Hello, like many I see on here I have an LG Plasma with screen issues but no issues with sound. I have a decent background in electronics but zero experience in tv repair. So I've spent several hours reading posts, getting familiar with the components, and testing. I'm still poking around but I'd like some direction from the experts.
Here are the part numbers for this set.
Vizio model: P42HDTV10A
LG Model: PDP42X32000
6871QZH056B
6871QYH048B
6871QDH117A
6871QCH077C
6871QRH068A
6871QLH059A
Symptoms:
Screen is mostly white noise with the entire screen flicking off and on at a high rate. You can see the on-screen display but it's very faint and distorted. Connecting a single results in some picture but it's highly distorted and very faint. Mostly black with image outlines in bits of color.
I've done the basics:
-Tested all removable and surface mount fuses. no issues.
-Tested the output voltages on the power supply. no issues.
-Removed all the boards, inspected the traces and caps.
No obvious cap issues. I did notice odd something on the zsus board. There is a sticky substance like grease covering about a quarter of bottom. No obvious source.
-Some post mentioned running the set for 10 minutes and finding "cool" boards. Well I tried that and everything was cool
I used a thermal gun while running and touched everything once off. I wasn't running a single so maybe that was the issue.
-The ysus board 'ticks' at a high rate when the set it on. I wasn't sure if that was normal. It's possible it's ticking in time with the screen flicker but my eyes and ears can't agree today.
One of the other posts mentioned "Troubleshooting Manual 2007 VG training plasma". This was really useful but I could not do some of the tests because the p50 it's based on is too different. I couldn't find the test points it mentioned to scope. Is the a training manual for this model? I wanted to test the bias of the hybrid circuit but need to procedure. Based on what I've read I think it's the zsus that's the problem but I'm guessing.
Can someone suggest some next steps?
Thanks,
-Bill
6871QZH056B
6871QYH048B
6871QDH117A
6871QCH077C
6871QRH068A
6871QLH059A
Symptoms:
Thanks,
-Bill
