Rebuilding Rosewill 350W
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Rebuilding Rosewill 350W
    My next project coming up: Leadman LP6100C. Also, I just rebuilt a sunpro-raidmax 450W. The tiniest secondary capacitors I have ever seen. This psu is used very little as a backup psu by my friend, so it got the leftover teapo caps, 2 X caps, 2 Y caps, better filtering coil, Capxon 470uf, 250v primaries. One thing we didn't do is put a bridge rectifier in it, as I don't have one that will fit. Voltages checked out very well on it, starting right at 12.05, 5.03, and 3.41.
    I have a lot of leftover secondary and primary silicon from some gutted psu's, I wonder if I could add those to improve the capacity of it.
    • everell
      • Jan 2009
      • 1514
      OK.......here is the Raptor 400 watt L&C with two transistor 5vsb removed and piggyback board with DM311 5vsb installed. No load voltage set to 5.01 volts. Using a load resistor of 4.75 ohms, the voltage reading was 5.94 volts. Good results for a one amp test.
      The modification required one pc board trace cut. Photo included. And schematics.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        5.94 volts...wouldn't that blow up your chipset?
        And why did your avatar suddenly get so tiny?
        Also do you have any idea what goes in that spot with the two jumper wires across it?
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Are you talking about the in the primary side next to the bridge rectifier?
          If so, it looks like space for an extra input filtering choke/coil.
          • Toasty
            • Jul 2007
            • 4171
            >>No load voltage set to 5.01 volts. Using a load resistor of 4.75 ohms, the voltage reading was 5.94 volts. Good results for a one amp test.<<
            Happy fingers... 4.94 volts
            OR
            Dyslexia... 4.95 volts
            veritas odium parit
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              OR
              By the way, I just noticed that in everell's new desing, the main 5vsb transistor is removed and only DM311 is powering the 5vsb. Wouldn't that make DM311 overheat, though?
              I hope I'm not asking a dumb question.
              • yanz
                • Nov 2004
                • 910
                #27
                i like it, everell. it looks nice and simple.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  That would make sense, but I wouldn't want to put one there and have it 'splode or do something else on me.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    That Chinamart PSUs got some 'splodin to do .
                    Couldn't resist with the old reference.
                    • everell
                      • Jan 2009
                      • 1514
                      Now, now ...... you shouldn't pick on an old fart. Couple of weeks, on September 2, I will be 61. Don't feel 61, except for occasional "happy fingers" and "dyslexia"! And ratdude, just for your information, mother still tells me to "grow up". Mothers just don't quit.
                      It was a little late for me when I posted the info on the mods for the Raptor L&C power supply. What was intended was .... I set the no load voltage at 5.01 volts. With a 4.75 ohm load, it measured 4.94 volts.
                      Why a load resistance of 4.75 ohms? The ATX specification says the 5vsb should be 5 volts plus or minus five per cent. That would be .25 volts either direction. Since a load resistor should reduce the voltage, I figured that this circuit should be capable of producing one amp at the lowest permissible voltage, which would be 4.75 volts. Using ohm's law, I simply calculated the needed load resistor based on 4.75 volts at one amp. I found a 6 ohm 50 watt resistor. I paralleled a 25 ohm 10 watt resistor across it. Then to tweak it I paralleled a 470 ohm 2 watt resistor across the other two. Resistance came out close enough. At 4.94 volts, that would be a little more than one amp, but was close enough for me.
                      The DM311 chip has a power FET inside. Therefore, a power transistor is not needed for the circuit. Check out the data sheet on DM311. It is very impressive.
                      I did not understand which jumper wires you were asking about. Perhaps you can add some details to your question.
                      Toasty - this is the circuit I want to try on the Powerman PSU. Still haven't found a 5vsb transformer.
                      The mama bird on the forklift is now quite busy. The eggs hatched, and the little baby birds wait patiently while mama flies back and forth with food. Busy birdie!
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        The jumper wire between the bridge rectifier and the filtering coil on your psu. Mine has that exact same spot, I don't know what would go there.
                        • everell
                          • Jan 2009
                          • 1514
                          The markings on my pc board are L1, L2, and C3. My line filter coil is labeled LF1, and the capacitor installed is labeled CX1. I am assuming that the manufacturer could use the LF1 position as on my board, or use the L1 or L2 position for a toroid coil. The C3 is probably a capacitor option, either to add another capacitor, or to use with a toroid coil when used.
                          My pc board has (on the output side) the option of using either a 16 pin chip or a 20 pin chip for the pwm/supervisor. I see some other places for parts not installed and some unused parts jumpered. Again, I think this is a matter of options the manufacturer uses depending on wattage and quality.
                          I am NOT an engineer, but for a 200 watt or so psu, I don't think you will gain much by adding additional line filtering.
                          In my opinion, the most gain comes from changing the input and output filter capacitors, modifying the 5vsb circuit, and adding the line filter you have already added.
                          My 5vsb modification has been implemented on the Raptor L&C 400 watt? unit, a SeaSonic 250 watt unit, and a Bestec 250 watt mobo killer (former mobo killer!). It works well on all of them.
                          • larrymoencurly
                            • Oct 2004
                            • 960
                            I have one with the big heatsinks, and in addition to its bigger caps failing, the 1uF - 10uF ones go bad as well, and I think they receive 50V spikes.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              I was looking at getting a LP6100C which is the 300W version, and surprisingly the LP6100D which is suppose to be a 400W or so will actually run its ratings. But, not much work needs to go into one except caps and a bridge rectifier. I'm working on getting a old YueLin power supply from a friend to tinker with. This one ran as a supplementary psu powering 3 gtx260's in his computer by itself.
                              • everell
                                • Jan 2009
                                • 1514
                                Are you saying you are "going to buy" a LP6100C? I have a LP6100 (by Extreme) and the transformers inside are even SMALLER then the L&C power supply. On the other hand, the Bestec which gets the bad rap has larger transformers than both LP6100 and L&C. If you have not yet purchased the LP6100C, perhaps it would be going in the wrong direction! Even a Bestec can be improved - it just needs work on the 5vsb.
                                If you already have the LP6100C, you can compare it with my circuit board.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #36
                                  Only worth it if you can find an older LP6100 model. The newer ones are built just like all the other regular gutless PSUs with small transformers and tiny primary switchers.
                                  Have you scope the voltage on those caps? Would be interesting to see if the caps really did get 50v spikes. Reason I'm wondering is because I might recap mine as well.
                                  everell: I think the Powmax you have is not a LP6100 but rather a LP7700 variant (as indicated by the transformers). I believe LP6100 has a different design using two 8-pin ICs: a 3842/3843 as the PWM controller and another 8-pin IC responsible for monitoring the voltages on the secondary side (not sure if it's a supervisory chip like the TPS3510P or a dual-voltage comparator like the DBL393, though). Instead of having an isolation transformer, it has 3 optocouplers. The silkscreen for the input filtering is also different.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    I have a leadman lp-8860 and they are identified by the transformer's markings. It uses the same 5vsb transformer as the lp6100 though, as that is marked by lp6100.
                                    The primary transformer is even labeleb as "250W" on the side, even though it was marketed as a 650W. He he.
                                    Real lp6100's have tall heatsinks and actual full input filters.
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      I have an Extreme LP-6100D 400 watt psu - switching transformer marked 7700
                                      Powmax LP-7700D 350 watt psu - switching transformer marked 7700
                                      Powmax LP-8800D 400 watt psu - switching transformer marked 8100
                                      All have the tiny transformers - I don't think any will handle full load as specified on label.
                                      Each of the three circuit boards is different - and use a different chipset. I think they are throwing just about anything in the box and sticking a label on for whatever the customer orders. At this point I don't believe that ordering a LP-6100C will actually get you a LP-6100C. Perhaps a box with a label that says LP-6100C, but what is inside?
                                      Old Chinese proverb say "You get what you pay for ..... if you are lucky!"
                                      • yanz
                                        • Nov 2004
                                        • 910
                                        #39
                                        @370forlife
                                        Hihihi.. Dejavu.. I knew when i saw your pics i have one in my warehouse that looks exacly like your Rosewill. But this one is called Simbadda SZ-430WP4, claimed for 430W.
                                        Caps in the secondary is all AsiaX TMX.
                                        The cables are unbelievably of 18 AWG except for molex wires (20 AWG).
                                        There's a plastic sheet under PCB.
                                        This PSU was from a client that want an upgrade for his entire system. I change the old PSU with a Seventeam 300W (or 250W, i dont remember).
                                        I would use this Simbadda PSU for other project if only i don't have a pile of Seasonic 300W.
                                        I'll recap it and use it for experiment, maybe for changing the 5vsb regulator like everell did. It's really interesting.
                                        Oh, note that it has 2x 12V rails. But, really?
                                        • yanz
                                          • Nov 2004
                                          • 910
                                          #40
                                          @everell
                                          tell me about it.. cheap psu with tiny transformer but claimed for 400W ++
                                          meh!
                                          Hipro 300W (big) vs Ersys 450W (small) :
                                            Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                            by momaka
                                            I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                            For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                            https://www.badcaps.net/filedata/fetch?id=3591771
                                            https://www.badcaps.net/filedata/fetch?id=3591772
                                            It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                            https://www.badcaps.net/filedata/fetch?id=359177...
                                            03-12-2025, 03:42 PM
                                          • eryjus
                                            Heathkit IO-4205 Power Supply Caps
                                            by eryjus
                                            First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                            I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                            I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                            05-10-2023, 11:21 AM
                                          • Paxman_Swede
                                            Identifying caps on an old Zoom 9000
                                            by Paxman_Swede
                                            Hello!
                                            I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                            The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                            I have studied the board and...
                                            01-14-2025, 09:51 AM
                                          • captain150
                                            Help with switching power supply caps
                                            by captain150
                                            I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                            I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                            03-16-2025, 07:34 PM
                                          • Foetuss
                                            Gigabyte GA-6OXT :: caps question
                                            by Foetuss
                                            Good evening
                                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                            But I was also suprised about the bigger boys, which are 330µF 25V.
                                            Could it be they used 25V caps because they were cheaper / available at that time?...
                                            02-11-2025, 12:22 PM
