Lenovo L340-15API BIOS Dump needed
  • JoeyFitzp
    • Feb 2015
    • 7
    I am looking for a BIOS dump for a Lenovo L340-15API. NM-C101 Rev:1.0.
    The laptop was shut off during a BIOS update and doesn't boot. The power light flashes and has a slow fan spin. If anyone has one they are willing to share, I would greatly appreciate it
    • 20695
    Re: Lenovo L340-15API BIOS Dump needed
    Post your corrupt backup ,someone will help .
    • JoeyFitzp
      • Feb 2015
      • 7
      Here is the BIOS dump that I suspect is corrupt
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Try
        Become a Badcaps supporter
        Thanks to all supporters.
        • JoeyFitzp
          • Feb 2015
          • 7
          Originally posted by Vesko356
          Try
          Thank You!!!
          That BIOS dump worked
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            You're very welcome!
            • wckeeper
              • Jan 2020
              • 5
              • Scotland
              Could you tell me if you used the same chip or new one. I have old programmer and used mx 25L6445E instead of original 25LB64CSIG and it doesn't work with the file from Vesko356. Both are 1.8V and I just wonder if it's problem with ic compatibility or something else.
                • 20695
                The 25LB64CSIG is 1.8V .The 25L6445E is 3.3V (working voltage) VCC = 2.7~3.6V
                https://www.gigadevice.com/datasheet/gd25lb64c/
                • wckeeper
                  • Jan 2020
                  • 5
                  • Scotland
                  Now it's clear. I expected "L" means 1.8V. Looks like it's time for new programmer. I'm using GQ-4X. Many thanks for help.
                    • 20695
                    LB means 1.8V ,see page 64 in the datasheet
                    Series
                    LB: 1.8V, 4KB Uniform Sector, QE=1 Permenently
                    I found a 1.8V adapter for your programmer.Don`t expect it to be added to the chip supported list - http://www.mcumall.com/forum/topic.asp?TOPIC_ID=13311
                    https://www.ebay.co.uk/itm/GQ-4X-SPI...-/112388345340
                    • wckeeper
                      • Jan 2020
                      • 5
                      • Scotland
                      Series
                      Not supported.
                      • huss584
                        Hussein
                        • Apr 2020
                        • 226
                        • Palestine
                        Please Clear BIOS,
                        Attach my Original File
                        • peste
                          • Dec 2016
                          • 12652
                          • ROMANIA
                          bios extracted from the Lenovo site update
                          DMI 2C9000 - 2CAFFF
                          • wckeeper
                            • Jan 2020
                            • 5
                            • Scotland
                            Just for update of my previous post. I've got again similar laptop V155-15API with the same motherboard NM-C101 and bios issue. This time I used CH341A programmer with 1.8V adapter and test clip. Chip 25Q64FWSIQ programmed on the board successfully. Laptop is working fine with no issues. Thanks Vesko356 and SMDFlea for support.
                              • 20695
                              Thanks for the update - https://www.badcaps.net/forum/showpo...34&postcount=6
                              • orarun
                                • Dec 2021
                                • 1
                                • Russia
                                I have my laptop's BIOS blocked by a password some time ago and forgot it .
                                I have Lenovo IdeaPad L340-15API 81LW0053RK.
                                to: wckeeper
                                I have the same model as you. Could you please help me with some questions.
                                1. Do these things are enough to program a BIOS chip right on the motherboard?
                                https://aliexpress.ru/item/329078604...id=65890590318
                                https://aliexpress.ru/item/400012005...00000329733787
                                2. Can I use file from Vesko356?
                                3. Do I need to reprogram the EC ITE8586 also?
                                Thank you in advance!
                                • SteveSherwood
                                  • Aug 2021
                                  • 2
                                  • Ireland
                                  Try
                                  Thanks for the Dump. Works great!!
                                  • SteveSherwood
                                    • Aug 2021
                                    • 2
                                    • Ireland
                                    to: wckeeper
                                    This is everything you need.
                                    Check out: https://www.youtube.com/watch?v=JoqwHaV8reY
                                    https://www.aliexpress.com/item/1005...ct.mainProduct
                                    • octopus1973
                                      • Jan 2023
                                      • 2
                                      • Rheinland-Pfalz
                                      Hello wckeeper,
                                      I have the same Board as you. Which file do I need for the programmer CH341A?
                                      Thank you for your help
                                      • peste
                                        • Dec 2016
                                        • 12652
                                        • ROMANIA
                                        Originally posted by octopus1973
                                        Hello wckeeper,
                                        bios for... L340-15API, L340-17API, L340-15API Touch, V155-15API use the bios from post #13, if you have the 25Q64FWSIQ bios chip you need an adapter from 3.3v to 1.8v, don't forget to do a copy of the original bios before writing..
                                        • Joluvillas
                                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                          by Joluvillas
                                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                          06-18-2024, 10:35 PM
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          Hi everyone,
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • hirens
                                          Lenovo ideapad 3 14IGL05 bios dump needed
                                          by hirens
                                          model: 81wh
                                          sn: pf36ta6h
                                          board no: nm-c961 gs453/gs553
                                          hey guys above is my laptop info
                                          it only blinks the power button kindly help me with a working dump
                                          old dump attached...
                                          07-21-2023, 04:48 AM
