I picked this up through Craigslist, and it is a heavy sucker. The seller reported the 'flashing red light at startup problem', but could not reproduce the problem in his garage. I got it home and after it cooled off (the temp in his garage was over 90°F) it would intermittently begin flashing the red light at startup. If it did start, it seemed to work OK for a 4 year old plasma set. (The panel has some 'burn' from displaying predominately SD images)
Opening it up, I found a pair of 3300 uF, 10 V Samhwa caps in the power supply had bulging tops, the typical cause of this problem. NOW comes the problems.
Searching for '42PF7220A flashing red led' produces numerous hits. Most indicate the typical result of these caps failing is the red light flashing 7 times. This flashes a code 63, which indicates a panel failure. Is this a case of a noisy power supply generating errors, or is this beast going to die shortly?
The power supply seems to have a mixture of Samwha and Samxon caps, with possibly other brands mixed in. Samxon seems to be generally regarded as a good brand, but I wasn't able to find a definitive answer on Samwha. Any opinions? I'm quite willing to replace all the caps IF I could be confident the panel is going to last.
PlainBill
PlainBill
