Asus UX51VZ Zenbook U500V
  • nicolae788
    • May 2015
    • 31
    • Romania
    I need some help in figuring out if the short i have on this board it's a short to general ground plane or it's a defective component somewhere in the positive current distribution.
    I have a short to ground from the choke near the charger input, a short to ground from the chokes for 5V and 3.3V, a short to ground near the BIOS chip, a short to ground from a choke near the battery connector.
    I attached some images with areas and an arrow that points the direction of the short. The RT 8239B present on this M/B it's shot, but i do not have a short to ground in that area, all the shorts seem to be on the Vin feed. If i connect the charger the path immediately following the charger plug get's hot and it blows the first FET as marked on the picture.
    Being unable to find a schematic for this board, things are somewhat confusing. I managed to find the UX31 schematic but it's not entirely correct, of course, for my case....
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Re: Asus UX51VZ Zenbook U500V
    Hello, I have already almost this same issue.
    Seems every 3,3V or 5V is on short, I removed some MOSFETs like you and replace them but with no lucky.
    Everytime I put voltage at shorted point some times I only get heat at Southbridge chip.
    I have the boardview but I'm confused, could anyone help me?
    • StanLee
      • Jun 2018
      • 2
      • Slovakia
      Hello friends. Did you find a defect in this board? I also have a problem here. Well thank you
      • nicolae788
        • May 2015
        • 31
        • Romania
        Never solved that board. Sorry.
        • playit
          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
          by playit
          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
          09-02-2023, 02:43 AM
        • jkucukov
          Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
          by jkucukov
          I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
          During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
          02-05-2025, 09:27 PM
        • Leefreeman97
          Diagnosing short to ground issue. pcb from an e scooter
          by Leefreeman97
          Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
          09-19-2025, 03:33 PM
          ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
          This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
          09-07-2024, 06:31 AM
        • MisterAIL
          820-00840 / No boot / PP3V3_G3H Short to ground
          by MisterAIL
          Firstly sorry for my english, french guy inside.
          I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
          History is a day, nothing happened when opening the laptop.
          Nothing special inside, no corrosion, no liquid damage, never opened.
          First, with the logicboard alone on the desk, mesures are :
          5v017 and 0.000 amp. nothing else.
          Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
          10-13-2021, 11:42 AM
