to measure the voltage at the IGBT pins when one of the DMM pins slipped and caused a large spark, mains breakers triggered, and result of shorted IGBT's.... I have some spares but at this moment this repair is not worth to me, I informed my friend I would not invest more time into this thing so Im out...
                        Thanks everyone who helped with this repair, I learn a lot either with those that end up fixed, and also with those that end up discarded.
                        Sidenote to CAPLEAKER. If you see my first posts I had found the IGBT's and associated diodes shorted, and I had already swapped them by new ones. The 2 large output diodes tested fine. Thanks again.
                        • Crystaleyes
                          • Sep 2021
                          • 493
                          • Brazil
                          #32
                          Seems a shame you're gonna scrap it. There is almost always some way to recover even the most random of electronic circuits.
                          Oh well...
                          I take it that you already tried hitting the polyphase discombobulator with a club hammer?
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8352
                            That sux…
                            • Crystaleyes
                              Inverter Welder Strangeness
                              by Crystaleyes
                              Hola peeps.
                              I'm placing it in this topic, because from what I can see, it is essentially a modified SMPS, but please move if there is a 'correct' forum section.
                              Recently, I bought an essentially brand new, but defective, 155 amp inverter welder.
                              The unit would turn on fine, with the digital display and fan doing their thing, however when attempting to strike an arc, the rod would merely spark or just get stuck onto the steel.
                              Now I know that many (if not most) in here would simply not have bought it, but I am still learning this trade...
                              03-27-2023, 04:04 PM
                            • reessi
                              Imac A1312 - Blown Diode, Need Inverter Schematic?
                              by reessi
                              iMac 27-Inch "Core i7" 3.4 (Mid-2011):
                              First off I have the Imac Schematic but only for the mainboard, does anyone have the inverter one or a similiar one from another for better understanding?
                              Searched all over for one!
                              All voltages to the Inverter are correct:
                              (12v in, 3.3v Enable and PWM Approx 3.0v).
                              Output was 12v and moved a little but Inverter was obviously cutting off as D1 was SHORTED.
                              After replacing this the IMAC works for 1 week exactly and dies again. When working the output was correct...
                              12-04-2020, 06:58 AM
                            • spleenharvester
                              Reverse engineering of DoCreate DHJ567 handheld spot welder
                              by spleenharvester
                              Hello everyone
                              I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                              Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                              05-08-2025, 02:52 PM
                            • eccerr0r
                              inverter H tree driver imbalance in an AC inverter
                              by eccerr0r
                              My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                              11-16-2025, 12:34 PM
                            • asr
                              Finding replacement diode iPad Pro 3rd gen A1701
                              by asr
                              Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                              Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                              07-09-2024, 06:24 PM
