Panasonic TC-50PU54 8 blinks picture flashes then dead
  • aasnowskate
    • 118
    • usa
    I have a Panasonic 50 inch plasma TV that has 8 blinks of the red LED Light.
    When I plug it in, I can hear the click of a relay. When the power button is pressed, the screen comes on for a second, then shuts down and then the LED blinks 8 times. I unplugged the SS board and then there is a solid light, no blinks but no picture at all. So I replaced the SS board and there is still the same problem.
    I am leaning toward the SC board being the problem. When I unplug everything from it, there is still 8 blinks when the TV is turned on.
    Does anyone have any thoughts?
    Re: Panasonic TC-50PU54 8 blinks picture flashes then dead
    On the SS board, do you see a point marked TP_SOS8?
    I believe this is just a 2012 Panasonic? Heh, the newer ones don't seem to last...
      Possibly helpful SM documentation
      • aasnowskate
        • 118
        • usa
        Thanks for the reply. There is no place on that board marked TP_S0S8. this is a 2012 Panasonic. The service manual you posted is for a TV that has some different boards. This TV has only one SS board. I do appreciate it though.
          The documentation should be broadly useful, though (8 blink diagnosis in particular) -- I'll try and track down some other documents for you.
            The TC-P50U54 is the Costco variant of the TC-P50U50 which should be similar to the TC-P50UT50 minus the 3D capability.
            • aasnowskate
              • 118
              • usa
              The manual has a great flow chart for the 8 blink problem, but when I follow it with this TV, it has me check the 1 and 2 pins on the SS52 through SS57 connectors on the SS board. When I do this, I have continuity where I should. On that flow chart, it leads me to replace the SS2 board. There is not a Ss2 board on this set.
                Where does it say replace SS2? I only see replace SS? (On UT50 guide. ST50 has SS2.)
                • aasnowskate
                  • 118
                  • usa
                  When checking continuity on SS board, following the YES on the flow chart because I had continuity. This is on the second page of the 8 blink flow chart. the SS57 connector on my set is actually on the SS board.
                  After reading that, I am kind of thinking it might be the A board?
                    Any chance you can easily test pin 5 of "SS33" or "A33" on SS or A board? Check the voltage there as it shuts down. If it goes high (>2V), the SS board is signalling a fault, either SS, panel or A faulty. If it doesn't A is guaranteed to be faulty.
                    • aasnowskate
                      • 118
                      • usa
                      I don't have anything to get in there to get a good reading. The points on my meter don't seem to get a good contact on that pin. However, I now do see the TPS0S8 you were talking about earlier. Is there something you would like me to check on there. Sorry for not seeing it.
                        Yes, that has the same function as pin 5. Check that voltage as it shuts down. There is no need to apologise...
                        • aasnowskate
                          • 118
                          • usa
                          Good, it drops to 0 volts after the tv shuts down. I suppose I will be ordering A or main board. Thanks for the help once again Tom66. this is the second or third TV you have helped me fix.
                            Drops to 0V? I should have said "while it runs" too. What do you get while it runs?
                            Does that mean it is high when the TV powers up? Because that is SS/A/panel.
                            • aasnowskate
                              • 118
                              • usa
                              When I first tried, it was around 4.9v and then whent into shutdown, started blinking and voltage was 0, the voltage stays there until I unplug it and start over.
                              • aasnowskate
                                • 118
                                • usa
                                This is the new SS board that is in there right now.
                                  OK, that indicates bad SS, A or panel.
                                  A and panel are unlikely as you do have light emission.
                                  Two red capacitors on the SS board. Left of this image.
                                  https://www.badcaps.net/forum/attach...1&d=1376316458
                                  What voltage do you measure across these, while the panel is operating? If it is between 60V and 150V, that is good. On the SC, there are also two similar capacitors. The voltage across these should be largely the same as what you get on the SS. I would also compare with old SS board if you can do so easily.
                                  • aasnowskate
                                    • 118
                                    • usa
                                    The voltages on the two caps on the SS board and the two caps on the SC board are within the range you listed while the TV first starts up. They then drop when it goes into the shutdown mode. I have not put the old SS board back in as it is kind of a pain. I am still kind of leaning toward the A board, how about you?
                                      One other thing to check is the SC_UHZ on the A20/SC20 connector. It's pin 9, any way to test it? SC_UHZ may cause 6 or 8 blinks.
                                      • aasnowskate
                                        • 118
                                        • usa
                                        When I unplug the SC20 connector, I still get 8 blinks. When I measure the SC_UHZ voltage it is zero when the tv first comes on and when the LED is blinking.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • FZG
                                          Panasonic AG-1000B VHS player with bad picture quality
                                          by FZG
                                          Hello!
                                          I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                          Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                          I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                          Also, what mechanism is this?
                                          Any feedback is appreciated!...
                                          05-06-2024, 07:16 AM
                                        • Bazfletch3
                                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                          by Bazfletch3
                                          Hi all
                                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                          From there I envisaged that the backlighting wasn't working, however...
                                          01-08-2024, 10:18 PM
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
