Hi all,i have the above samsung,the power going to the inverter seems fine,iv checked for open cuircuit on inverter,cant fine any bad bits,could this be bad bulbs?how do i test? the inverter board is a inv32s12s,just some help,would a new invertor help?picyure is fine for 3 secs then out.i have a basic cuircuit tester and a capacitance tester,no esr though.iv tried heating the psu caps with hairdrier to see if helped but still same,but im getting good 24v to inverter,the transformers are all clean no burns smell or marks on the underside,can somebody help on how to test these properly?thanks for reading.
samsung le32r87bd loses backlight after 3 secs
Tags: None
Re: samsung le32r87bd loses backlight after 3 secs
Could you post some good clear pictures of the component side of your board?
Take 3 pics.
Left 3rd of the board.
Middle 3rd of the board.
Right 3rd of the board.
That way we should be able to read the markings on the board.------------signature starts here------------
was 1st thing i done mate,power getting to the transformers,and power going out,can measure whats going to the backlight as its too high for my meterComment
i measured the power out from the 4 bits leading from the transformers when turning tv on,all have power out,but goes too high for my meter to read.so im guessing bulbs?any way at all to test?Comment
You will probably have to wait until someone with a little more knowledge than me comes along. The pictures are very good which will help a lot.------------signature starts here------------
Check resistance of inverter transformers. With power OFF.
https://www.badcaps.net/forum/attach...1&d=1385298441
Between the two top left outputs, then the two top right outputs, of each transformer. Use 20kohm range. Report reading for each pair of connections.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
hi tom,the readings i have are
1st transformer L=1.18 R=no reading
2nd L=1.18 R= no reading
3rd L=1.16 r=no reading
am i reading like you asked?
the top 2 on the left the the top 2 opposite on the right of the transformer?
excuse my ignorance!Comment
sorry i take it you ment as it faces me!duhh!
ok again!
1st transformer L=1.19 r=1.19
2nd L=1.19 R=1.19
3rd L=1.19 R=1.17
silly me!Comment
ok again!
2nd L=1.19 R=1.19
3rd L=1.19 R=1.17
silly me!Comment
All your transformers seem OK, so most likely you have a bad bulb in the LCD panel.
In the top centre of this picture
https://www.badcaps.net/forum/attach...7&d=1385297274
there is a chip for controlling the backlight, can you read its part #?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
0z9966sn
ma9834.1t
0735b1
is whats written on the larger one with countless legsComment
OZ9966 is the one of interest. Need a closer pic of it. You can place a solder jumper, which will disable error detect, enabling you to see which bulb in the panel has gone bad.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... -
Hi everyone!
Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
My issue: No backlight.
Model: QE82Q70RAT
Type No: QE82Q70RAT
The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
So hopefully, I can fix this cheaper.
by howardc64TV was fixed just after removing Samsung's rear snap cover.
This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
Maybe PSU->backlight connector didn't have a good contact?...07-23-2025, 12:34 AM -
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
- Loading...
- No more items.
