Rebuilding Rosewill 350W
  • larrymoencurly
    • Oct 2004
    • 960
    Re: Rebuilding Rosewill 350W
    Originally posted by momaka
    Originally posted by larrymoencurly
    I have one [an old Leadman] with the big heatsinks, and in addition to its bigger caps failing, the 1uF - 10uF ones go bad as well, and I think they receive 50V spikes.
    Have you scope the voltage on those caps? Would be interesting to see if the caps really did get 50v spikes. Reason I'm wondering is because I might recap mine as well.
    A long time ago, with a friend's scope, and the spikes were very narrow. Here's the PSU (1uF, 50V caps can be seen in lower right):
    • larrymoencurly
      • Oct 2004
      • 960
      Since that photo was taken, another 3-4 caps have bulged, and the PSU hasn't been used.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        How well does it run it's ratings?
          master hoarder
          • May 2008
          • 12175
          #44
          Can't say for sure since each unit is somewhat different from the next.
          Probably better than most generic power supplies. Primary heatsink is pretty thick too, so that must be helping it. Older LP6100 units also have a TO-247 switcher (which has bigger case size than TO-220) hence better heat dissipation. Still, I wouldn't expect more than 350 watts continuous.
          Not sure how important those 1uF caps are, but I definitely hope the 2.2uF one next to the PWM IC and the 47uF 25v VSB-critical one aren't getting the spikes too - those are important.
          By the way, what supervisory chip does your unit use? Writing looks a bit different from what I have. Can't find a datasheet for mine either.
          • Krankshaft
            • Jan 2007
            • 2328
            Awwww... that 5 VSB transformer is so tiny and cute!!!
            I've seen PWM feedback isolation transformers that were bigger.
            Maybe it's 350 watts peak?
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
